Another Unknown Item
While filling my brake fluid reservoir during my brake overhaul I noticed this small cable that wasn’t connected to anything...looked around the engine but couldn’t determine where it goes.
Anybody recognize it??
13 minutes ago, Big Dan said:
Have you driven the vehicle or just wrenched on it so far? Looks like the throttle cable.
Sent from my Pixel 2 XL using Tapatalk
I’ve driven it, throttle is working unless it was changed out and this one just left there. I probably need to take a close look.
So I Googled the AW4 throttle valve cable...just about everything I’ve read mentions that having issues with this particular cable would lead to shifting issues, when I drove it today after the brake work it seemed to shift just fine.
More research needed on this.
It's not the transmission cable, that's visible just at the left edge of the frame.
Some sort of cruise control cable or maybe hood latch cable that wasn't removed completely?  I can't think of what else would have a cable.
2 hours ago, DirtyComanche said:
Not really a useful mod with an auto.  :confused:
True, very true.  But I'm not even going to try to fathom why people do what they do to Jeeps of all sizes and sorts.  I've seen some strange stuff, as I'm sure you have.
Okay, I traced it over to some bottle looking contraption tucked in between the air filter box and fender. From what I can see the only 2 connections this “bottle” has is the other end of this mysterious cable and what appears to be a vacuum line that runs over and connects to a tee that comes off the manifold. I’m gonna dig through the FSM and see if I can come up with anything. Here’s a pic of the bottle
1 minute ago, Big Dan said:
That looks like a cruise control servo.. But mine isn't in that area.
It’s equipped with cruise control. I noticed a hole, looks like a cable connection hole, located on the throttle linkage bracket, wondering if it goes there. I’ll start researching it from the cruise control side of things.
3 minutes ago, 87MJTIM said:
The PO must have moved it out of the way but left it intact
Hey 87, do you have cruise on yours? Could you take a pic on how it connects to the throttle linkage? Details are sketchy on this but I’m still looking.
Hey guys, checking out for the weekend but I’m sure I’ll find time to check the site. Headed to the beach, the wife wanted to go for our anniversary, can’t argue with that.
Appreciate all the help.
I will, but I’m away currently. Be back June 11
