ogjeep Posted March 9, 2021 Author Posted March 9, 2021 On 3/6/2021 at 11:24 AM, Jesse J said: that sucks about the trans. Yea def sucks but itll be allright.
ogjeep Posted March 25, 2021 Author Posted March 25, 2021 i have alot of updates, i redid the whole front end and added the original grill. I finally repainted all the trim, as well as the mirrors. I also replaced the fog lights, and added some additional Hella fog lights. Then on top of that i added some Projector Headlights with Halos. And damn are they nice. Here are some pics
ogjeep Posted March 25, 2021 Author Posted March 25, 2021 Finally got around to lowering it. Damn it rides smooth. Ill take some higher quality pics soon.
Dzimm Posted March 26, 2021 Posted March 26, 2021 Looking good. Have you noticed any spring wrap with those lowering blocks? Some vehicles have issues some don't, curious if the MJ does or not. How close is your front bump stop to the pad on the axle? Mine got within an inch on the ZJ springs so have to be careful with bumps at speed.
ogjeep Posted March 26, 2021 Author Posted March 26, 2021 12 hours ago, Dzimm said: Looking good. Have you noticed any spring wrap with those lowering blocks? Some vehicles have issues some don't, curious if the MJ does or not. How close is your front bump stop to the pad on the axle? Mine got within an inch on the ZJ springs so have to be careful with bumps at speed. No spring wrap yet. But i also havnt done any ripping burners yet. As for the front i need to look but i did check oil pan clearance and we are good. Driving around havnt had any smacks on the bumpstops yet. But i did remove them. So i just have the shafts in there no pad. Not sure if you did that as well. But so far so good! Ill be adding cal tracs once the turbo kit gets going.
Dzimm Posted March 26, 2021 Posted March 26, 2021 3 hours ago, ogjeep said: Not sure if you did that as well. No I actually put new bumpstops in it because mine were trashed and I wanted to ensure I wouldn't be unintentionally draining the oil. Without the bumps you shouldn't bottom out but I believe the oil pan is closer to your steering stabilizer than the bump tube is to the axle so may need to be extra careful. I think if we somehow relocated the steering stabilizer we would have plenty of clearance on the oil pan with these springs that we could run with a much shorter bump stop and completely avoid any issues. It's one thing I haven't worked out yet.
ogjeep Posted March 26, 2021 Author Posted March 26, 2021 44 minutes ago, Dzimm said: No I actually put new bumpstops in it because mine were trashed and I wanted to ensure I wouldn't be unintentionally draining the oil. Without the bumps you shouldn't bottom out but I believe the oil pan is closer to your steering stabilizer than the bump tube is to the axle so may need to be extra careful. I think if we somehow relocated the steering stabilizer we would have plenty of clearance on the oil pan with these springs that we could run with a much shorter bump stop and completely avoid any issues. It's one thing I haven't worked out yet. Good tips, I havnt experienced any bad symptoms yet at all though. And ive hooned it pretty well.
89 MJ Posted March 27, 2021 Posted March 27, 2021 Wow! I love the red contrast with the bright blue and green background.
ogjeep Posted March 30, 2021 Author Posted March 30, 2021 On 3/26/2021 at 11:06 PM, MiNi Beast said: On 3/27/2021 at 4:56 AM, 89 MJ said: Wow! I love the red contrast with the bright blue and green background. Thanks for the love fellas
ogjeep Posted March 30, 2021 Author Posted March 30, 2021 Got around to building a custom exhaust for it. It will make alot more sense when the rear end is finished up. But hot damn it sounds good.
Dzimm Posted March 30, 2021 Posted March 30, 2021 That does sound pretty good. What is the setup on the exhaust?
ogjeep Posted March 30, 2021 Author Posted March 30, 2021 15 hours ago, Dzimm said: That does sound pretty good. What is the setup on the exhaust? Brand new cat with a hand built straight pipe to a resonator tip. Gurgles nicely
Jesse J Posted March 30, 2021 Posted March 30, 2021 37 minutes ago, ogjeep said: Brand new cat with a hand built straight pipe to a resonator tip. Gurgles nicely sounds fantastic!
ogjeep Posted March 31, 2021 Author Posted March 31, 2021 6 hours ago, Jesse J said: sounds fantastic! Thanks
ogjeep Posted March 31, 2021 Author Posted March 31, 2021 Got over to my friends shop and fabbed up a roll pan today.
MiNi Beast Posted March 31, 2021 Posted March 31, 2021 about damn time, your jeep was looking so incomplete. looks good but let me know when its all pretty.
ogjeep Posted March 31, 2021 Author Posted March 31, 2021 1 hour ago, MiNi Beast said: about damn time, your jeep was looking so incomplete. looks good but let me know when its all pretty. Its always incomplete
Pete M Posted March 31, 2021 Posted March 31, 2021 we're all still waiting on finding someone that's willing to push for replication of the side skirts.
MiNi Beast Posted March 31, 2021 Posted March 31, 2021 2 hours ago, Pete M said: we're all still waiting on finding someone that's willing to push for replication of the side skirts. how many you need? ill make some up, give me something to do.
ogjeep Posted March 31, 2021 Author Posted March 31, 2021 3 hours ago, Pete M said: we're all still waiting on finding someone that's willing to push for replication of the side skirts. Just wait for it....
