AZJeff Posted March 10, 2020 Posted March 10, 2020 I seem to remember this topic has been covered before, but I cannot seem to find it by searching the forum. For a 3.5 inch lift, what sort of choices do I have for decent rear shocks? I know one way to figure this out is to measure the max. axle droop and the height when against the bump stop, but I am also hoping someone has found some brands to be better than others, especially for a MJ that rarely carries any load.
thecodemonk Posted March 10, 2020 Posted March 10, 2020 Very happy with Bilstein 5100s as wellSent from my Pixel 4 using Tapatalk
AZJeff Posted March 10, 2020 Author Posted March 10, 2020 Thanks for finding that table. I knew it was out there, but had no idea I had already been shown this in response to a similar question before. Chalk it up to age. Yeah, that's my excuse.
fiatslug87 Posted March 10, 2020 Posted March 10, 2020 Here are Old Man Emu (OME) shock lengths, converted to Excel so it can be sorted/filtered. OMEShockSpecs.xlsx
ghetdjc320 Posted March 11, 2020 Posted March 11, 2020 On 3/10/2020 at 2:33 PM, thecodemonk said: Very happy with Bilstein 5100s as well Sent from my Pixel 4 using Tapatalk X2 I went with 5125’s and just browsed the Bilstein catalog until I found the ones I needed with the right valving and lengths. I’d recommend you actually measure your shock length needs vs just going off of something for a 3.5” lift. Actual lift heights just vary too much imo
Jeep Driver Posted March 11, 2020 Posted March 11, 2020 3 hours ago, fiatslug87 said: Here are Old Man Emu (OME) shock lengths, converted to Excel so it can be sorted/filtered. OMEShockSpecs.xlsx 50.08 kB · 3 downloads I looked that over, have no idea how to translate their mount info. Shrugged.
fiatslug87 Posted March 11, 2020 Posted March 11, 2020 The description of the mounts are on the second sheet within the workbook.
ghetdjc320 Posted March 11, 2020 Posted March 11, 2020 56 minutes ago, fiatslug87 said: The description of the mounts are on the second sheet within the workbook. I don’t see any valving info listed. Do they not post the valving specs? I’d get a set of bilsteins or fox and get them re-valved at accutune for your application.
Tex06 Posted May 26, 2020 Posted May 26, 2020 On 3/11/2020 at 8:38 AM, cruiser54 said: JK Rubicon take-offs. Cheap, easy, work great. Any idea on the extended/collapsed length of these Cruiser? I stumbled into a set of AEV dualsport Bilstein 5100s for dirt cheap and I'm thinking they just might work when I lift my truck.
dasbulliwagen Posted May 26, 2020 Posted May 26, 2020 I had the black JK takeoffs on my truck, 2wd springs with longer shackles, and they were a bit too short at stock height and stock mount locations. The red Rubicon ones are about the same length as the black ones. I personally would not recommend them for 3.5 of lift unless you weld on new shock mounts higher up than the low original spring plate mount ones.
