MiNi Beast Posted December 28, 2020 Posted December 28, 2020 all the hardware you pull off. cps if there
BeatCJ Posted December 28, 2020 Posted December 28, 2020 I am a big fan of a tach, but that's a full cluster swap. I have the stuff to swap mine, but it takes a little more than just swapping in the cluster. Sending units will also need swapped.
Jesse J Posted December 28, 2020 Posted December 28, 2020 yes but i though maybe being able to see the rpms will be helpful for a manual swap. especially because I am still pretty new at manual 28 minutes ago, BeatCJ said: I am a big fan of a tach, but that's a full cluster swap. I have the stuff to swap mine, but it takes a little more than just swapping in the cluster. Sending units will also need swapped.
BeatCJ Posted December 28, 2020 Posted December 28, 2020 It can be helpful. Like I said, I am going to swap a full gauge cluster into mine. My point was, depending on your gauge setup now, you will need to change other things, too. But you will learn to shift by feel/sound really quickly, so it's really not that big a deal.
Jesse J Posted December 28, 2020 Posted December 28, 2020 yeah I figured i'd be fine idk I kinda like just the 2 gauges it's simple maybe a little too simple but
BeatCJ Posted December 28, 2020 Posted December 28, 2020 Nope. Most everyone here likes a tach. No Worries
MiNi Beast Posted December 29, 2020 Posted December 29, 2020 the tech. 90 should still be good but you can get a standalone rpm tech.
Pete M Posted December 29, 2020 Posted December 29, 2020 87-90 clusters swap directly. take care when trying to remove yours. use the junkyard cluster as practice. if you pull the cluster out too far before unclipping the speedo cable, you can cause issues with the cable.
89 MJ Posted December 29, 2020 Posted December 29, 2020 7 hours ago, Jesse J said: yes but i though maybe being able to see the rpms will be helpful for a manual swap. especially because I am still pretty new at manual Nah, get it if it’s cheap and works, but its not needed. My blue truck doesn’t have a tach and I don’t need one. You will have a natural feeling when iou need to shift.
MiNi Beast Posted December 29, 2020 Posted December 29, 2020 take a pic then you can always look at it.
jdog Posted March 16, 2021 Posted March 16, 2021 Selling Dealer: D'AMBROSIO CHRYSLER JEEP Salt Lake City, UT
