howeitsdone Posted May 28, 2022 Author Share Posted May 28, 2022 Joined the 300k club on the way to Moab last night! Fingers crossed from here on out... Link to comment Share on other sites More sharing options...
Pete M Posted May 29, 2022 Share Posted May 29, 2022 sweet! time to change your entry in the engine mileage thread. Link to comment Share on other sites More sharing options...
howeitsdone Posted May 31, 2022 Author Share Posted May 31, 2022 Closing out the weekend with more projects! Link to comment Share on other sites More sharing options...
howeitsdone Posted June 4, 2022 Author Share Posted June 4, 2022 Got the Reflectix for the topper about 90% laid down tonight. Carpet will be next. Link to comment Share on other sites More sharing options...
howeitsdone Posted June 11, 2022 Author Share Posted June 11, 2022 Got an absolute score today! Won’t shift into 5th so I’ll need to do some digging and possible rebuilding. Now to decide wether or not to swap input shafts on the tc or just find one… Those snap rings are a pita. Link to comment Share on other sites More sharing options...
howeitsdone Posted June 12, 2022 Author Share Posted June 12, 2022 Aaaand just realized it's an ax4... I didn't do the proper research and investigating when I purchased. It was listed as an ax-15. Fortunately I only paid $100 (+$100 in gas) so not a total loss, but enough to be crowned stupid for the week. Link to comment Share on other sites More sharing options...
eaglescout526 Posted June 12, 2022 Share Posted June 12, 2022 Oooooo I might be interested in the clutch parts. Link to comment Share on other sites More sharing options...
howeitsdone Posted June 12, 2022 Author Share Posted June 12, 2022 9 hours ago, eaglescout526 said: Oooooo I might be interested in the clutch parts. As of right now it’s a $200 paper weight. Let me know if you need anything. Link to comment Share on other sites More sharing options...
Pete M Posted June 24, 2022 Share Posted June 24, 2022 I see an external slave. it's not completely worthless. Link to comment Share on other sites More sharing options...
howeitsdone Posted June 30, 2022 Author Share Posted June 30, 2022 Well, been working on the topper/camp setup a bit. Slow progress, but moving. Last piece of the topper is the trimlok that I don't want to install, but has to be done. Still a ways to go for the bed portion such as drawer, shelving, etc... but we're getting there. Opted not to paint the topper. It needs some fiberglass work in a few spots and I don't want to spend the money polishing a turd just to fix it later on. Link to comment Share on other sites More sharing options...
howeitsdone Posted July 9, 2022 Author Share Posted July 9, 2022 The Comanche Camper has been getting some work done. Got the skeleton of the bed & storage done. Then added some power. Lots more to do, but I'm currently writing this from dispersed BLM in the Uintas, so clearly it's working lol. Link to comment Share on other sites More sharing options...
Pete M Posted July 14, 2022 Share Posted July 14, 2022 this is what I want to do to with my MJ trailer eventually. following! Link to comment Share on other sites More sharing options...
howeitsdone Posted July 21, 2022 Author Share Posted July 21, 2022 Well, uhhh I believe these are supposed to be a part of a TC output shaft bearing.... They were hanging out on my garage floor. Which is perplexing seeing how it's sealed... Unless came from somewhere else that I'm not thinking of. They were dry which also was odd. I've got a metal-to-metal type sound above ~2.4k RPM that started 2 days ago. Haven't driven since the noise. My FT 4wd grinds nicely to compliment. Perfect timing as I am supposed to be driving it up to Yellowstone next week Link to comment Share on other sites More sharing options...
howeitsdone Posted July 21, 2022 Author Share Posted July 21, 2022 And appears the ATF was looking to escape as well. Lovely. Link to comment Share on other sites More sharing options...
howeitsdone Posted July 21, 2022 Author Share Posted July 21, 2022 Dropped the 242 tonight and will replace with the 231 tomorrow and see if there is a difference. Video if anyone sees this. This is in FT 4wd. Link to comment Share on other sites More sharing options...
