Virginia Posted December 9, 2018 Share Posted December 9, 2018 Mine has frozen up. Any tricks or suggestions on doing this? Gonna put a new belt on as well. I've watched several videos--none of which are my 1991 comanche specific but watched a 1991 cherokee changed and figure it's the same. It's the pretty shiny thing in the picture. Link to comment Share on other sites More sharing options...
ComancheKid45 Posted December 9, 2018 Share Posted December 9, 2018 Very easy. Loosen belt, unbolt old pulley, install new pulley and retighten belt. Link to comment Share on other sites More sharing options...
Virginia Posted December 9, 2018 Author Share Posted December 9, 2018 Thanks Link to comment Share on other sites More sharing options...
Virginia Posted December 11, 2018 Author Share Posted December 11, 2018 So, you say just loosen the belt.....Guess I'm doing something wrong because I can't get it loose. I have loosened those 3 bolts in the front and one down below the pulley on the front. The tensioning bolt is almost all the way out and the 2 bolts on the back are loose and still, I can't get the belt loose. What am I missing? Link to comment Share on other sites More sharing options...
JustEmptyEveryPocket Posted December 12, 2018 Share Posted December 12, 2018 Sometimes the slider is slightly frozen in place. I have had to smack the power steering reservoir with my hand a few times to get it to move. Link to comment Share on other sites More sharing options...
SVPete Posted December 12, 2018 Share Posted December 12, 2018 Sometimes I had to remove the rear bolts completely to allow the pump to move that little bit more. Link to comment Share on other sites More sharing options...
Virginia Posted December 12, 2018 Author Share Posted December 12, 2018 I found a bolt directly underneath the reservoir that needed to be loosened. Was the one that slides. Took me forever to find it. Once I loosened that, the rest was easy. The old idler pulley had eaten the ball bearings inside it. Good grief. No wonder it froze. Anyway, all is good now. Thanks Link to comment Share on other sites More sharing options...
cruiser54 Posted December 12, 2018 Share Posted December 12, 2018 Link to comment Share on other sites More sharing options...
Virginia Posted December 12, 2018 Author Share Posted December 12, 2018 Thanks Cruiser. I finally found that bottom bolt. I had to practically hang upside down in the engine compartment to see it. Once I got that loosened the belt popped right off and changing the idler pulley was easy. The bearings in there were all chewed up and several were missing. No wonder it locked up. I've printed your tips pages. Very helpful. Link to comment Share on other sites More sharing options...
olddude Posted December 14, 2018 Share Posted December 14, 2018 Time to invest into a inspection mirror. Every good mechanic should have one, not expensive, very handy. Link to comment Share on other sites More sharing options...
PIKE Posted December 14, 2018 Share Posted December 14, 2018 One of these too. Belt tension gauge. http://www.daycoproducts.com/dayco®-belt-tension-gauges http://www.daycoproducts.com/stuff/contentmgr/files/3/1378ea57bf6d09e5f72ce92bb8eff3ce/documents/belt_tension_recommendations__rev._4.18.13_.pdf Belt for 4.0 is a 6PK Link to comment Share on other sites More sharing options...
Virginia Posted December 15, 2018 Author Share Posted December 15, 2018 12 hours ago, olddude said: Time to invest into a inspection mirror. Every good mechanic should have one, not expensive, very handy. Thanks Link to comment Share on other sites More sharing options...
Virginia Posted December 15, 2018 Author Share Posted December 15, 2018 10 hours ago, PIKE said: One of these too. Belt tension gauge. http://www.daycoproducts.com/dayco®-belt-tension-gauges http://www.daycoproducts.com/stuff/contentmgr/files/3/1378ea57bf6d09e5f72ce92bb8eff3ce/documents/belt_tension_recommendations__rev._4.18.13_.pdf Belt for 4.0 is a 6PK Thanks Link to comment Share on other sites More sharing options...
