Knock sensor question
  • 89 MJ changed the title to Knock sensor question
My read of the renix fuel injection manual would lead me to believe that you could leave it disconnected.
If a knock generates an electrical signal which would then cause the ECU to retard timing for 15-ish seconds, then return it to normal....
If it's not connected, then it can't send a signal to retard the timing...right?
Maybe some smarter guys will confirm or shoot me down.
This is what we were thinking.
13 minutes ago, Ωhm said:
True
So it would be fine disconnected?
tap and screw the sensor. the renix system needs it to prevent the knock, knock is bad for the engine in the long term you know, also your fuel economy will suffer as the knock sensor is used to fine tune the timing
Thank you.
11 hours ago, eaglescout526 said:
Theres three Mopar knock sensors left.
What do one of those go for? I see the "good" aftermarket ones a $50 and would love a MOPAR one if the prices are semi-close.