howeitsdone Posted July 22, 2022 Author Share Posted July 22, 2022 Put the 231 in tonight and drove it around the block. I've got really bad driveline vibration now. I know the TC is good because I was using it in Nov/Dec. So I'm stumped. Probably going to ask around. Link to comment Share on other sites More sharing options...
howeitsdone Posted July 22, 2022 Author Share Posted July 22, 2022 Determined the vibration is from the motor. I bet I stressed the mounts just enough when lowering the trans to swap the TC out. The front of the motor shakes quite a bit and the rear is pretty stable. I can only assume it's because the trans mount provides enough support. I've also got two trans mount bolts that just spin once tightened which is most likely causing my high-torque buckling issue. The trans isn't tight enough to the mount (which needs to be replaced, but for ~$80 I might save that toward an ax15). I should have taken teflon and wrapped the bolts but only just now thought of that lol. Link to comment Share on other sites More sharing options...
scguy Posted July 23, 2022 Share Posted July 23, 2022 23 hours ago, howeitsdone said: Determined the vibration is from the motor. I bet I stressed the mounts just enough when lowering the trans to swap the TC out. The front of the motor shakes quite a bit and the rear is pretty stable. I can only assume it's because the trans mount provides enough support. I've also got two trans mount bolts that just spin once tightened which is most likely causing my high-torque buckling issue. The trans isn't tight enough to the mount (which needs to be replaced, but for ~$80 I might save that toward an ax15). I should have taken teflon and wrapped the bolts but only just now thought of that lol. The looseness at the mount could allow the drivetrain to lift under torque and create driveline vibrations. Make sure to double check your crank balancer for coming apart also. Link to comment Share on other sites More sharing options...
howeitsdone Posted July 28, 2022 Author Share Posted July 28, 2022 On 7/23/2022 at 11:46 AM, scguy said: The looseness at the mount could allow the drivetrain to lift under torque and create driveline vibrations. Make sure to double check your crank balancer for coming apart also. Thanks. All good on those fronts. I just ripped the mount when servicing. The vibration is purely from the motor. On the other hand. I no longer have the weird high torque issue with the TC/Trans banging around. Switching back to the 231 seemed to have solved that. Whether it's from installation process or the TC itself, I'm not sure, but it works! I have been climbing tough mountains in 1st and 2nd gear with absolutely no issues at all. I'm actually really impressed with the BA10/5 because it performs so well compared to what everyone says. It's nice when everything (except motor vibrations) works! Link to comment Share on other sites More sharing options...
Pete M Posted July 31, 2022 Share Posted July 31, 2022 nothing wrong with a happy Peugeot. and if it works fine now, it should continue to do so if you're nice to it. Link to comment Share on other sites More sharing options...
howeitsdone Posted August 6, 2022 Author Share Posted August 6, 2022 Bought motor mounts but looks like I'll have to return. They gave me a one piece and it looks like I need a two-piece. Link to comment Share on other sites More sharing options...
Pete M Posted August 7, 2022 Share Posted August 7, 2022 what's a "2 piece" motor mount? I hope that was a funny. Link to comment Share on other sites More sharing options...
howeitsdone Posted August 12, 2022 Author Share Posted August 12, 2022 WJ Brake Booster parts came in today. Check valve and boot need to be replaced. Plus I bought some line to bend my own since it didn't come with the flexible WJ lines. Otherwise got both for a great deal and will install as soon as the WK2 is done in the garage which should be sometime this weekend. Link to comment Share on other sites More sharing options...
Diesel_Zuk Posted August 14, 2022 Share Posted August 14, 2022 On 5/7/2022 at 7:37 PM, howeitsdone said: The truck is also going through a "transition" of some sort... Did you happen to buy that header panel from a pull it yourself yard, off of an older blue XJ? Link to comment Share on other sites More sharing options...
howeitsdone Posted August 14, 2022 Author Share Posted August 14, 2022 19 minutes ago, Diesel_Zuk said: Did you happen to buy that header panel from a pull it yourself yard, off of an older blue XJ? I bought the Main panel from a JY down in Grand Junction off a white XJ. All of the trim pieces were bought online. Link to comment Share on other sites More sharing options...
