ghetdjc320 Posted Friday at 06:21 PM Author Share Posted Friday at 06:21 PM On 3/21/2025 at 6:07 PM, watchamakalit said: Tightening those bolts is not that bad. I'm sure it's well within the scope of your abilities. Surprised to see what appears to be a steel exhaust not of the stainless variety. You getting cheap at the end of the build? Lol Expand Mostly running out of time . Aluminized works well if you keep it clean. I was going to tig up a 304 system but just don't have the time. this should last me several years and is honestly going to be a nice layout to model after when I eventually tig up a stainless setup . I've been down into the column that far before, but it's been some time back. Probably a couple of hours to carefully disassemble and get it repaired correctly. Going to use red Loctite and torque to spec. I also replaced the turn and wiper switches and installed a NOS cruise control turn signal/wiper lever. I removed the OE style cruise control connector and replaced it with a 4 pin Deatsch connector to connect to the LS PCM. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted yesterday at 02:57 AM Author Share Posted yesterday at 02:57 AM Some update pics: Link to comment Share on other sites More sharing options...
A-man930 Posted yesterday at 02:16 PM Share Posted yesterday at 02:16 PM Is this intended to be a moisture barrier? On 3/25/2025 at 2:57 AM, ghetdjc320 said: Some update pics: Expand Link to comment Share on other sites More sharing options...
ghetdjc320 Posted yesterday at 03:52 PM Author Share Posted yesterday at 03:52 PM I On 3/25/2025 at 2:16 PM, A-man930 said: Is this intended to be a moisture barrier? Expand Partly. Also a good thermal barrier and dampener. The inside of the doors and around the speaker have been completely dynamated. The dynaliner is a 1/8” closed cell barrier just used behind the door panel. The door panels themselves are 3/16” birch with a foam layer followed by the vinyl. They are quiet as a Mercedes Link to comment Share on other sites More sharing options...
A-man930 Posted yesterday at 05:07 PM Share Posted yesterday at 05:07 PM On 3/25/2025 at 3:52 PM, ghetdjc320 said: I Partly. Also a good thermal barrier and dampener. The inside of the doors and around the speaker have been completely dynamated. The dynaliner is a 1/8” closed cell barrier just used behind the door panel. The door panels themselves are 3/16” birch with a foam layer followed by the vinyl. They are quiet as a Mercedes Expand I'll be keeping this in mind. Nice work Link to comment Share on other sites More sharing options...
