Having trouble passing Smog.
Replaced rotor, cap, wires, plug, o2 sensor, cleaned injectors , new cat etc, figures are way down but mechanic says probably need EGR to get it to pass, except this is a federal car so never had an EGR.
only fail is :
NO (PPM)
25 mph MAX 609 AVE 265 MEAS 893
Location?
4 or 6 cyl
Nox?
2 more posts and the classifieds will open up for you. You can always put your Vin in the registry
If the vehicle didn’t come from the factory with an EGR, how can DMV require one be installed?
Just asking.
  • pigneguy changed the title to Smog fail on 91 Comanche
youre right ,no egr on a '91
here's smog reports:
initial gross polluter and last one with new cat. wires, plugs, rotor, cap etc
swapped out O2 sensor but purchased a bosch ny mistake, will swap in an NTK this week
IMG_1554.HEIC
NOX is related to temperature, isn't it? What thermostat are you running -- and does it work? What spark plugs are you using?
Any luck getting it to pass?  I'm having the same problem with my '91 - high NO.  We had a bad vacuum leak (bent injector rail) but that is fixed along with a bunch of other clean up to vacuum lines and grounds.  I can't even remember what we have done at this point.  With everything we have done to it to try and pass it runs amazing, especially after we  just installed 4 hole injectors these week and taking in in.
Switch to a 185 thermostat
With a spray nozzle on your garden hose clean out the fins on your radiator
Make sure your mechanical fan clutch is working fine or just replace it
Run 91 octane (can be debated if 91 creates a cooler combustion chamber temperature)
Smog it with a 1/4 tank keep the weight down
Sea foam your engine and do an oil change
Run some fuel injector cleaner through your fuel system
Change out your fuel filter
Check or change out your fuel injector pressure regulator on the injector rail
By your numbers look like you could afford to create a richer A/F ratio
Trying to get your computer to create a richer burn, same air, more fuel, lower combustion temps, lower NOx
Also
Check for a cracked exhaust manifold down at the collector
Check the exhaust manifold gasket especially around the #5 and #6 cylinders
Any pre cat leak could cause a High NOx situation
To check for leaks just pressurize your exhaust system and with a spray bottle with some soapy water spray the gasket and collector areas and look for bubbles (small shop vac works well)
Well except for the vacuum we have done all of that.  We've checked for leaks but not as thorough as that method - will need to give it a try.
no luck, no vacuum leaks, swapped out the bosch O2 sensor for an NTK.....figures barely changed it's frustrating.
Mechanic says he can't adjust the timing etc as the computer justs re-adjusts..... how does one "hget the computer to create a richer burn..." under these circumstances ?
Yes, you are correct, it has no adjustment, that's were the --
Cleaning out your radiator
Going to a colder thermostat
Cleaning out your injectors or maybe bigger injectors
Maybe A colder spark plug
91 octane
Make sure the clutch on your fan is working
--Comes into play.
High combustion temperatures leads to High NOx
Ask me how I know.
The cooler it runs the richer the computer will try and make it run, like starting it up on a cold morning.
Also, check for an exhaust leak!
Awesome, every 2nd year I always sweat bullets. :L: I forgot to to ask if it was Auto or Manual, RPMs on the 25mph 2305 rpm on the Fail vs 1478 on the pass the lower RPM also could of played a roll in the Pass also. I Love to see these on the road, I have a goal to have as many or more as Fiatslug !!! Hopefully we get one in over at Fairfield PnP, meetup, and tag team it and save a little bit of history :wink:
16 hours ago, fiatslug87 said:
Congrats!!!
So, what did you do???
Smogged cold and kept shop fans on the front. Lower rpms seem to have helped also.
