hakukamana Posted February 13, 2020 Posted February 13, 2020 Just purchased, running but not driving. No Brakes. 1988 Sport truck Short Bed. White. Project "future", $300, just couldn't pass it up. 4.0L Automatic column shift, 4x4. Bench seat mini console for 4x4 shifter. Idiot gauge cluster. Drivers mirror only. White Camper shell. AC, power steering, manual windows, fixed vent windows. Blue Interior.
eaglescout526 Posted February 13, 2020 Posted February 13, 2020 *X3 -Q8 AGC APA MONOTONE PAINT PACKAGE BCQ Battery - 750 Amp Maintenance Free CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DGW Transmission - 4-Spd. Automatic,44RE DSA LIMITED SLIP DIFFERENTIAL DTA ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS HAA AIR CONDITIONING - FRONT JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MBG Bumper - Rear Step, Painted MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NHQ Transmission Heater PWB QWB RAC RADIO - AM/MTR SBA POWER STEERING TBB CONVENTIONAL SPARE TIRE WJD WHEELS - 15 X 7.0 STYLED STEEL XPF PROTECTIVE COATING AND REMOVER Build date 3/20/88 Body code JL61
hakukamana Posted February 13, 2020 Author Posted February 13, 2020 Its a little rough, this is the one that had the RH mirror delete. Got a pinched DS fender. Had to take off and pound out..
500 MJ Posted February 13, 2020 Posted February 13, 2020 THAT is a heck of a deal for $300 anywhere, not to mention you are on an island where you would otherwise have to pay big money to have MJ parts shipped to!
eaglescout526 Posted February 13, 2020 Posted February 13, 2020 1 hour ago, hakukamana said: I think I spy a factory tube bumper
hakukamana Posted February 14, 2020 Author Posted February 14, 2020 Eagle Scout you are correct. After your post I compared the license plate lights, the inner plastic caps and the brackets it was a factory tube bumper. Its trash and rusted pretty badly. Its been backed up into the tubes and they are bent and dented. I looked at the tube thickness looks like .0625 thickness its paper thin. No wonder if you backed into anything it dented. The piece of channel I think was used as a tow ball extension. The spare tire winch is in tack and functional, the load valve for the brakes is there and the rod and the bracket on the diff all in place. This is the first truck I've ever seen with all of these pieces still on the truck. Looks like the original muffler, and exhaust pipes.
hakukamana Posted February 14, 2020 Author Posted February 14, 2020 Eagle I don't think the transmission is a 44RE, if memory serves me, is that what was used in a Grand Cherokee with a 5.2L? I would think in 88' it would have been a AW4.
Pete M Posted February 14, 2020 Posted February 14, 2020 that would be one of those codes that got reused.
eaglescout526 Posted February 14, 2020 Posted February 14, 2020 Yup. AW4 codes still exist which is good. I'm very surprised to see a factory tube bumper.
jdog Posted February 24, 2021 Posted February 24, 2021 Selling Dealer: COURTESY PONT-JEEP-EAGLE Honolulu, HI
makoa Posted August 16, 2021 Posted August 16, 2021 1988 sport truck 4x4 4.0L automatic 6 cylinder Still runs, but is being worked on
eaglescout526 Posted August 17, 2021 Posted August 17, 2021 *X3 -Q8 AGC APA MONOTONE PAINT PACKAGE BCQ Battery - Maintenance Free CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DGW Transmission - 4-Spd. Automatic DSA LIMITED SLIP DIFFERENTIAL DTA ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS HAA AIR CONDITIONING - FRONT JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MBG Bumper - Rear Step, Painted MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NHQ Transmission Heater PWB QWB RAC RADIO - AM/MTR SBA POWER STEERING TBB CONVENTIONAL SPARE TIRE WJD WHEELS - 15 X 7.0 STYLED STEEL XPF PROTECTIVE COATING AND REMOVER Build date 3/20/88 Body code JL61 Sold by COURTESY PONT-JEEP-EAGLE, HONOLULU HI
