trick34 Posted June 1, 2019 Posted June 1, 2019 I jumped the gun a bit on this one. It doesn’t have a d44 front. I learned my lesson. As the title states I just picked up a 1991 comanche with with Dana 44 front and rear. I know the consensus on the internet is that all came with a dana 30 front. This is my 3rd Comanche and I’ve owned 3 xj’s as well so I’m decently familiar with the platform. Does anyone one have any insight on this truck? I will post pictures when I can get it on my rack. Possibly this afternoon or tomorrow.
Jeep Driver Posted June 1, 2019 Posted June 1, 2019 So, you are suggesting it came with a D44 front from the factory? Yes, pics please.
trick34 Posted June 1, 2019 Author Posted June 1, 2019 30 minutes ago, Jeep Driver said: So, you are suggesting it came with a D44 front from the factory? Yes, pics please. I’m more of on a fact finding mission. As I stated above I’ve owned a few and I know common knowledge is that it came with a d30. I'm trying to find a legit vin decoder and will be looking for the build sheet in the truck today as well. I plan to this afternoon. Has axle tags on both still too. I will post those as well.
trick34 Posted June 1, 2019 Author Posted June 1, 2019 4 hours ago, JMO413 said: Post the VIN I will decode through Chrysler. Here is the vin number: 1J7FJ26S2ML548031
trick34 Posted June 1, 2019 Author Posted June 1, 2019 On my way to rack the truck and get pictures. Will have them within the hour.
JMO413 Posted June 1, 2019 Posted June 1, 2019 *C1 TRIM STYLE C1 - CLOTH && VINYL BENCH SEAT -SA CHARCOAL 171 Zone 71-Los Angeles 1AA U.S. Dealer Retail 3VQ Customer Preferred Discount 4AF American Coin Merchandising ALA SE Decor Group ALK Italia Package APA Monotone Paint BAP 75 Amp Alternator BCX Nickel Metal Hydride Battery BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHN Command-Trac Part Time 4WD System DHT Elec,Shift-on-the-Fly,P/Time T/Case DJH 230MM Front Axle DMD 3.55 Rear Axle Ratio DRK Dana 44/226MM Rear Axle DSA Anti-Spin Differential Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GRV Left Manual Mirror GUA Open HCD Do Not Use - See HCA JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K3Z STRIPE/BADGE/MOLDING/COLOR KWX EAGLE/SUMMIT DECALS BL LBC Glove Box Lamp LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MOLDINGS - TYPE I NAE California Emissions NBK EVAP Control System NF5 Fuel Tank - 23 Gallon PB3 Intense Blue Pearl Coat QB3 Intense Blue Pearl Coat RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCE Alcantara Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TBB Full Size Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires TZH Michelin Brand Tires WJK 15X6.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z84 Right Front Spring Group XIII
JMO413 Posted June 1, 2019 Posted June 1, 2019 There's not an option code for the front axle. There bad news is the parts catalog only lists a Dana 30 for a front axle option.
trick34 Posted June 1, 2019 Author Posted June 1, 2019 34 minutes ago, JMO413 said: There's not an option code for the front axle. There bad news is the parts catalog only lists a Dana 30 for a front axle option. Thank you for decoding the vin. I wonder if it was a dealership option. I will post pictures here in a few min of the axle codes. If the axle was casted in 1990-1991 I would be surprised if it wasn’t on it when the customer purchased it original.
trick34 Posted June 1, 2019 Author Posted June 1, 2019 So I have to eat crow on this one. I got a little ahead of myself and I got a bit excited. It is definitely a dana 30. I subject myself to all the criticism I deserve. And I won’t post prematurely again. My lesson Is learned. please go easy on me...
Pete M Posted June 1, 2019 Posted June 1, 2019 you're not the first to mistake a 30 for a 44, probably not the last.
Minuit Posted June 1, 2019 Posted June 1, 2019 36 minutes ago, trick34 said: please go easy on me... How DARE YOU own up to making an honest, innocent mistake regarding two pieces of equipment that upon casual inspection look fairly similar? Don't you know that the right thing to do on the internet is to argue with anyone who asks for proof, engage in whataboutism, and move the goal posts when consensus disagrees with your assertions? Really though... common mistake. I have heard rumors of D44 fronts on some XJs that were built in Venezuela.
trick34 Posted June 1, 2019 Author Posted June 1, 2019 40 minutes ago, JMO413 said: You can always hope! 21 minutes ago, Pete M said: you're not the first to mistake a 30 for a 44, probably not the last. 7 minutes ago, Minuit said: How DARE YOU own up to making an honest, innocent mistake regarding two pieces of equipment that upon casual inspection look fairly similar? Don't you know that the right thing to do on the internet is to argue with anyone who asks for proof, engage in whataboutism, and move the goal posts when consensus disagrees with your assertions? Really though... common mistake. I have heard rumors of D44 fronts on some XJs that were built in Venezuela. Thank you guys. I appreciate that it isn’t just a roast fest. I’m definitely pretty embarrassed to have jumped the gun so much on it.
Eagle Posted June 1, 2019 Posted June 1, 2019 1 hour ago, Minuit said: I have heard rumors of D44 fronts on some XJs that were built in Venezuela. From time spent in South America with my wife, visiting her family, it is my understanding that those rumors are true. However, I can't say that I've seen one. My wife was from Chile. I've been wheeling with a friend in Chile, but the Jeeps in Chile are built in the U.S., not Venezuela.
MJXJjeepguy Posted June 1, 2019 Posted June 1, 2019 1 hour ago, 13 Legion said: i love that guy.... Well we all can relax after all!
Racko Posted June 2, 2019 Posted June 2, 2019 2 hours ago, trick34 said: So I have to eat crow on this one. I got a little ahead of myself and I got a bit excited. It is definitely a dana 30. I subject myself to all the criticism I deserve. And I won’t post prematurely again. My lesson Is learned. please go easy on me... This guy....I’m just kidding it happens to best of us!
