ogjeep Posted March 9, 2021 Author Share Posted March 9, 2021 On 3/6/2021 at 7:24 PM, Jesse J said: that sucks about the trans. Expand Yea def sucks but itll be allright. Link to comment Share on other sites More sharing options...
ogjeep Posted March 25, 2021 Author Share Posted March 25, 2021 i have alot of updates, i redid the whole front end and added the original grill. I finally repainted all the trim, as well as the mirrors. I also replaced the fog lights, and added some additional Hella fog lights. Then on top of that i added some Projector Headlights with Halos. And damn are they nice. Here are some pics Link to comment Share on other sites More sharing options...
ogjeep Posted March 25, 2021 Author Share Posted March 25, 2021 Link to comment Share on other sites More sharing options...
Jesse J Posted March 25, 2021 Share Posted March 25, 2021 looks great now! Link to comment Share on other sites More sharing options...
ogjeep Posted March 25, 2021 Author Share Posted March 25, 2021 Finally got around to lowering it. Damn it rides smooth. Ill take some higher quality pics soon. Link to comment Share on other sites More sharing options...
Dzimm Posted March 26, 2021 Share Posted March 26, 2021 Looking good. Have you noticed any spring wrap with those lowering blocks? Some vehicles have issues some don't, curious if the MJ does or not. How close is your front bump stop to the pad on the axle? Mine got within an inch on the ZJ springs so have to be careful with bumps at speed. Link to comment Share on other sites More sharing options...
ogjeep Posted March 26, 2021 Author Share Posted March 26, 2021 On 3/26/2021 at 2:11 AM, Dzimm said: Looking good. Have you noticed any spring wrap with those lowering blocks? Some vehicles have issues some don't, curious if the MJ does or not. How close is your front bump stop to the pad on the axle? Mine got within an inch on the ZJ springs so have to be careful with bumps at speed. Expand No spring wrap yet. But i also havnt done any ripping burners yet. As for the front i need to look but i did check oil pan clearance and we are good. Driving around havnt had any smacks on the bumpstops yet. But i did remove them. So i just have the shafts in there no pad. Not sure if you did that as well. But so far so good! Ill be adding cal tracs once the turbo kit gets going. Link to comment Share on other sites More sharing options...
Dzimm Posted March 26, 2021 Share Posted March 26, 2021 On 3/26/2021 at 3:00 PM, ogjeep said: Not sure if you did that as well. Expand No I actually put new bumpstops in it because mine were trashed and I wanted to ensure I wouldn't be unintentionally draining the oil. Without the bumps you shouldn't bottom out but I believe the oil pan is closer to your steering stabilizer than the bump tube is to the axle so may need to be extra careful. I think if we somehow relocated the steering stabilizer we would have plenty of clearance on the oil pan with these springs that we could run with a much shorter bump stop and completely avoid any issues. It's one thing I haven't worked out yet. Link to comment Share on other sites More sharing options...
ogjeep Posted March 26, 2021 Author Share Posted March 26, 2021 On 3/26/2021 at 6:49 PM, Dzimm said: No I actually put new bumpstops in it because mine were trashed and I wanted to ensure I wouldn't be unintentionally draining the oil. Without the bumps you shouldn't bottom out but I believe the oil pan is closer to your steering stabilizer than the bump tube is to the axle so may need to be extra careful. I think if we somehow relocated the steering stabilizer we would have plenty of clearance on the oil pan with these springs that we could run with a much shorter bump stop and completely avoid any issues. It's one thing I haven't worked out yet. Expand Good tips, I havnt experienced any bad symptoms yet at all though. And ive hooned it pretty well. Link to comment Share on other sites More sharing options...
ogjeep Posted March 27, 2021 Author Share Posted March 27, 2021 Snapped some higher res shots today. Enjoy Link to comment Share on other sites More sharing options...
MiNi Beast Posted March 27, 2021 Share Posted March 27, 2021 Link to comment Share on other sites More sharing options...
89 MJ Posted March 27, 2021 Share Posted March 27, 2021 Wow! I love the red contrast with the bright blue and green background. Link to comment Share on other sites More sharing options...
ogjeep Posted March 30, 2021 Author Share Posted March 30, 2021 On 3/27/2021 at 6:06 AM, MiNi Beast said: Expand On 3/27/2021 at 11:56 AM, 89 MJ said: Wow! I love the red contrast with the bright blue and green background. Expand Thanks for the love fellas Link to comment Share on other sites More sharing options...
ogjeep Posted March 30, 2021 Author Share Posted March 30, 2021 Got around to building a custom exhaust for it. It will make alot more sense when the rear end is finished up. But hot damn it sounds good. Link to comment Share on other sites More sharing options...
Dzimm Posted March 30, 2021 Share Posted March 30, 2021 That does sound pretty good. What is the setup on the exhaust? Link to comment Share on other sites More sharing options...
ogjeep Posted March 30, 2021 Author Share Posted March 30, 2021 On 3/30/2021 at 2:34 AM, Dzimm said: That does sound pretty good. What is the setup on the exhaust? Expand Brand new cat with a hand built straight pipe to a resonator tip. Gurgles nicely Link to comment Share on other sites More sharing options...
Jesse J Posted March 30, 2021 Share Posted March 30, 2021 On 3/30/2021 at 6:02 PM, ogjeep said: Brand new cat with a hand built straight pipe to a resonator tip. Gurgles nicely Expand sounds fantastic! Link to comment Share on other sites More sharing options...
ogjeep Posted March 31, 2021 Author Share Posted March 31, 2021 On 3/30/2021 at 6:40 PM, Jesse J said: sounds fantastic! Expand Thanks Link to comment Share on other sites More sharing options...
ogjeep Posted March 31, 2021 Author Share Posted March 31, 2021 Got over to my friends shop and fabbed up a roll pan today. Link to comment Share on other sites More sharing options...
MiNi Beast Posted March 31, 2021 Share Posted March 31, 2021 about damn time, your jeep was looking so incomplete. looks good but let me know when its all pretty. Link to comment Share on other sites More sharing options...
ogjeep Posted March 31, 2021 Author Share Posted March 31, 2021 On 3/31/2021 at 2:32 AM, MiNi Beast said: about damn time, your jeep was looking so incomplete. looks good but let me know when its all pretty. Expand Its always incomplete Link to comment Share on other sites More sharing options...
Pete M Posted March 31, 2021 Share Posted March 31, 2021 we're all still waiting on finding someone that's willing to push for replication of the side skirts. Link to comment Share on other sites More sharing options...
MiNi Beast Posted March 31, 2021 Share Posted March 31, 2021 On 3/31/2021 at 4:17 AM, Pete M said: we're all still waiting on finding someone that's willing to push for replication of the side skirts. Expand how many you need? ill make some up, give me something to do. Link to comment Share on other sites More sharing options...
ogjeep Posted March 31, 2021 Author Share Posted March 31, 2021 On 3/31/2021 at 4:17 AM, Pete M said: we're all still waiting on finding someone that's willing to push for replication of the side skirts. Expand Just wait for it.... Link to comment Share on other sites More sharing options...
