so it turned out to be a combination of things
1st is the fuse box terminal block was broken from the one that feeds it. set up a jumper wire to feed the fuse.
2nd was a bad turn signal switch that wasn't working correctly and screwing with the brake lights
3rd was bad sockets in the front
4th ??
oh yeah and some bulbs.
but I give credit to @Jesse J he's doing great at figuring it out and understanding my ramblings.
  • Replies 155
Yeah got the brake lights working again just barely. front drivers side turn signal isn't working dead circuit on the switch. need to figure out the brights and then then we are ready to go. huge thanks to @jdog
On 2/3/2021 at 2:05 PM, Jesse J said:
uggh I hate electrical work. it's so finicky
and you stuck thru 2 days of it
