89MJohn Posted October 31, 2019 Share Posted October 31, 2019 Total new member no posting experience any help suggestions or funny jokes appreciated!! I recently was given an 89 jeep Comanche 2wd 5 speed manual. It was near a California wildfire and was saved by single lady homeowner before total loss. I moved her to new home and she noticed me admiring it. Longest story short her sons first car, he had passed away, she kept in memory of him. Someone stole it, punched ignition, on and on. Link to comment Share on other sites More sharing options...
Ωhm Posted October 31, 2019 Share Posted October 31, 2019 Welcome to CC Forum. Link to comment Share on other sites More sharing options...
89MJohn Posted October 31, 2019 Author Share Posted October 31, 2019 So after moving her she offered it to me. We filled out the paperwork because she'd lost title, and I put $200 cash in her purse without her seeing just to help out. She called later and tried insist I take the money back lol. Reading for 2 weeks I understand swap from a "donor truck" is bolt on with moderate sarcasm mentioned sometimes I had seen an xj at a neighbor's home so off with Cash i went. $225 for the 88 2 DOOR xj with 219k on clock. Started fine and drove onto trailer Leaked water from rear of engine and steering was terrible but for the $.... Link to comment Share on other sites More sharing options...
89MJohn Posted October 31, 2019 Author Share Posted October 31, 2019 89 mj 4.0L manual 2x4 88 xj 4.0L automatic 4x4 I will get pictures of mj engine bay and wiring tomorrow Here is the xj engine bay & here xj is out of theway after trailering home Link to comment Share on other sites More sharing options...
thecodemonk Posted October 31, 2019 Share Posted October 31, 2019 Nice! This sounds like the start of a good build thread! Looks like you got some good bones to put together too! Is that grille.. melted?? With that much heat, you definitely want to replace the radiator as I would assume that the plastic sides on the radiator are probably compromised.Sent from my Pixel 4 using Tapatalk Link to comment Share on other sites More sharing options...
89MJohn Posted October 31, 2019 Author Share Posted October 31, 2019 Yes melted Prev owner pushed it away from wildfire so she could save it. Radiator will be upgraded to 91+ model with radiator cap and open system from my reading Questions 1. Should I abandon melted mj wiring harness in place of xj harness or repair? 2. Should I upgrade front xj axle away from what I've read is vacuum disconnect d30 axle 3. I'm self and internet educated automotively and want to know if I'm over my head before hand Link to comment Share on other sites More sharing options...
Dammerung Posted October 31, 2019 Share Posted October 31, 2019 On 10/31/2019 at 4:25 AM, 89MJohn said: Yes melted Prev owner pushed it away from wildfire so she could save it. Radiator will be upgraded to 91+ model with radiator cap and open system from my reading Questions 1. Should I abandon melted mj wiring harness in place of xj harness or repair? 2. Should I upgrade front xj axle away from what I've read is vacuum disconnect d30 axle 3. I'm self and internet educated automotively and want to know if I'm over my head before hand Welcome to the club!1. I’d recommend replacing everything with the stuff from the xj, as most of the connectors for the headlights and such are melted.2. I can’t help, 4 wheeling isn’t my thing.3. I don’t believe you are. The Comanche is my first and I haven’t had any problems tying to fix mine up. It should be a simple in and out swap with the good parts from the xjSent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Smokeyyank Posted October 31, 2019 Share Posted October 31, 2019 Welcome and good find! For the harness you got 2 routes. Upgrade to a 97 xj+; advantages are better connectors, obd II, and parts more readily available. Disadvantage it's a lot of work. Or Swap in another renix era harness. Advantages; not as involved as a 97+. Disadvantage you're still going through a decent amount if work for little gain, connectors could be a problem. Axle if you're already planning to swap I'd find a non CAD d30. Plus the 96+ have bigger u joints. No, not only is CC an awesome forum full of tons of knowledge but there are plenty of write ups on swapping to a 4wd and so on. Anyone with some basic mechanical aptitude can easily wrench on a 4.0. Link to comment Share on other sites More sharing options...
