Carter’s 1986 AMC Eagle (plus Eagle axle swap and other tech info)
Going back together. I’m almost as far as I can go before needing to pull the engine out of the Eagle. The Eagle already has a brand new water pump that I need to use and I’ll need the Eagle specific oil pan.
  • Replies 267
4 hours ago, neohic said:
Anything special or just freshened up?
Just an aluminum valve cover and new gaskets. The rod bearings looked brand new in it. I suspect it’s around 80,000 miles. Eventually I’d like to stick a cam in it and get a 4.0 head.
10 hours ago, Eagle_SX4 said:
You might want to consider putting in a new oil pump while it is on the stand. Also a new rear main. Just for peace of mind. I know first hand how difficult it is to pull the oil pan off that engine while it is in the car.
Already planned. Along with a new timing chain because the 258s had a plastic cam gear.
  • 4 weeks later...
10 hours ago, neohic said:
Looks great!
Thank you!
4 hours ago, acfortier said:
Nice color. That's what I painted my AMC 360 when I got a reman for my J10.
It is a great color. Looked even better when I sanded the top of the valve cover and got it sitting in the car. Funnily enough, it’s not AMC blue. It’s a Mitsubishi color that’s almost the same, it’s just got a ton of metallic.
IMG_5753.jpeg.265a225a317f187942b63ab3ec9907ed.jpegIMG_5754.jpeg.686fbe61bb252b4f026d6c93e80a4839.jpeg
14 hours ago, fiatslug87 said:
What’s the Mitsubishi color called?
I don’t remember. I’ll have to get a picture of the can at home. It also might be in my Comanche build thread sometime in the later half of 2020.
Took me long enough to get a pic, but here’s the info. A pint will do 1 engine. It’s an acrylic enamel single stage. Color is Kawa Semi Blue, #928250.
I’ve put some miles on the new engine. It’s way smoother and more powerful.
I don't think that I mentioned it anywhere yet in this thread, but ever since I got the car back, the aluminum power steering pump bracket was broken. Some fellow Wisconsin AMC collectors sent me another one, which was perfect timing because it came as I was doing the engine. It was actually from the guy who got me in touch with the person I got the driver seat and some other interior pieces from. They've got a YouTube channel in case you don't get enough AMC content here on CC.
https://youtube.com/@americanmadeclassics?si=0EGLg9GocDnzUOBk
Here's something neat for the other Eagle owners on here to check out. A list of options with prices for each model year. Mine cost $13,661 new.
Google Sheets link for it:
https://docs.google.com/spreadsheets/d/1_P_Nyd2ndpqctnW-18LTyCz4Lm12SDOVKo7pJRrzpos/edit?usp=sharing
Images:
262915030_Screenshot2024-09-21183930.png.0e0ffd05f844214920a920c9b542015b.png1905310345_Screenshot2024-09-21183946.png.ac0d5650187a29aeb2cdca7d7b5c9c8c.png1186625852_Screenshot2024-09-21183959.png.f8ea40c1f16f69318521afb3aea2efdc.png1555423538_Screenshot2024-09-21184015.png.e26e241724aa1fd5f9e6d642e9efeabe.png
PDF For Downloading:
AMC Eagle Price Guide - Google Sheets.pdf
I should have added that I don't think all of that information is completely accurate, as my car had 2.35 gears in the front diff and its an 86. Also, the pictures are blurry, that's why I have the other two methods of viewing it.
  • 2 months later...
More parts on the way. This time it’s a partial set of sill
And here is why I needed them. Super corroded to the point of having holes. Actually, only needed the one for the drivers door, but spares don’t hurt.
  • 89 MJ changed the title to Carter’s 1986 AMC Eagle (plus Eagle axle swap and other tech info)
