nknapp16 Posted November 7, 2019 Share Posted November 7, 2019 Whats up guys, guess its time to start a build sheet so I can look back. Bought a 1990 4.0, 4x4, AW4, D44, MJ with Metric Ton Package in May 2018 (212k miles). Had to be towed home, missed an interview because tow truck driver decided to run errands.....3 hours later (thought it had been stolen, wouldnt answer phone). Anyway it was rough when I got it, brakes nonexistant, oil pressure low and erratic. Only had 10 days to get in inspected(no driveway) fixed what I could and then had a garage take care of the rest(bill wasnt as bad as I thought itd be) they got the brakes working and switch the oil filter to a WIX, pressure evened out. Passed inspection, and now it takes up all my free time (ask my wife.....). Overall goal is to have something fun, but mostly reliable. As of now I drive it to work once a week (70 miles round trip) without fear. So far..... Changed stock items -windshield, hood latch, brakes, belt/idle pulley, exhaust (stock with thrush muffler), trans mount, battery, alternator, vaccum hoses, blower, TPS and CPS. Upgrade items- 746 fuel injectors, Meanlemons 60mm throttle body and battery cables, Crown Auto HD Steering Kit- RT21004, Gauge cluster with RPM tach and sensors, 31x10.5 General Grabber A/TX(some rubbing full turn), AND completed Cruisers Tips- 1, 3, 4, 5, 7, 8, 10 ,11, 14, 18, 19, 22, 23, 37 To do list- Rust removal, floor pans. At least a 3 inch lift.... Link to comment Share on other sites More sharing options...
MeanLemons Posted November 12, 2019 Share Posted November 12, 2019 Good start! Link to comment Share on other sites More sharing options...
watchamakalit Posted November 12, 2019 Share Posted November 12, 2019 Its my trucks longbed brother. don't be afraid to daily drive it. They might be older trucks but can still be very reliable. My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t Link to comment Share on other sites More sharing options...
Pete M Posted November 12, 2019 Share Posted November 12, 2019 just gotta be proactive with parts-swapping, that's all. Link to comment Share on other sites More sharing options...
JMO413 Posted November 13, 2019 Share Posted November 13, 2019 Your truck and what you've done are almost identical to mine. Same black pioneer with some rust. I've got rid of allot of rust and replaced both floor pans. Can't wait to see the progress. Link to comment Share on other sites More sharing options...
nknapp16 Posted November 13, 2019 Author Share Posted November 13, 2019 Thanks guys, any suggestions for body rust? Should I knock it off or just spray with rust inhibitor/ primer? And what's the best/easiest spray to at least stop the rust for now. Link to comment Share on other sites More sharing options...
Pete M Posted November 13, 2019 Share Posted November 13, 2019 MJs rot from the inside-out. and inside the bedsides, inside the rockers, and inside the frames are... difficult to deal with. primer is not a sealer and thus not a final coat. you must hit it with a paint too. Link to comment Share on other sites More sharing options...
nknapp16 Posted November 26, 2019 Author Share Posted November 26, 2019 Had a small coolant leak. After driving(up to temp) and turning it off, once it sat for awhile it would leave a small puddle under the jeep. Never saw where it was leaking from, but guessing the lower radiator hose. Anyways decided to just do it all, swapped out water pump, thermostat (stant), thermostat housing, fan clutch, and upper and lower radiator hose. Before temp was well below the 210 mark....guessing 190ish. Now it is just past 210, if I turn on the heat, it drops to 210 exactly...........from what i see (searches) this seem normal. Any input? Positive note- heat blew warm before, now is hot. Link to comment Share on other sites More sharing options...
thecodemonk Posted November 26, 2019 Share Posted November 26, 2019 210 is within normal operating range. You may have had a lower temp thermostat in there previously that started cooling earlier. It doesn't always work (usually just means it takes longer to get "up to stabilized temperature"). My 01 XJ and the 91 MJ (pre-LS) both ran between 195-210ish pretty consistently without issues. I'd only worry if it started to get up to 220-230 range consistently. Link to comment Share on other sites More sharing options...
