Scottybbythesea Posted June 17, 2021 Posted June 17, 2021 Gave up on locating a factory SWB roll bar Found a late 80s Toyota rollbar on Craigslist. It’s about 8” too narrow and 1” too short. Ordered up some 3” tube to make up the difference. Then I cut the down tubes and and plan on swapping them left to right so they slant inboard, instead of outboard. I’ll post up more pics as I make progress. Using some frame mounts I bought from a member here.
Pete M Posted June 17, 2021 Posted June 17, 2021 this is a smart move. grab what you can find and make it work.
Scottybbythesea Posted June 25, 2021 Author Posted June 25, 2021 Keep in mind two things. 1) I’m not making this to save myself in the event of an actual rollover B) I’m not a welder but I own a $99 Harbor Freight welder and a grinder. And some bondo. Some progress. Cut the bar all up and measured and test fit and measured and measured and guessed a little and cut, inserted and welded, ground, and bondo-ed. Still have a lot more work to do.
Scottybbythesea Posted June 29, 2021 Author Posted June 29, 2021 Widened the bar 7 3/8”. It’s getting there.
Kaiserman Posted June 30, 2021 Posted June 30, 2021 Looking good so far. Can't beat using what you have on hand or can scrounge up cheap.
Scottybbythesea Posted August 10, 2021 Author Posted August 10, 2021 Done! Daylighters going on after lunch
MiNi Beast Posted August 10, 2021 Posted August 10, 2021 I love it!!! You did a damn good job. And doing it yourself is a great accomplishment. Thank you for the example of aspirational accomplishment. Where there's a will, there will be way!
Scottybbythesea Posted August 10, 2021 Author Posted August 10, 2021 Thanks for the encouragement, I appreciate it. Here’s the finished project.
DonM Posted August 14, 2021 Posted August 14, 2021 Darn that looks good. Not just the bar, the whole truck.
