What would cause this...?
Seems like my headlight switch? When I turned it off the fog went away, could this mean I have a short or possible fire soon?
I've already completed the relay harness upgrade.
Are you saying you turned off your headlights with the fogs on? If so that’s completely normal.
Nevermind i see it now. Yeah that’s probably not a good sigh and that you might need to start digging.
What do you see?  That's the way mine work. Turn off your headlights and the fogs turn off. What am I missing here.
he's talking about the haze on the cluster plastic  :L:
I’d say headlight switch is the most likely culprit. When I was junkyard shopping for a new connector after mine caught fire, every single one I could find was melted. But the lighting in the cluster could also be an issue.
Got a new switch at o'reilly's since I work there. (For the discounts).
P/N DS220 for anyone looking for one. Brand is Standard Ignition (Not a typical stock item.)
Waiting for part to come in then ill rip into the dash to see what I see... I'll report findings for curious people.
Currently using a different vehicle for night driving. Refuse to use the switch till i know for sure. I'm not burning my just rebuilt truck to the ground....
To me that looks like condensation rather than smoke.  Maybe... there is some moisture that has gotten inside the instrument cluster, somehow.  With the lights on, the gauge lights heat up that moisture and cause the condensation you see inside the gauge cluster.  Turn off the lights, heat goes away, condensation clears.  Has it rained recently in your neck of the woods?  Do you have water leaks in the cab, from the windshield seal or door seals?  Have you cleaned the interior with a wet cloth, and gotten water behind the dash or gauge cluster?
Yes rain, no on the windshield recently replaced, was garaged for 9months prior to replacement. New doors & window seals.
Only water getting in currently is pass side from a wire plug hole i haven't managed to source yet and driver cab vent pillar I believe.
Also the gauge cluster was torn down and reassembled with a small bead of sealant so, not sure how moisture would get inside it. Not saying its impossible... water finds a way...
So, I got the old one replaced. Didn't look bad in there, there was some corrosion buildup starting on the internal of the switch itself. Lots fell out when I got it out.
Despite its rather good condition.  I replaced it anyway since these things have a tendency to burn the truck to the ground out of nowhere...
  • 1 month later...