nknapp16 Posted November 27, 2019 Author Share Posted November 27, 2019 Big morning, finally got rid of all the steering slop and it drives awesome now. (I cheated and turned the power steering adjustment allen, if it goes it goes, that other way looks very time consuming). Engine temp is constant, dash shows between 210 and I think 225. Infrared therm. Shows 150ish at thermostat housing and 185 at big hose going off it. And got a freebie finally, oil gauge pegged while driving, when I installed new gauge cluster tore some of the copper ribbon, slid in some wire, works but always in the back of my mind. When the oil gauge pegged I figured that came undone, (ugh taking apart gauge cluster again.....let's say it would of stayed like that for awhile), but the oil sender unit wire had just popped off. It's the small things in life haha, so back to driving her daily again after her sitting for .....3 weeks? Link to comment Share on other sites More sharing options...
nknapp16 Posted January 13, 2020 Author Share Posted January 13, 2020 This nice weather got me motivated to rip out the carpet and see if I had a good truck or a junker. Been putting it off bc I was scared. Thank the Jeep God's, it's not that bad. Link to comment Share on other sites More sharing options...
Pete M Posted January 17, 2020 Share Posted January 17, 2020 yup, I've definitely seen far worse. Although it feels weird to congratulate you for the small rust holes. Link to comment Share on other sites More sharing options...
nknapp16 Posted February 18, 2020 Author Share Posted February 18, 2020 Picked up a new set of seats! Pretty good condition, bolted right in, xj buckets that had the mj brackets installed already. Stripping has been taking awhile, the rubber covering is by far the worst part, but got most of it. Once I found rust under some of it I decided to get it all out. Slow but steady....Sent from my SM-N970U1 using Tapatalk Link to comment Share on other sites More sharing options...
nknapp16 Posted March 2, 2020 Author Share Posted March 2, 2020 Took a break on mj, friend gave me a 6v 1990 power wheels jeep safari. No battery or key. Upgraded to a 12v 20amph battery and switch that works. Gonna be nephews 2nd bday present. Sent from my SM-N970U1 using Tapatalk Link to comment Share on other sites More sharing options...
Pete M Posted March 2, 2020 Share Posted March 2, 2020 nice! Link to comment Share on other sites More sharing options...
nknapp16 Posted May 2, 2020 Author Share Posted May 2, 2020 About to install new rear leafs from general spring......should I just do the 8.8 now if I can find one cheap.....? Besides the axle what would I need.Sent from my SM-N970U1 using Tapatalk Link to comment Share on other sites More sharing options...
Pete M Posted May 8, 2020 Share Posted May 8, 2020 I think there's a writeup in the link in my sig? another decent option is the Liberty 8.25 which is super common in the junkyards right now. Link to comment Share on other sites More sharing options...
nknapp16 Posted May 8, 2020 Author Share Posted May 8, 2020 Changing leaf springs..not funSent from my SM-N970U1 using Tapatalk Link to comment Share on other sites More sharing options...
Pete M Posted May 8, 2020 Share Posted May 8, 2020 bolts seized in the bushings? Link to comment Share on other sites More sharing options...
nknapp16 Posted May 8, 2020 Author Share Posted May 8, 2020 Yea, seized in metal sleeve, got passenger side out, but need new u hardware also, ubolts, bolts. Plates are good. Lining that center pin up is a pain also, any tricks?Sent from my SM-N970U1 using Tapatalk Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 8, 2020 Share Posted May 8, 2020 On 5/8/2020 at 3:50 AM, nknapp16 said: Lining that center pin up is a pain also, any tricks? Expand When I got a leaf spring from generalspring, the alignment pin was way too thick to fit in the hole, so I had to use the old pin to get it to line up correctly. That was the problem I had. Link to comment Share on other sites More sharing options...
nknapp16 Posted May 22, 2020 Author Share Posted May 22, 2020 Got the leafs in, driver side was much easier, GS must of made the alignment hole bigger, fit perfect. 10.75 inches from top of tube to frame and thats with a 2 inch lift shackle..... Link to comment Share on other sites More sharing options...
nknapp16 Posted May 24, 2020 Author Share Posted May 24, 2020 Before Link to comment Share on other sites More sharing options...
nknapp16 Posted May 24, 2020 Author Share Posted May 24, 2020 After Link to comment Share on other sites More sharing options...
Pete M Posted May 24, 2020 Share Posted May 24, 2020 definitely not saggin' any more Link to comment Share on other sites More sharing options...
