Kjell Posted November 17, 2018 Author Share Posted November 17, 2018 Replaced the other brakeline ( bypass line)to rear brakes , getting to be an expert on bleeding mj brakes Link to comment Share on other sites More sharing options...
Kjell Posted December 1, 2018 Author Share Posted December 1, 2018 New tires and new color on rims, changed the air filter maybe the engine gets some air now! Link to comment Share on other sites More sharing options...
Pete M Posted December 1, 2018 Share Posted December 1, 2018 you win the prize for the dirtiest MJ filter I've ever seen. Link to comment Share on other sites More sharing options...
Kjell Posted December 1, 2018 Author Share Posted December 1, 2018 On 12/1/2018 at 3:44 AM, Pete M said: you win the prize for the dirtiest MJ filter I've ever seen. Expand Yes dirtiest filter ever! including industry machinery maby PO did a homemade oilbath/dry filter solution or drived true a coal mine oil field every day Link to comment Share on other sites More sharing options...
Kjell Posted December 1, 2018 Author Share Posted December 1, 2018 Link to comment Share on other sites More sharing options...
Kjell Posted March 20, 2019 Author Share Posted March 20, 2019 The story goes on... 91 block, 7120 head ,HO intake ,Renix exhaust ,Renix TB, HO injektors .Special Thanks to Cruiser54 for all the info you put out on the Web Link to comment Share on other sites More sharing options...
MJXJjeepguy Posted March 20, 2019 Share Posted March 20, 2019 On 3/20/2019 at 10:28 AM, Kjell said: The story goes on... 91 block, 7120 head ,HO intake ,Renix exhaust ,Renix TB, HO injektors .Special Thanks to Cruiser54 for all the info you put out on the Web Expand I love it! Very clean engine bay! Link to comment Share on other sites More sharing options...
Kjell Posted March 20, 2019 Author Share Posted March 20, 2019 On 3/20/2019 at 10:58 AM, MJXJjeepguy said: I love it! Very clean engine bay! Expand Glad you like it! some work left with the heating hoses ,broke the heatvalve and havent replaced it yet Link to comment Share on other sites More sharing options...
MJXJjeepguy Posted March 20, 2019 Share Posted March 20, 2019 On 3/20/2019 at 1:25 PM, Kjell said: Glad you like it! some work left with the heating hoses ,broke the heatvalve and havent replaced it yet Expand Oh i have done that before by accident tried to pull hose hard and broken plastic piece of heat valve. lol Link to comment Share on other sites More sharing options...
89 MJ Posted March 20, 2019 Share Posted March 20, 2019 Can you tell if there is a noticeable power difference between the Renix motor and the HO? Link to comment Share on other sites More sharing options...
Kjell Posted March 20, 2019 Author Share Posted March 20, 2019 On 3/20/2019 at 3:54 PM, 89 MJ said: Can you tell if there is a noticeable power difference between the Renix motor and the HO? Expand The old motor was running on its last breath so its a big differens now , did use the HO head ,intake and injectors . Trottle body and rest is renix. The HO motor has more power so i belive its a noticeable difference, can't say for sure whit this hybrid/bastard engin Link to comment Share on other sites More sharing options...
Kjell Posted March 20, 2019 Author Share Posted March 20, 2019 On 3/20/2019 at 3:50 PM, MJXJjeepguy said: Oh i have done that before by accident tried to pull hose hard and broken plastic piece of heat valve. lol Expand exactly what happend! Don't mess whit tings that works Link to comment Share on other sites More sharing options...
Pete M Posted March 20, 2019 Share Posted March 20, 2019 On 3/20/2019 at 3:54 PM, 89 MJ said: Can you tell if there is a noticeable power difference between the Renix motor and the HO? Expand the HOs have a tiny bit more at the top end, but the renix has a tiny bot more at the bottom end. the engines are more or less the same. the later fuel injection systems are the big difference, but it's not in felt power, but rather more reliable wiring and 91-95 has OBD1 and 96+ is OBD2 for easier diagnoses. Link to comment Share on other sites More sharing options...
RustyRodder Posted March 20, 2019 Share Posted March 20, 2019 Looks great! What is that cover behind the battery? Makes the engine bay way cleaner! Link to comment Share on other sites More sharing options...
