wclegere Posted February 15, 2019 Author Share Posted February 15, 2019 On 2/15/2019 at 1:53 AM, Jeep Driver said: Yes, you'll have a TPS or throttle position sensor. Expand would that have anything to do with the no start problem? Link to comment Share on other sites More sharing options...
Jeep Driver Posted February 15, 2019 Share Posted February 15, 2019 On 2/15/2019 at 1:55 AM, wclegere said: would that have anything to do with the no start problem? Expand No. Link to comment Share on other sites More sharing options...
wclegere Posted February 15, 2019 Author Share Posted February 15, 2019 On 2/15/2019 at 1:56 AM, Jeep Driver said: No. Expand ok. I really want to thank you for all your help and patience! Link to comment Share on other sites More sharing options...
Jeep Driver Posted February 15, 2019 Share Posted February 15, 2019 Let's keep this simple. TBI, ECU will prime fuel pump for 2-3 seconds when you turn the key to on or ignition. After it primes it will shut the pump off. ECU, when ECU senses that the engine is turning over, signal from CPS, it will run the pump and send a pulse signal to the injector and allow spark. CPS, if no signal to ECU, ECU will shut down pump and end pulse signal to injector and end spark. If your injector is not pulsating- no signal from CPS to ECU. Or you have a wiring issue or you have a bad ECU. It's that simple. What ECU did you get to replace the original and why did you replace it? Link to comment Share on other sites More sharing options...
wclegere Posted February 15, 2019 Author Share Posted February 15, 2019 Right now, I've got this Comanche that a man is trying to get running for his son as a first vehicle. He's in way over his head in the amount of money he's spent on this thing. In addition to that I've got a 99 Chevy Suburban with a 5.7L vortec that is pushing antifreeze into the crankcase and a 96 Ford explorer that is throwing O2 sensor codes after replacing the exhaust system and a 77 Jeep CJ7 complete rebuild project going on all at the same time! I'm stretched a little thin at the moment. Link to comment Share on other sites More sharing options...
wclegere Posted February 15, 2019 Author Share Posted February 15, 2019 On 2/15/2019 at 2:02 AM, Jeep Driver said: Let's keep this simple. TBI, ECU will prime fuel pump for 2-3 seconds when you turn the key to on or ignition. After it primes it will shut the pump off. ECU, when ECU senses that the engine is turning over, signal from CPS, it will run the pump and send a pulse signal to the injector and allow spark. CPS, if no signal to ECU, ECU will shut down pump and end pulse signal to injector and end spark. If your injector is not pulsating- no signal from CPS to ECU. Or you have a wiring issue or you have a bad ECU. It's that simple. What ECU did you get to replace the original and why did you replace it? Expand YES!!!! This is what I needed!!! Thank You!!! Ok... I think we can go from here. Jeep Driver, YOU ARE THE MAN!!!! CPS or wiring issues. Thank you! Link to comment Share on other sites More sharing options...
eaglescout526 Posted February 15, 2019 Share Posted February 15, 2019 On 2/15/2019 at 2:02 AM, Jeep Driver said: Let's keep this simple. TBI, ECU will prime fuel pump for 2-3 seconds when you turn the key to on or ignition. After it primes it will shut the pump off. ECU, when ECU senses that the engine is turning over, signal from CPS, it will run the pump and send a pulse signal to the injector and allow spark. CPS, if no signal to ECU, ECU will shut down pump and end pulse signal to injector and end spark. If your injector is not pulsating- no signal from CPS to ECU. Or you have a wiring issue or you have a bad ECU. It's that simple. Expand Well said. Link to comment Share on other sites More sharing options...
Eagle Posted February 15, 2019 Share Posted February 15, 2019 On 2/15/2019 at 12:45 AM, wclegere said: Engine has plenty of spark. Yes it will fire when gas is dumped into the TB but that really doesn't help much with the solution, does it? Expand Of course it helps. An internal combustion engine needs three things to start and run: fuel, air, and spark. If all you know is that it won't start, you don't know what to check first. If you can pour gas into the throttle body and it starts, that verifies that the ignition system isn't a problem. So you DON'T worry about CPS, ECM, coil, or distributor. Also, it's getting air so you don't worry about valves or camshaft. So you're down to a fuel delivery problem. Focus your attention on troubleshooting the fuel system. Link to comment Share on other sites More sharing options...
yxmj Posted February 15, 2019 Share Posted February 15, 2019 Sort of like what was said on page 1.......? Link to comment Share on other sites More sharing options...
Eagle Posted February 15, 2019 Share Posted February 15, 2019 On 2/15/2019 at 4:48 PM, yxmj said: Sort of like what was said on page 1.......? Expand Pretty much. Link to comment Share on other sites More sharing options...
Nick Walker Posted August 20, 2021 Share Posted August 20, 2021 On 2/15/2019 at 2:09 AM, wclegere said: YES!!!! This is what I needed!!! Thank You!!! Ok... I think we can go from here. Jeep Driver, YOU ARE THE MAN!!!! CPS or wiring issues. Thank you! Expand Having the same issue with my 86 Comanche. It will start and then die after two seconds. Replaced the CPS, fuel pump, Map, relay. Did the new ECU fix your issue? Link to comment Share on other sites More sharing options...
