Pete M Posted January 12, 2021 Author Share Posted January 12, 2021 I've got an electric fan blowing on it made a huge difference over the first couple days. Link to comment Share on other sites More sharing options...
89 MJ Posted January 13, 2021 Share Posted January 13, 2021 I had to house sit for some friends. Their house is heated by wood, so I had to keep it stocked up. I thought it was pretty fun to need to always make sure there was enough wood for the day and night, and to make sure that it was always producing heat. I would consider owning a house that needs wood to heat it. Link to comment Share on other sites More sharing options...
Pete M Posted January 13, 2021 Author Share Posted January 13, 2021 forgot to prep the wood for today so that meant wandering out into the cold to the wood rack behind the barn. still learning lessons the hard way I guess. thus far I've been able to remember that the stove is hot so I guess I've got that goin' for me. Link to comment Share on other sites More sharing options...
BeatCJ Posted January 13, 2021 Share Posted January 13, 2021 Don't worry, it happens to all of us. I can remember it happening to my grandfather, too. Link to comment Share on other sites More sharing options...
Lthompson741 Posted January 13, 2021 Share Posted January 13, 2021 I heat my shop with a forced air wood burner. Mine is home-made one copied from the ones the major home improvement ones sell. It takes about an hour to get it going (I don’t leave it running 24-7). But once it’s going it will push you out of my 3 car shop. I have to open the garage door and let some of the heat out after a while. I guess thats the draw back of a home made one. I also have a electric fan on a timer that will turn on and off every 15 minutes to circulate the air around it which makes a huge difference in the garage. I burn pretty much anything, mostly seasoned oak, but have burned pine, maple etc (all seasonsed). My chimney is a 8 inch gas main that is about 1 inch thick metal, so I’m not to worried about burning thru. I also sweep the stack about twice a season. Opening the ash pan is the key to reloading for mine as well, once it’s gets roaring, no smoke in the shop. Link to comment Share on other sites More sharing options...
Pete M Posted January 14, 2021 Author Share Posted January 14, 2021 so today's experiment went sideways on me. I carefully made my layers of burnables and then stuffed the rest of the space with cardboard like I've seen guys do on youtube. but upon lighting the fire, it smoked a LOT and that smoke escaped out every door seal in the box. now the house stinks to high heaven and I had to open the windows to vent it out. I made the assumption that the box would seal in everything and that's just not the case. so tomorrow morning I'm going to make a small fire purely out of 2x4 splinters and some paper and slowly heat up the box and flue before I add more to the mix. we'll see how that goes. I might have to just bite the bullet and load up a lot of wood the night before so that the box is still warm in the morning. it's a waste of wood because it'll only warm a room that no one is in all night. hampers my ash removal too because, well, everything is hot when I push the ashes around so they fall down to the pan and that kinda sucks. oh well. it's just a matter of finding out what works best for this household. I'll get there. Link to comment Share on other sites More sharing options...
BeatCJ Posted January 14, 2021 Share Posted January 14, 2021 My fire habits will be different than yours, my woodstove is in my living room, I have a very open Livingroom, dining area/kitchen. But, assuming I'm starting from cold, I put in two wedge shaped splits in the bottom. I put one good handful of pencil split kindling at the base of the valley. Then another of larger, finger or thumb sized splits on that. Then a couple of bigger pieces on top of that. Then I fire up a propane torch, and use that to light my fire. If I set it up so the torch flames shoot out the back, the heat column goes right up my flue, and it builds a good draw pretty quickly. I used to use newspaper as my starter, about 6 sheets twisted to sticks. Getting the air to fuel density is more important with the paper. Since my stove heats my whole upstairs, I usually stoke it up at night, and damp it down so it's still going in the morning. Then it's raking coals and feeding it. Of course, my heat pump is set at 60, and the stove is keeping my granddaughters warm. My bedroom door is closed, with the window open and a fan pulling outside air in. Link to comment Share on other sites More sharing options...
Pete M Posted January 14, 2021 Author Share Posted January 14, 2021 yeah, I might have to break out the torch to accelerate the process a bit Link to comment Share on other sites More sharing options...
89 MJ Posted January 14, 2021 Share Posted January 14, 2021 Pete, go big, use an Oxy/Acetylene torch. That'll really get it going quick! Link to comment Share on other sites More sharing options...
rokinn Posted January 14, 2021 Share Posted January 14, 2021 I spent a year not that long ago living off grid (except for internet, gotta have that) at about 8500 feet in a two story (1200 sq ft) cabin. I heated the entire winter with heat from a wood stove with the temp sometimes down to -15. Getting a fire going fast in the morning was paramount. On the coldest mornings the inside temp could down to the high 30's. Best way I found to start a fire was to wrap dry pine cones (the more pitch the better} in newspaper. The number of pine cones in each couple of pages of newspaper determined by size of the cones. Do several of these. Then pile small kindling, usually chopped from the log wood I used to burn, 2x4's, etc. and then somewhat larger pieces of kindling up to one inch or so. Get this going with the flu wide open. Once that is blazing and coals are starting to develop ad in increasingly larger pieces of wood until there is a good coal base and then you can add in larger logs. Don't damp it down until it's good and hot. Link to comment Share on other sites More sharing options...
