AMC 20
derf
Found at a salvage yard under an 86 Comanche.  The speedo was shot so there's no telling what the true mileage is.
I will get more pictures tomorrow and post them, including taking off the cover and verifying the gear ratio and condition of the gears.
I'm going to toss out $500 as an initial asking price but may adjust that based on what I find.  And cash always talks to me so it's always "or best offer".
The spring plates will come with it.  One U-bolt didn't survive extraction and we left the other 3.  Parking brake cables were extracted intact and come with the axle.  They couldn't be tested.
Axle is located in Castle Rock, CO 80108, just south of Denver.  Local pickup preferred.  I might be able to ship it on your dime.
2 hours ago, 89 MJ said:
In case anyone doesn’t know, this rear axle has very comparable strength to an MJ D44, but is rarer as it is 86 only.
AMC 20’s arent really all that rare. They were found in many other Jeep vehicles like CJ’s, Wagoneers etc. Decent aftermarket support but not nearly as much as a 44. They may be less common in MJ’s but 86 was the highest production year for MJs also.
You got me curious.
One of the [CENSORED] torx bolts didn't want to come out so that will be an adventure.
But I counted teeth.  It is indeed a 4.10 axle (41/10) with an open differential.
Yes, I should have specified more. I didn’t know that 86 was the highest production year for the MJ. Interesting.
10 hours ago, derf said:
You got me curious.
you could have simply rotated the axle shaft and counted pinion rotations. :(
Very true but the cj 20 axle was a split shaft design from what ive read. Where mj 20s were a solid shaft design making it stronger.
Ive also not seen a lot of 20 axles. A few cjs but nothing ive actually seen in person. Ive seen far more 44 axles. Even under mjs
The V8 Wagoneers were also solid shaft amc 20’s, seen lots of the personally. Was looking for a Dana 44 rear in one but all I found were 20’s. CJ’ with V8s and many V8 amc vehicle had them too. Not bad axles but not unicorns. It is odd that they went from an amc 20 to a Dana 35. That’s a pretty big strength gap there.
Archived