Eagle Posted October 31, 2019 Share Posted October 31, 2019 On 10/31/2019 at 4:25 AM, 89MJohn said: Yes melted Prev owner pushed it away from wildfire so she could save it. Radiator will be upgraded to 91+ model with radiator cap and open system from my reading Questions 1. Should I abandon melted mj wiring harness in place of xj harness or repair? 2. Should I upgrade front xj axle away from what I've read is vacuum disconnect d30 axle 3. I'm self and internet educated automotively and want to know if I'm over my head before hand Expand 1. Is the MJ harness melted? If so, the XJ harness should be pretty much the same, so you should be able to use all or most of it to replace the damaged parts in the MJ. The biggest difference is that the '88 has the C101 connector -- high on the firewall, on the driver's side in the engine bay. That's where the engine side mates with the under-dash part. The C101 connector was troublesome, and for the 1989 model year they eliminated it. 2. Unless you plan to run huge tires, there's nothing wrong with the D30 axle in the XJ. Just engage the disconnector and lock it in place -- there are several articles here explaining how to do that. There's no reason for you to buy another axle if you already have one. Just be certain the ratios match. 3. You'll learn a lot. We're here to help when you have questions. Link to comment Share on other sites More sharing options...
DesertRat1991 Posted October 31, 2019 Share Posted October 31, 2019 On 10/31/2019 at 3:04 AM, 89MJohn said: 89 mj 4.0L manual 2x4 88 xj 4.0L automatic 4x4 I will get pictures of mj engine bay and wiring tomorrow Here is the xj engine bay & here xj is out of theway after trailering home Expand But... that XJ tho... Are those the original Marchal fogs? How's the interior look? Link to comment Share on other sites More sharing options...
89MJohn Posted October 31, 2019 Author Share Posted October 31, 2019 On 10/31/2019 at 4:37 PM, DesertRat1991 said: But... that XJ tho... Are those the original Marchal fogs? How's the interior look? Expand Lol My same thoughts exactly 2 DOOR bone stock down to fog lights accept that spare carrier which is growing on me. Interior is good missing passenger door card and DIRTY. Headliner is good, nice dashmat Found several tools & three boxes of ammo in xj so knock another $25 off price 😀 My cousin dibbed the carcass for a chevy 4 link swap IF I gut it. Link to comment Share on other sites More sharing options...
89MJohn Posted October 31, 2019 Author Share Posted October 31, 2019 On 10/31/2019 at 4:19 PM, Eagle said: 1. Is the MJ harness melted? If so, the XJ harness should be pretty much the same, so you should be able to use all or most of it to replace the damaged parts in the MJ. The biggest difference is that the '88 has the C101 connector -- high on the firewall, on the driver's side in the engine bay. That's where the engine side mates with the under-dash part. The C101 connector was troublesome, and for the 1989 model year they eliminated it. 2. Unless you plan to run huge tires, there's nothing wrong with the D30 axle in the XJ. Just engage the disconnector and lock it in place -- there are several articles here explaining how to do that. There's no reason for you to buy another axle if you already have one. Just be certain the ratios match. 3. You'll learn a lot. We're here to help when you have questions. Expand Eagle, and to EVERYONE above THANK YOU FOR YOUR TIME So helpful to have direct answers especially with subtle year model differences like the wiring plug c101 mentioned To do away with the c101 plug I can direct solder the wires and do away with it myself from 88 harness?? So I see both opinions, replace and repair the in fact melted mj harness or abandon it... Pics of the mj wiring damage should help with decision. Will post later Concerning the 97+ swap, price difference leads me to the -91 year swap. I can't find a 97 for under $1700 Link to comment Share on other sites More sharing options...
89MJohn Posted November 1, 2019 Author Share Posted November 1, 2019 Mj engine bay Not sure its melted wiring, thinking its a few wires that direct shorted and a bad mechanic took it all apart. Link to comment Share on other sites More sharing options...
omega_rugal Posted November 1, 2019 Share Posted November 1, 2019 oh that feeling when you see an MJ waiting to be modded... Link to comment Share on other sites More sharing options...
Eagle Posted November 1, 2019 Share Posted November 1, 2019 On 10/31/2019 at 6:01 PM, 89MJohn said: To do away with the c101 plug I can direct solder the wires and do away with it myself from 88 harness?? Expand Yes. In fact, the factory issued a TSB (Technical Service Bulletin) recommending exactly that. Link to comment Share on other sites More sharing options...
89MJohn Posted November 1, 2019 Author Share Posted November 1, 2019 What's the consensus on wiring mess? Excellent I will Google the tsb for the plug solder repair. Anything else like that i should be aware of? Decided to keep the 2 door xj complete for wife and find another 88-91 donor xj Link to comment Share on other sites More sharing options...
