WahooSteeler Posted May 20, 2020 Share Posted May 20, 2020 Does it matter what year Cherokee the rubber windshield surround molding is from? Link to comment Share on other sites More sharing options...
ghetdjc320 Posted May 20, 2020 Share Posted May 20, 2020 When I had my windshield installed i had them install the newer style 97+ gasket instead of that metal trim. Looks really good imho Link to comment Share on other sites More sharing options...
WahooSteeler Posted May 20, 2020 Author Share Posted May 20, 2020 9 minutes ago, ghetdjc320 said: .... i had them install the newer style 97+ gasket instead of that metal trim Yeah, I'm trying to confirm if they are the same for all XJ years once they switched over to the rubber gasket/molding. I believe that was in '94 but want to confirm. Found a brand new one on FB for cheap. I have the "chrome" trim and I like the way it looks, but unfortunately it does nothing to keep the elements out at all. Link to comment Share on other sites More sharing options...
jdog Posted May 20, 2020 Share Posted May 20, 2020 I think the switch was with the body style change, so 97 Link to comment Share on other sites More sharing options...
Limeyjeeper Posted May 20, 2020 Share Posted May 20, 2020 I have a 91 and fitted a new Mopar one with no issues. Link to comment Share on other sites More sharing options...
WahooSteeler Posted May 20, 2020 Author Share Posted May 20, 2020 Laughing at myself because many times I will post a question basically being lazy and looking for the quick answer instead of researching on my own. Then an idea will pop in my head on how to quickly find the answer. I jumped on FB marketplace and searched XJ's starting with 1993 and sure enough there are plenty of pre-'97s with the rubber gasket so even if some of them had metal trim and replaced with rubber, it seems to be good from at least '94 on. Link to comment Share on other sites More sharing options...
krustyballer16 Posted May 20, 2020 Share Posted May 20, 2020 If you're having a glass place put it in, Just be safe and tell them its a 98 xj. Won't matter once the truck is there. Don't explain to them anything. It'll confuse them and they'll argue and maybe refuse to even do it with different rubber...Sent from my SM-G973U using Tapatalk Link to comment Share on other sites More sharing options...
ghetdjc320 Posted May 20, 2020 Share Posted May 20, 2020 53 minutes ago, krustyballer16 said: If you're having a glass place put it in, Just be safe and tell them its a 98 xj. Won't matter once the truck is there. Don't explain to them anything. It'll confuse them and they'll argue and maybe refuse to even do it with different rubber... Sent from my SM-G973U using Tapatalk Agreed, that keeps it simple Link to comment Share on other sites More sharing options...
Wounded_Fighter Posted May 20, 2020 Share Posted May 20, 2020 Do you need to cut the metal retainer tabs out if you had the tabs for metal trim? Link to comment Share on other sites More sharing options...
JMO413 Posted May 20, 2020 Share Posted May 20, 2020 1 hour ago, Wounded_Fighter said: Do you need to cut the metal retainer tabs out if you had the tabs for metal trim? No need they can stay. Link to comment Share on other sites More sharing options...
AZJeff Posted May 21, 2020 Share Posted May 21, 2020 On 5/20/2020 at 7:29 AM, Wounded_Fighter said: Do you need to cut the metal retainer tabs out if you had the tabs for metal trim? No need to take the metal studs off that are welded to the frame around the windshield, but I WOULD remove the little clips, especially if they are the steel kind. They have a tendency to cause rust, even when they are not holding anything down. I am assuming you are having a auto glass shop put the new gasket (molding) in at the same time as installing the windshield itself, because the rubber fits over the edge of the glass prior to being adhesively bonded to the window opening. Link to comment Share on other sites More sharing options...
Wounded_Fighter Posted May 22, 2020 Share Posted May 22, 2020 15 hours ago, AZJeff said: No need to take the metal studs off that are welded to the frame around the windshield, but I WOULD remove the little clips, especially if they are the steel kind. They have a tendency to cause rust, even when they are not holding anything down. I am assuming you are having a auto glass shop put the new gasket (molding) in at the same time as installing the windshield itself, because the rubber fits over the edge of the glass prior to being adhesively bonded to the window opening. Yeah I'm going to have a shop do it. my truck had the plastic clips. I had the glass removed so I can do some paint if need be. Link to comment Share on other sites More sharing options...
olddude Posted May 22, 2020 Share Posted May 22, 2020 Picture of 99xj windshield installed on 89 mj note; studs were not removed. Link to comment Share on other sites More sharing options...