Pete M Posted August 20, 2021 Share Posted August 20, 2021 On 8/20/2021 at 2:19 PM, Nick Walker said: Having the same issue with my 86 Comanche. It will start and then die after two seconds. Replaced the CPS, fuel pump, Map, relay. Did the new ECU fix your issue? Expand wiring is a big issue with these old trucks. have you accomplished all of Cruiser's MJ tips? should be like the first link in the link in my signature you wouldn't happen to have this little guy somewhere in the engine bay, would you? it's white-ish and like 3" long. it wouldn't have been there from the factory, but could have been added later on. Link to comment Share on other sites More sharing options...
Nick Walker Posted August 20, 2021 Share Posted August 20, 2021 On 8/20/2021 at 2:59 PM, Pete M said: wiring is a big issue with these old trucks. have you accomplished all of Cruiser's MJ tips? should be like the first link in the link in my signature you wouldn't happen to have this little guy somewhere in the engine bay, would you? it's white-ish and like 3" long. it wouldn't have been there from the factory, but could have been added later on. Expand From what I think I have read, the 2.5 doesn't have the resistor. Link to comment Share on other sites More sharing options...
Nick Walker Posted August 20, 2021 Share Posted August 20, 2021 On 8/20/2021 at 3:04 PM, Nick Walker said: From what I think I have read, the 2.5 doesn't have the resistor. Expand I am getting fuel all the way to the TB, but nothing spraying in. Link to comment Share on other sites More sharing options...
Pete M Posted August 20, 2021 Share Posted August 20, 2021 I know. 86 shouldn't have it and the 2.5 shouldn't have it. but dying repeatably after 2 seconds is exactly what a failed resistor would do so I figured I'd ask just in case a previous owner had it installed. what are you getting out of the CPS? is that signal getting past the connector? does the truck keep running if you put gas or starter fluid in the TB? Link to comment Share on other sites More sharing options...
Nick Walker Posted August 20, 2021 Share Posted August 20, 2021 On 8/20/2021 at 3:12 PM, Pete M said: I know. 86 shouldn't have it and the 2.5 shouldn't have it. but dying repeatably after 2 seconds is exactly what a failed resistor would do so I figured I'd ask just in case a previous owner had it installed. what are you getting out of the CPS? is that signal getting past the connector? does the truck keep running if you put gas or starter fluid in the TB? Expand What do you mean what am I getting out of the CPS? Sorry I'm not the most mechanically inclined person but I am learning. I can keep it running if i continuously apply the throttle but it runs very rough. It will come close to stalling then I can get it to rev but will die if i do not keep in the throttle. Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 20, 2021 Share Posted August 20, 2021 On 8/20/2021 at 3:05 PM, Nick Walker said: I am getting fuel all the way to the TB, but nothing spraying in. Expand Try this epic. Link to comment Share on other sites More sharing options...
Pete M Posted August 20, 2021 Share Posted August 20, 2021 On 8/20/2021 at 3:21 PM, Nick Walker said: I can keep it running if i continuously apply the throttle but it runs very rough. It will come close to stalling then I can get it to rev but will die if i do not keep in the throttle. Expand that's a huge clue there. that tells me the CPS is working and the computer is working. do you have a multimeter? Link to comment Share on other sites More sharing options...
Nick Walker Posted August 20, 2021 Share Posted August 20, 2021 On 8/20/2021 at 3:12 PM, Pete M said: I know. 86 shouldn't have it and the 2.5 shouldn't have it. but dying repeatably after 2 seconds is exactly what a failed resistor would do so I figured I'd ask just in case a previous owner had it installed. what are you getting out of the CPS? is that signal getting past the connector? does the truck keep running if you put gas or starter fluid in the TB? Expand Yes i do. Link to comment Share on other sites More sharing options...
Nick Walker Posted August 20, 2021 Share Posted August 20, 2021 On 8/20/2021 at 3:30 PM, Pete M said: that's a huge clue there. that tells me the CPS is working and the computer is working. do you have a multimeter? Expand Yes I do. Link to comment Share on other sites More sharing options...
Pete M Posted August 20, 2021 Share Posted August 20, 2021 the link in my signature has threads on testing the various sensors. I would test the TPS and idle controller. Link to comment Share on other sites More sharing options...
Nick Walker Posted August 20, 2021 Share Posted August 20, 2021 On 8/20/2021 at 4:00 PM, Pete M said: the link in my signature has threads on testing the various sensors. I would test the TPS and idle controller. Expand Oddly enough the TPS has never been plugged in to my Knowledge. The connector is melted and I think it was set manually to where the throttle is resting against the throttle. It had always ran fine so I never messed with it Link to comment Share on other sites More sharing options...
Pete M Posted August 20, 2021 Share Posted August 20, 2021 um, what? how can it run without the throttle position sensor plugged in? Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 20, 2021 Share Posted August 20, 2021 On 8/20/2021 at 5:31 PM, Pete M said: um, what? how can it run without the throttle position sensor plugged in? Expand I mean it will run. The ECU has default readings to get the engine running but as soon as you throttle it the engine sputters and dies due to the demand and the ECU can’t compensate with no TPS. I’ve tried it before but Nick definitely does need it plugged in and adjusted per the factory specs. Link to comment Share on other sites More sharing options...
jdog Posted August 20, 2021 Share Posted August 20, 2021 A picture would help clear up the confusion, I'm thinking it's the idle solinoid that is unplugged Link to comment Share on other sites More sharing options...