Eagle Posted November 1, 2019 Share Posted November 1, 2019 On 11/1/2019 at 2:54 AM, 89MJohn said: Decided to keep the 2 door xj complete for wife and find another 88-91 donor xj Expand Donor can be '87-90. 1991 was when Chrysler introduced the HO. Those have a totally different electrical system. Different ECU, different injection, different ignition. Assuming the XJ is complete and undamaged, you can open the hood on that and use it as a road map to check what's been messed with in the MJ. Link to comment Share on other sites More sharing options...
Pete M Posted November 1, 2019 Share Posted November 1, 2019 how solid is that XJ? how much work to get it working again? those things are pretty dang rare and I'd wager you can make a tidy profit if it's easy to get running again. Link to comment Share on other sites More sharing options...
Eagle Posted November 1, 2019 Share Posted November 1, 2019 On 11/1/2019 at 2:54 AM, 89MJohn said: Decided to keep the 2 door xj complete for wife and find another 88-91 donor xj Expand Good plan. Link to comment Share on other sites More sharing options...
89MJohn Posted November 2, 2019 Author Share Posted November 2, 2019 So create a new page for the xj fix up or keep on truckin here everyone? Xj questions and apologies in advance for poor photos Is this the c101 plug high on firewall that needs direct soldering, drivers side? Also in same pic near bottom is a rubber hose with a white plug. Is that supposed to be plugged? Hey posting is easy.... Next, looking above throttle body Whats the unplugged 2 wire plug center of pic Also what's the steel cable directly under the 2 wire plug. Old cruise control? Interior has aftermarket cruise unit Link to comment Share on other sites More sharing options...
89MJohn Posted November 2, 2019 Author Share Posted November 2, 2019 Final ask for help of the evening Hose from thermostat is broken hence water leak I see where one hose plugs into, where does one with green arrow go? Will these be replaced with open cooling system upgrade? Thank you everyone again for the warm WELCOME Link to comment Share on other sites More sharing options...
jdog Posted November 2, 2019 Share Posted November 2, 2019 On 11/2/2019 at 2:07 AM, 89MJohn said: So create a new page for the xj fix up or keep on truckin here everyone? Xj questions and apologies in advance for poor photos Is this the c101 plug high on firewall that needs direct soldering, drivers side? Also in same pic near bottom is a rubber hose with a white plug. Is that supposed to be plugged? Hey posting is easy.... Next, looking above throttle body Whats the unplugged 2 wire plug center of pic Also what's the steel cable directly under the 2 wire plug. Old cruise control? Interior has aftermarket cruise unit Yep thats the 101 connetor, the hose with the plug is the vent for the front axle and is supposed to have the cap on it. I'm not sure where the plug in goes, yes I would say that's a cruise cableStock 1988 swb 4.0 ax15 np 231. Link to comment Share on other sites More sharing options...
jdog Posted November 2, 2019 Share Posted November 2, 2019 On 11/2/2019 at 2:46 AM, 89MJohn said: Final ask for help of the evening Hose from thermostat is broken hence water leak I see where one hose plugs into, where does one with green arrow go? Will these be replaced with open cooling system upgrade? Thank you everyone again for the warm WELCOME That hose will go to the coolant bottle, in the picture you almost see where it was broken. Stock 1988 swb 4.0 ax15 np 231. Link to comment Share on other sites More sharing options...
89MJohn Posted November 2, 2019 Author Share Posted November 2, 2019 On 11/2/2019 at 3:19 AM, jdog said: That hose will go to the coolant bottle, in the picture you almost see where it was broken in the picture Stock 1988 swb 4.0 ax15 np 231. Expand Now I feel dumb, I was looking for a hose connection to fit it with. Wow that 101 connector has a lot of wires!! Do all wire colors match either side of connectors or follow pins direct 1 at a time? Link to comment Share on other sites More sharing options...
jdog Posted November 2, 2019 Share Posted November 2, 2019 On 11/2/2019 at 5:06 AM, 89MJohn said: Now I feel dumb, I was looking for a hose connection to fit it with. Wow that 101 connector has a lot of wires!! Do all wire colors match either side of connectors or follow pins direct 1 at a time? No problem it's a weird setup. I am not sure with the 101 connetor as I have yet to do it. If you look on cruisers website, cruiser54.com he has instructions on how to delete it. Oh and welcome to the club. Stock 1988 swb 4.0 ax15 np 231. Link to comment Share on other sites More sharing options...
