silvertwinkiehobo Posted July 31, 2021 Share Posted July 31, 2021 Joe and I have converted his '88, although I'm a fan (pardon the pun) of a well-executed closed loop system, this one just had a truly crappy tank. So we got a couple used but excellent condition radiators from the J/Y, and both have the bung for the older fan temp sensor, but after burping the system three times from cold to hot and back down, it works beautifully. I made a junkyard run in it with nearly 900 pounds of metals, and it never went over 220°, considering it was a hot Texas day, and I kept the trans in a lower gear, which kept the engine speed around 1800-2000 RPM. Link to comment Share on other sites More sharing options...
89 MJ Posted July 31, 2021 Author Share Posted July 31, 2021 16 minutes ago, silvertwinkiehobo said: Joe and I have converted his '88, although I'm a fan (pardon the pun) of a well-executed closed loop system, this one just had a truly crappy tank. So we got a couple used but excellent condition radiators from the J/Y, and both have the bung for the older fan temp sensor, but after burping the system three times from cold to hot and back down, it works beautifully. I made a junkyard run in it with nearly 900 pounds of metals, and it never went over 220°, considering it was a hot Texas day, and I kept the trans in a lower gear, which kept the engine speed around 1800-2000 RPM. Thank you. My plan is to covert to the open system and run a Mishimoto radiator. Link to comment Share on other sites More sharing options...
silvertwinkiehobo Posted July 31, 2021 Share Posted July 31, 2021 I honestly don't think you need a hifalutin', high-cost radiator, but I do think you need a clean and thick cross-section one. But, it is your truck. Link to comment Share on other sites More sharing options...
89 MJ Posted July 31, 2021 Author Share Posted July 31, 2021 1 minute ago, silvertwinkiehobo said: I honestly don't think you need a hifalutin', high-cost radiator, but I do think you need a clean and thick cross-section one. But, it is your truck. I know I don’t need a hifalutin’, high-cost radiator, but I am done fighting the cooling system, so we are going with high quality, name brand parts. Link to comment Share on other sites More sharing options...
watchamakalit Posted July 31, 2021 Share Posted July 31, 2021 Personal I don't mind the closed lood system. I have a macs tank and a homemade overflow bottle (old gatorade jug). So some would say its an open loop now I ran for years with plastic tanks with few problems. I think the closed loop is sufficient if properly maintained. Link to comment Share on other sites More sharing options...
cruiser54 Posted July 31, 2021 Share Posted July 31, 2021 The biggest problem with the closed system is the crappy expansion tanks we have these days. They're junk. Link to comment Share on other sites More sharing options...
89 MJ Posted July 31, 2021 Author Share Posted July 31, 2021 1 hour ago, watchamakalit said: closed loop is sufficient if properly maintained. This is my issue. I am fighting all of the lack of maintenance from, I would guess, since the truck was new. It was towed behind a motorhome, used as a wood truck, and then it sat for years. Had my truck been properly maintained, I doubt I would be having these issues. 48 minutes ago, cruiser54 said: The biggest problem with the closed system is the crappy expansion tanks we have these days. They're junk. I learned that one the hard way this spring. Link to comment Share on other sites More sharing options...
olddude Posted July 31, 2021 Share Posted July 31, 2021 Aluminum recovery tank from Mac's Radiator Shop and a new radiator from NAPA. There is nothing like the good old Georgia summer heat. I replaced thermostats' and those mickey mouse plastic recovery tanks almost every summer until I finally replaced the tank and radiator that was years ago. Link to comment Share on other sites More sharing options...
Jeep Driver Posted August 1, 2021 Share Posted August 1, 2021 4 hours ago, 89 MJ said: , I doubt I would be having these issues. It's 32 years old, yes you would. Link to comment Share on other sites More sharing options...
watchamakalit Posted August 1, 2021 Share Posted August 1, 2021 25 minutes ago, Jeep Driver said: It's 32 years old, yes you would. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted August 1, 2021 Share Posted August 1, 2021 8 hours ago, silvertwinkiehobo said: I honestly don't think you need a hifalutin', high-cost radiator, but I do think you need a clean and thick cross-section one. But, it is your truck. Mishimoto is not a “high-end” radiator. It’s a solid unit built the way it should be and better than what you can get at the auto parts stores for sure. And the number one thing, it’s not some cheap multi core aluminum knock of radiator that isn’t worth the aluminum they used to build it. After you fight heating issues over and over and literally chase your own tail trying every “fix” and throwing a lot of money at the issue, a $400 radiator is nothing. I have personally discovered the hard way that most of cooling system “upgrades” are a gimmick. The Mishimoto is not. Next step above a mishimoto would be a Novak imho. ColdCase may merit a strong look as well. The old 3” core Griffith JeepSpeed radiator was probably the best core out there. I will say though, that mishimoto can handle quiet a beating. And the lifetime warranty is pretty sweet Link to comment Share on other sites More sharing options...
