MiNi Beast Posted December 28, 2020 Share Posted December 28, 2020 all the hardware you pull off. cps if there Link to comment Share on other sites More sharing options...
Jesse J Posted December 28, 2020 Share Posted December 28, 2020 ok cool. should i get a tachometer gauge? Link to comment Share on other sites More sharing options...
BeatCJ Posted December 28, 2020 Share Posted December 28, 2020 I am a big fan of a tach, but that's a full cluster swap. I have the stuff to swap mine, but it takes a little more than just swapping in the cluster. Sending units will also need swapped. Link to comment Share on other sites More sharing options...
Jesse J Posted December 28, 2020 Share Posted December 28, 2020 yes but i though maybe being able to see the rpms will be helpful for a manual swap. especially because I am still pretty new at manual 28 minutes ago, BeatCJ said: I am a big fan of a tach, but that's a full cluster swap. I have the stuff to swap mine, but it takes a little more than just swapping in the cluster. Sending units will also need swapped. Link to comment Share on other sites More sharing options...
BeatCJ Posted December 28, 2020 Share Posted December 28, 2020 It can be helpful. Like I said, I am going to swap a full gauge cluster into mine. My point was, depending on your gauge setup now, you will need to change other things, too. But you will learn to shift by feel/sound really quickly, so it's really not that big a deal. Link to comment Share on other sites More sharing options...
Jesse J Posted December 28, 2020 Share Posted December 28, 2020 yeah I figured i'd be fine idk I kinda like just the 2 gauges it's simple maybe a little too simple but Link to comment Share on other sites More sharing options...
BeatCJ Posted December 28, 2020 Share Posted December 28, 2020 Nope. Most everyone here likes a tach. No Worries Link to comment Share on other sites More sharing options...
jdog Posted December 28, 2020 Share Posted December 28, 2020 Just watch the year you pull out from Link to comment Share on other sites More sharing options...
Jesse J Posted December 28, 2020 Share Posted December 28, 2020 the flywheel or the tach? Link to comment Share on other sites More sharing options...
MiNi Beast Posted December 29, 2020 Share Posted December 29, 2020 the tech. 90 should still be good but you can get a standalone rpm tech. Link to comment Share on other sites More sharing options...
Pete M Posted December 29, 2020 Share Posted December 29, 2020 87-90 clusters swap directly. take care when trying to remove yours. use the junkyard cluster as practice. if you pull the cluster out too far before unclipping the speedo cable, you can cause issues with the cable. Link to comment Share on other sites More sharing options...
89 MJ Posted December 29, 2020 Share Posted December 29, 2020 7 hours ago, Jesse J said: yes but i though maybe being able to see the rpms will be helpful for a manual swap. especially because I am still pretty new at manual Nah, get it if it’s cheap and works, but its not needed. My blue truck doesn’t have a tach and I don’t need one. You will have a natural feeling when iou need to shift. Link to comment Share on other sites More sharing options...
Jesse J Posted December 29, 2020 Share Posted December 29, 2020 k I will look at it Link to comment Share on other sites More sharing options...
MiNi Beast Posted December 29, 2020 Share Posted December 29, 2020 take a pic then you can always look at it. Link to comment Share on other sites More sharing options...
jdog Posted March 16, 2021 Share Posted March 16, 2021 Selling Dealer: D'AMBROSIO CHRYSLER JEEP Salt Lake City, UT Link to comment Share on other sites More sharing options...
