Is this safe/normal?
ftpiercecracker1
Well the cardboard on its own is unlikely to spontaneously combust... you’d have much bigger problems if your engine bay got hot enough for that to happen. I’d be more concerned about it soaking up oily ooze and turning into a big candle if something else were to catch fire under there.
It would probably dampen some sound, if that was a concern of yours. I’ve seen similar things done for sound deadening in dorm rooms or rental apartments where you’re not allowed to do much to them – but that doesn’t make me want it in my engine bay.
Yeah I can't imagine it would go up in flames under normal circumstances but I wouldn't want to cram combustible materials in my engine bay either.  If something were to happen it's way more likely to go up.
I'd rather get some form of heat reflective sound deadening mat or something else that isn't quite so flammable.
