1jtmp6313jt166077
hakukamana
Just purchased, running but not driving. No Brakes. 1988 Sport truck Short Bed. White. Project "future", $300, just couldn't pass it up. 4.0L Automatic column shift, 4x4. Bench seat mini console for 4x4 shifter. Idiot gauge cluster. Drivers mirror only. White Camper shell. AC, power steering, manual windows, fixed vent windows. Blue Interior.
*X3
-Q8
AGC
APA MONOTONE PAINT PACKAGE
BCQ Battery - 750 Amp Maintenance Free
CBA BENCH SEAT - STRAIGHT BK
CGX Head Restraints-Outboard Seating, RR
DGW Transmission - 4-Spd. Automatic,44RE
DSA LIMITED SLIP DIFFERENTIAL
DTA
ERB ENGINE - 4.0L I6 MPI GAS
GAC ALL WINDOWS - TINTED GLASS
HAA AIR CONDITIONING - FRONT
JJA CIGAR LIGHTER - FRT COMP
LMA HALOGEN HEADLAMPS
MBG Bumper - Rear Step, Painted
MDA FRT LICENSE PLATE ATTACH REQUIRED
NAA ESA W/CATALYST (EXC CALIF SYSTEM)
NHQ Transmission Heater
PWB
QWB
RAC RADIO - AM/MTR
SBA POWER STEERING
TBB CONVENTIONAL SPARE TIRE
WJD WHEELS - 15 X 7.0 STYLED STEEL
XPF PROTECTIVE COATING AND REMOVER
Build date 3/20/88
Body code JL61
Eagle Scout you are correct. After your post I compared the license plate lights, the inner plastic caps and the brackets it was a factory tube bumper. Its trash and rusted pretty badly. Its been backed up into the tubes and they are bent and dented. I looked at the tube thickness looks like .0625 thickness its paper thin. No wonder if you backed into anything it dented. The piece of channel I think was used as a tow ball extension. The spare tire winch is in tack and functional, the load valve for the brakes is there and the rod and the bracket on the diff all in place. This is the first truck I've ever seen with all of these pieces still on the truck. Looks like the original muffler, and exhaust pipes.
  • 1 year later...
  • 5 months later...
*X3
-Q8
AGC
BCQ Battery - Maintenance Free
DTA
PWB
QWB
RAC RADIO - AM/MTR
SBA POWER STEERING
Build date 3/20/88
Body code JL61
Sold by COURTESY PONT-JEEP-EAGLE, HONOLULU HI
