I have a question about the windshield on my 88 Comanche. It is leaking and I am wondering about the seal or gasket. Where can I get that gasket? And obviously a glass shop should be able to install it shouldn’t they. Hope this isn’t to dumb of a question
thanks for any help
David
That’s good to know I did not know that. I do see the trim on the outside and as far as the windshield goes. Is there any specific windshield I need to look for? or will a glass shop be able to decide that for me
I ordered a rubber gasket for a cherokee and glass for a cherokee and the shop installed both. If they search mj parts they won't find any. At least my shop couldnt
8 hours ago, jdog said:
84-01 are all the same
That is not true, as far as gaskets are concerned.  The 97+ gaskets frunction as the trim, eliminating the bright metal around the windshield.
in my book, this an improvement, since the metal trim will vibrate/rub and take the paint off the body, leading to rust.
And, in my case, make an annoying clak-ca-clak-clak noise at highway speeds.
but the glass itself is the same iirc, the trim is different and annoying