Kjell Posted March 20, 2019 Author Share Posted March 20, 2019 On 3/20/2019 at 7:05 PM, RustyRodder said: Looks great! What is that cover behind the battery? Makes the engine bay way cleaner! Expand Thanks RustyRodder It's original ...found it under the seat plastic screws where missing so i found some new that fitted and painted it red , was black and faded.. Link to comment Share on other sites More sharing options...
Kjell Posted March 20, 2019 Author Share Posted March 20, 2019 On 3/20/2019 at 6:28 PM, Pete M said: the HOs have a tiny bit more at the top end, but the renix has a tiny bot more at the bottom end. the engines are more or less the same. the later fuel injection systems are the big difference, but it's not in felt power, but rather more reliable wiring and 91-95 has OBD1 and 96+ is OBD2 for easier diagnoses. Expand Great Pete M hope i got more in both ends ...and not less . would like to try the Boch /Volvo injectors 0280155746 but it was to much snow in the junkyard and maybe widener /bore up the renix trottle body..... to be continued..... Link to comment Share on other sites More sharing options...
Pete M Posted March 20, 2019 Share Posted March 20, 2019 better injectors and the bored out TBs are good ways to boost power. if you haven't seen it yet, there's a guy in the "vendor" section of the classifieds that bores out the renix TBs. Link to comment Share on other sites More sharing options...
Kjell Posted March 20, 2019 Author Share Posted March 20, 2019 On 3/20/2019 at 9:25 PM, Pete M said: better injectors and the bored out TBs are good ways to boost power. if you haven't seen it yet, there's a guy in the "vendor" section of the classifieds that bores out the renix TBs. Expand yes i have seen it ,looks great . Trying to find one more TB so i have one extra to do some work on . no ruch yet tought i brake in the motor before i start experiment Link to comment Share on other sites More sharing options...
Kjell Posted April 1, 2019 Author Share Posted April 1, 2019 Out on a lake and slipping.found another classic vehicle Link to comment Share on other sites More sharing options...
BeaterComanche86 Posted April 1, 2019 Share Posted April 1, 2019 Kjell your MJ is coming along nice, looks real good for being parked since 01. Do you know what the purpose of the cover is behind the battery? Or what it’s even called? I think I wanna look for one of those, it really cleans up the engine bay. Link to comment Share on other sites More sharing options...
JMO413 Posted April 1, 2019 Share Posted April 1, 2019 On 4/1/2019 at 10:31 PM, BeaterComanche86 said: Kjell your MJ is coming along nice, looks real good for being parked since 01. Do you know what the purpose of the cover is behind the battery? Or what it’s even called? I think I wanna look for one of those, it really cleans up the engine bay. Expand It's the relay cover. Used is your only option. Mine was missing when I got my truck also. Really cleans up that side of the engine compartment. Link to comment Share on other sites More sharing options...
Kjell Posted April 2, 2019 Author Share Posted April 2, 2019 On 4/1/2019 at 10:31 PM, BeaterComanche86 said: Kjell your MJ is coming along nice, looks real good for being parked since 01. Do you know what the purpose of the cover is behind the battery? Or what it’s even called? I think I wanna look for one of those, it really cleans up the engine bay. Expand Thanks Beater glad you like it ! wouldent be so hard making a cover of a steel or aluminum plate, if you can't find a used one . Link to comment Share on other sites More sharing options...
BeaterComanche86 Posted April 3, 2019 Share Posted April 3, 2019 On 4/1/2019 at 11:15 PM, JMO413 said: It's the relay cover. Used is your only option. Mine was missing when I got my truck also. Really cleans up that side of the engine compartment. Expand Thanks JMO On 4/2/2019 at 7:34 PM, Kjell said: Thanks Beater glad you like it ! wouldent be so hard making a cover of a steel or aluminum plate, if you can't find a used one . Expand That’s not a bad idea, could save a bucks in the process Link to comment Share on other sites More sharing options...
Kjell Posted April 8, 2019 Author Share Posted April 8, 2019 So finaly found some Volvo/bosch injectors(0280 155 746),ended up snitching them out of a volvo that the guy at the junkyard drove to work with... still warm Installed injectors and scrapped the c101 connector at the same time I can't say what made the biggest difference connector or the injectors, Maybe I woke up some sensor that fell asleep ,can say it runs great much smoother and better gasresponse Link to comment Share on other sites More sharing options...
Pete M Posted April 8, 2019 Share Posted April 8, 2019 both are fantastic upgrades Link to comment Share on other sites More sharing options...
