Door lock cylinder
Hello,
I am trying to replace the Door lock cylinder on my 88. I tried Autozone, Napa, & RockAuto. They all have the generic cylinder that doesn’t seem to work. Does anybody know where I can get a cylinder that does work?
8 hours ago, jdog said:
https://www.quadratec.com/p/omix-ada/door-lock-cylinder-kit-76-90-jeep-cj-cherokee-xj-wrangler-yj
Or you can use the newer lock style with the double-sided key, just be careful as not all are the same size,
If you do make sure you grab the lever on the back of the lock as it is completely different. I am struggling with that right now. I bought some (90+ locks thinking I could transfer the levers over from a pre 90 cylinder. No dice. Now I am on the hunt for some old 91 locks so I can grab the levers. In 93 the lock changed again so the 91 key won't work with a 93 - 96 they are fatter. None of the 91+ locks come with a lever attached. Omix don't make a 91+ lock assembly. The 93 plus locks are available but you can't use them either with a pre 90 lever. So it is really hard to upgrade from a single sided to double sided key setup. Ignition locks are much easier. Pretty much  interchangeable.
I went to 4WP store here in Vegas and ordered a lock set from Crown. The picture showed the same lock that I have, with the lever. It will get here in about a week and half. I'll let you know how it turns out.
Just for future reference for somebody. Pre 91 lock cylinder Part No  83505067 Black J8122874 Chrome. 91-92 lock cylinder 4637581 1993 4730931. Pre 90 cylinder kit comes with lever. 91-93 does not.
Pre 91 lock on the left 91-92 lock on the right. 91 cylinder is much thinner, smaller lever and double sided key.
23 minutes ago, Chargum85 said:
I got a bunch of cylinders from the junkyard and am going to key them all to match my ignition cylinder.  Re-keying shouldn't be too tough.
A locksmith told me that won't work. The ignition is a 6-bit lock (6 tumblers), and the door cylinders are 5-bit. If that's correct (and I have no reason to doubt him), what you want to do is impossible.
I swapped in a 91+ column with the newer "Chrysler" key that matches the newer door keys.  Sorry, should have mentioned that.
To add to this, you could likely remove the 6th tumbler from your ignition cylinder to match your door cylinders.
The keys are the same length, so I think the spacing between the tumblers is different.
Just took a look at my two original keys side-by-side.  Looks like the door key had a blank spot closest to the key ring end.  You could probably remove this tumbler from your ignition and key tumblers 1-5 to match.
That's what I thought, too. The locksmith told me that's not correct.
I don't know. It wasn't worth it to me to waste money trying something that the professional had already told me couldn't be done.
Yeah, that makes sense.  Plus the locksmith can now sell you twice as many keys ;-)
I didn't need keys, and he knew that. I was in the shop to buy locksets for my house, but I took the opportunity to ask a professional about the possibility of converting my '88 to a single key vehicle. He had nothing to gain by telling me it couldn't be done.
I got the lock set yesterday and installed them today. They work like a charm but what a pain to install. I also installed some window sash that I got at the junkyard.  And look what I found behind one of them door panels. You can’t read anything but it’s there.
  • 2 years later...
  • 1 year later...
Dusting this thread back off...
We have the passenger door panel off for replacing the insides of the door. We've never had keys to the door lock cylinders and are considering replacing the locks before replacing the vapor barrier and reinstalling the door card. Would be nice to be able to lock the doors, but so far the condition of the vehicle, millennial anti-theft device 5-speed transmission, and general honesty of people in Idaho have worked well enough...
This thread and this other thread have been helpful. It appears that the following parts are all the same and will work.
https://tinyurl.com/4366sbv6
https://tinyurl.com/4yxraaz7
https://tinyurl.com/3nc62zy6
I have read that the door lock cylinders can be re-keyed. We have a door key for our CJ that could pull double duty as the door key for the MJ too. If we re-keyed, what are some beginner level instructions for doing so?
Ultimately, our options are:
  1. Continue to ignore the non-working door locks
  2. Replace the lock cylinders
  3. Re-key the existing lock cylinders
