Pete M Posted July 27, 2020 Share Posted July 27, 2020 and don't say "Everything" as I can't afford to do that. But there's a 2.5 with AC in a junkyard near me and I really don't remember what all is unobtainium. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted July 27, 2020 Share Posted July 27, 2020 the AC mounting brackets, the idle control for the throttle body, I'm not sure what else other than the fuel pump assy, and normal MJ stuff. Link to comment Share on other sites More sharing options...
Pete M Posted July 27, 2020 Author Share Posted July 27, 2020 sorry, forgot to mention it's an XJ, so I'm limited to XJ things. Link to comment Share on other sites More sharing options...
eaglescout526 Posted July 27, 2020 Share Posted July 27, 2020 Air cleaner up to the bonnet. The hose is kinda irreplaceable if it falls apart and the air box is different from the Renix 4.0L. Valve cover if it sports the AMC logo on it. Otherwise dasbulliwagen covered the other stuff unless you pull the whole exhaust/intake. Optional can be the PS stuff. Link to comment Share on other sites More sharing options...
Pete M Posted July 27, 2020 Author Share Posted July 27, 2020 is the AC compressor unique or just the brackets? how about the AC hoses? are they available aftermarket? Link to comment Share on other sites More sharing options...
eaglescout526 Posted July 27, 2020 Share Posted July 27, 2020 Brackets are unique, hoses kinda are unique as I have seen there doesnt seem to be a consistent hose used, but they can easily be remade(by o'reillys or whom ever is preferred) if someone had them in their possession. Compressor is not unique. Link to comment Share on other sites More sharing options...
eaglescout526 Posted July 27, 2020 Share Posted July 27, 2020 I forgot. The coolant overflow tank is unique, but the cap is hard to find despite the bottle being made in the aftermarket. Link to comment Share on other sites More sharing options...
SoCalManche Posted July 27, 2020 Share Posted July 27, 2020 That's good to know...I need one! Link to comment Share on other sites More sharing options...
mjeff87 Posted July 27, 2020 Share Posted July 27, 2020 The TBI and the wiring clip/harness that attaches to it, along with the idle stepper motor.....or just grab the whole TBI. Power steering pump has a remote reservoir, A/C bracketry as mentioned, and the MAF sensor (if you can get it out of the manifold without breaking it). I've mentioned it before, but I have a complete 2.5 long block sitting up in a barn in PA that I picked up from a NAXJA guy (Danno) several years ago. It's free for anyone that can take/use it, but the only caveat is you have to go pick it up. Came out of a clean running 87 MJ when he transplanted a V8 into it. Probably should change the oil in it before firing it up though Link to comment Share on other sites More sharing options...
Eagle Posted July 27, 2020 Share Posted July 27, 2020 Power steering pump, reservoir, and brackets. Air cleaner box. Distributor. Throttle body. Link to comment Share on other sites More sharing options...
Pete M Posted July 28, 2020 Author Share Posted July 28, 2020 I'm back. managed to snag the entire throttle body assembly, manifold sensors, airbox top, airbox ducts, AC bracket (one bolt hole is broken off but I have it), distributor, and some other little things. they wanted far more for the pump than I could pay pump reservoir was broken bottom of airbox was broken coolant tank and cap were both broken tried to charge me a total of 36 bucks for a cheap old air horn assembly. I politely declined. Noticed on this trip that there are 3" spacer blocks for the rear lift and bolt/clamp spreader things on the front coils. eek. Link to comment Share on other sites More sharing options...
yxmj Posted July 28, 2020 Share Posted July 28, 2020 I can't see from the picture.....but does it have an under hood light? I had an 87 Larado that had one that was detachable with an auto-wind cord so it worked like a trouble light Link to comment Share on other sites More sharing options...
Pete M Posted July 28, 2020 Author Share Posted July 28, 2020 nope. I would have grabbed it if it did. Link to comment Share on other sites More sharing options...
OldSch88L Posted August 9, 2020 Share Posted August 9, 2020 I don't know about you, but I've never seen a 4 banger XJ or MJ at the junkyard yet, so I would have grabbed that radiator, being exclusive to that body style. Engine parts don't worry me since you can also get some from YJs. Link to comment Share on other sites More sharing options...
schardein Posted August 9, 2020 Share Posted August 9, 2020 Pete, good job on saving some of those hard to find parts. And, reminder that the 4cyls often have more desirable axle gear ratios for those going with bigger tires. Link to comment Share on other sites More sharing options...