89 MJ Posted January 14, 2021 Share Posted January 14, 2021 2 minutes ago, rokinn said: I spent a year not that long ago living off grid (except for internet, gotta have that) at about 8500 feet in a two story (1200 sq ft) cabin. I heated the entire winter with heat from a wood stove with the temp sometimes down to -15. Getting a fire going fast in the morning was paramount. On the coldest mornings the inside temp could down to the high 30's. That sounds like quite the adventure. Would you mind sharing more of your experiences when you did this? Link to comment Share on other sites More sharing options...
rokinn Posted January 14, 2021 Share Posted January 14, 2021 3 hours ago, 89 MJ said: 3 hours ago, rokinn said: That sounds like quite the adventure. Would you mind sharing more of your experiences when you did this? Happy to. Might take a day or so to get to it. Link to comment Share on other sites More sharing options...
MiNi Beast Posted January 14, 2021 Share Posted January 14, 2021 i use kindling on top a firestarter log if no rush and want it faster i use little blue torch. Link to comment Share on other sites More sharing options...
watchamakalit Posted January 15, 2021 Share Posted January 15, 2021 I pride myself frequently in building one match fires. You can't cheat the basics without alot of propane. Pete look into top down fire building. It will help greatly. The key is starting the fire high in the fire box to encourage the draft to find its way up the flue not into the room. Link to comment Share on other sites More sharing options...
Pete M Posted January 15, 2021 Author Share Posted January 15, 2021 I tried a top down for the first one and it went poorly, but I've learned a lot since then and think I'm ready to revisit the concept. Link to comment Share on other sites More sharing options...
rokinn Posted January 15, 2021 Share Posted January 15, 2021 You want the draft or oxygen to move through the fuel and flame. That's why forest fires burn faster and hotter when the there is wind. Top down is slow and ineffective. Get it going and build on it. You don't need anything but dry combustible material, air flow, and a match. Sort of like the internal combustion engine. Spark, more air flow and fuel = bigger fire or...bigger explosion and and more power = more heat...just one you don't need or want to cool with a radiator. You don't need an electric fan. The one presented earlier in the thread gets the blades turning by convection from the heat generated by the stove itself. Sort of like forest fires creating their own weather phenomena. Link to comment Share on other sites More sharing options...
Pete M Posted January 15, 2021 Author Share Posted January 15, 2021 today's experiment went good! after sifting out the ash I ended up with a small amount of coals upon which I built a quick fire of crumpled paper and 2x4 splinters. cracked the ash tray and let that burn bright for a bit, then added more splinters. got a bright and blazing little fire going and that was enough to heat up the flue so I could then add bigger things without smoke escaping. Link to comment Share on other sites More sharing options...
rokinn Posted January 15, 2021 Share Posted January 15, 2021 2 hours ago, Pete M said: today's experiment went good! after sifting out the ash I ended up with a small amount of coals upon which I built a quick fire of crumpled paper and 2x4 splinters. cracked the ash tray and let that burn bright for a bit, then added more splinters. got a bright and blazing little fire going and that was enough to heat up the flue so I could then add bigger things without smoke escaping. My stove didn't have a tray for the ash so I just left the door open a crack which created a source for air flow up the chimney. Once it was going well enough I could close the door and when it was really going well I could damp it down. Mine had an after burner which was also nice. Less wasted fuel up the chimney. Link to comment Share on other sites More sharing options...
Pete M Posted January 15, 2021 Author Share Posted January 15, 2021 11 hours ago, rokinn said: You don't need an electric fan. The one presented earlier in the thread gets the blades turning by convection from the heat generated by the stove itself. Sort of like forest fires creating their own weather phenomena. If I didn't live in Georgia I'd be all about that. but I don't expect the cold weather to last for much longer. one of the benefits of being in the south. February is springtime! (but then again summer arrives in May so there's that. ) Link to comment Share on other sites More sharing options...
89 MJ Posted January 15, 2021 Share Posted January 15, 2021 3 minutes ago, Pete M said: but I don't expect the cold weather to last for much longer. one of the benefits of being in the south. February is springtime! (but then again summer arrives in May so there's that. ) I'm a little bit jealous of you whenever you say that. I love the heat, and no rust. I do like the snow, but not the cold that comes with it Link to comment Share on other sites More sharing options...
Pete M Posted January 15, 2021 Author Share Posted January 15, 2021 we just trade 4 months of staying inside because it's cold for 4 months of staying inside because it's hot. can't argue about the rustfree junkyards though. that's pretty sweet. I do NOT miss the michigan 'yards. Link to comment Share on other sites More sharing options...
Pete M Posted January 16, 2021 Author Share Posted January 16, 2021 today's lesson is write down all the steps so my half-awake brain can't forget to open the flue first. there were some coals left from yesterday and the fire flared into life a bit sooner than I actually wanted and the flue escaped my brain for a couple minutes while I tried to figure out why it was smoking so bad. Link to comment Share on other sites More sharing options...
MiNi Beast Posted January 16, 2021 Share Posted January 16, 2021 Link to comment Share on other sites More sharing options...
Mossmj13 Posted January 16, 2021 Share Posted January 16, 2021 Boils water vintage one for sale Pete Link to comment Share on other sites More sharing options...
Pete M Posted February 18, 2021 Author Share Posted February 18, 2021 it's an art and a science. I really thought I had mastered the art side of things, but the past few days I've really struggled to keep a fire going without resorting to cracking open the ash door for fresh air. it was really frustrating. so today I took the back heat shield of the stove off and sure enough, the chain connected to the internal damper had fallen off. I'm not entirely sure what that chain moves inside the bottom of the stove (there's a separate chain for the thermostat flapper), but I repaired it and today's fire is roasty-toasty so it was clearly something important. part art, part science, and this time it was a science (engineering) failure. Link to comment Share on other sites More sharing options...
