Figured I’d start a thread on this build. Coming up on the point where I’ll start making changes.
First, the patient, this is a 1991 SWB, 2wd, 2.5L that is as base as you can get.  Even had the “radio delete” option.    Purchased non-running with a best guess that it’d been off the road for a decade.  Previous owner had acquired a sport bar, but hadn’t mounted it (project for later)
the story so far.
After draining 5 gallons of varnish from the fuel tank, an acid wash, and  new filter pump and sender I was able to jump start it.
After a set of new injectors it ran on 4 cylinders.
after a new set of rockers, push-rods, and lifters I still have a tick-tick-tick in the top end.   Going to ‘fix’ that by installing a stereo.
With that I’ve been slowly acquiring bits from the u-pull to to replace broken and damaged interior bits and to eventually support conversion to 4wd.
I expect eventually to repaint the truck, keeping the Colorado Red color.   4wd conversion, and a SOA lift.   End result to be a daily driver, parts runner, and mild to moderate wheeler.
Today’s project... starting to prep to install XJ bucket seats.   Many thanks to those who’ve gone before.
Pulling the 4 bolts from the seat cushion, then the 4 to release the sliders from the frame.
Then drill out the 6 rivets holding the XJ brackets to the sliders.   And repeat.
Leaves me with two sets of sliders.   Need to clean the seats and paint the MJ brackets (new reproduction).
:laugh:
Mrs. has been cleaning seats, and some matching door cards.
Really looking forward to having a place for a center console and some cup holders.
No power steering and a manual transmission means I really need a place to put my Pepsi.
While the cleaning goes on (and I’m off between the holidays) starting to prep a new rear axle.  Ford 8.8 to replace the D35 when I do the 4x4 conversion.
And now that the paint is dry, back to working on bucket seats.
Seems somewhere in history the factory rubber floor was replaced with carpet (thank you!), but I’m guessing from an XJ as it doesn’t quite fit properly behind the seat.   Bonus however that it already has holes for the center console brackets.
Anyone need a blue bench seat?  Does appear to have a cut in the fabric (pictures below), but it certainly looks like it could/would be repairable. Also have the center seat belt that I won’t be using.
  • 1 month later...
Little exterior work today.  Set of bushwhacker flares to help cover the new tires after the 4x4 conversion happens.
Before I get chewed on about the cut-out flares... the front fenders aren’t original and they’re hail damaged.    Bed is hail damaged, smashed at both rear corners, and as big ‘ding’  in front of the rear tire.  It’s very much a 50’ truck.   I did make sure not to cut anything that would prevent me from putting the stock flares on the bed or a another set of fenders if I change my mind.
she looks good with that low COG :L:
as I've been finding out first hand with my Liberty, "mounted" is different than "driving", which is different than "wheeling".  but I just keep trimming and smashing things until the tires fit :D
I "mounted" 33x10.50-15 BFG Mud Terrains on mine. It would move without rubbing, but even the potholes in my driveway made it unhappy! That said, it wouldn't have taken much trimming to make them work. Other than the control arm issue...
Made a little headway last weekend, front axle (XJ HP D30) is in with rhe Rusty’s 4” kit, track bar, steering brace, track bar brace.   All new steering linkage and the power steering box.  That stuff was all bolt in and just time consuming getting bolts to line up.
then we started trying to hook up brakes.  The 95 XJ bootster upgrade went ok, but the master cylinder and ZJ proportioning valve took a lot longer than expected.  Somehow none of the “this is a bolt in” write ups mention the new MC having the ports on the opposite side; or their needing to be metric/bubble flare fittings vs SAE inverted double flares.   Also no mention of the booster interference with the washer res.    Not a lot to see in pictures, just a lot of running around looking for parts.
hopefully get it back running next weekend.  Just need to finish the power steering conversion and bleed the brakes.
Did a bit more today.  Had to re-flare the brake lines from the master cylinder to the ZJ Prop valve.   Hadn’t realized that the 95+ MC requires “bubble flares” at the MC rather than the SAE standard “Inverted double flare”.    Re-done, brakes bled.  Which completes the MC and DD booster upgrade.
Finished up the power steering conversion today.  All factory parts, power steering pump, steering box, pitman arm.  Did have an unpleasant surprise... the high pressure line apparently has a bleed screw port which faces directly at the accessory belt.   Beyond that it was all bolt in, just replaces the idler on the drivers side.
Brakes are bled, steering is bled.   All new linkage going down to the rebuilt D30 front axle.
Rusty’s offroad springs, track bar, steering box brace, track bar brace and a set of Rubicon Express control arms (take offs from another project).  Set of Billstien shocks and it’s standing on its own 4 feet again.
