Kenda Klever, Pizza Cutters
Thanks Pete!
Thanks 89MJ. IMHO, pizza cutter tires look much better under a truck and a non pizza cutter tire is best suited for a XJ type vehicle.
Additionally, when I see tires that stick way the F out, past the sheet metal, it reminds me of a RC car... lol!
Yes Tex06, spacers/adapters. I purchased them from a heavy equipment shop. No average aftermarket peddler had 2 inch thick, hubcentric spacers/adapters.
On 4/5/2021 at 11:35 AM, RestoringNV said:
Kenda Klever 35x10.50R17, mounted on 2018 Wrangler Rubicon Recon Wheels.
Nicely tucked in under!
What is the actual height of that tire mounted and under the weight of the truck?
Looking around, there are some tires in the 33-35" range that are "skinny".
255/80R17 are about a 33.5x10.0
275/70R17 are about a 32.5x10.8
275/80R17 are about a 35x10.8
285/70R17 are about a 33x11.2
285/75R17 are about a 34.5x11.2
Pete: go out and fetch you a set of Kenda Klevers ;)
ghetdjc320: the axles under my MJ are XJ axles, with 4.56 yukon gears and a Spartan locker out back.
I can get you the additional information this evening.
And as promised tires are 34 inches tall, underneath the trucks weight!
Andy in PA: Actual tire size 35x10.50R17.
Jesse J: thank you kindly.
Wahoo Steeler: while that is true, it has been my finding, that BFG KO2 tires tread profile, is too flat faced and cause a pickup platformed vehicle to be squirrelly on wet surfaces. BFG KO2's are much better for an SUV platformed vehicle, due to improved and more even weight distribution.
derf: indeed there are, I am running 285/75R16's on my 05 TJR.
