krustyballer16 Posted May 3, 2018 Share Posted May 3, 2018 These seat brackets are copies of bench seat brackets. They make it so you can mount a bench seat, mj/xj seats or you can modify them to fit any seat. These are the pieces that bolt to the floor. You can either bolt or weld them to the seat frame. This is a set, left and right, front and rear mounts, 4 pieces. They'll come bare steel. $115 shipped.  The roll bar brackets go under the bed and bolt to the bed riser on the frame and to the bottom side of the bed, up to your roll bar. Includes front and rear/wheel well foot pad backing plate (not pictured) They'll fit long bed and short bed. This is a set, left and right, 8 pieces They'll come bare steel, new mounting hardware included. Holes may need to be redrilled to fit these M12 bolts. $130 shipped.  If both sets are ordered at the same time, I'll ship them for $215.  MEMBERS IN CANADA: IT COST AN EXTRA $35 TO SHIP THEM WAY UP NORTH. SO ADD THAT WHEN SENDING MONEY. THANKS  I take PayPal. paypal.me/krustyballer16 Or krustyballer16@aim.com  When paying, please send money through "friends and family" and include your username and full name and address in the notes  Comment with your order and I'll update this post with a list and once we get 20, between here and Facebook (or may have to run 40 sets) I'll order them.  May take up to 3 weeks for them to arrive (lasers, presses, shipping)   Any questions, just ask. ***Roll bar brackets*** -Kryptronic-paid (gave me the set to copy for these. Thanks) -Limeyjeeper-paid -Foxbody663 -strokermjcomanche-paid -rustyrodder-paid -goose_xj88 -fiatslug87 -budwisr-paid -lucas7667 -Dancome433 -Dzimm -Dkenitz-paid     Seat brackets -BigDan-paid -Dkenitz-paid -dirtbound (will be getting the prototype set)  Seat brackets w/1" rise -Hornbrod -Kryptronic-paid with possibility of not making these       Link to comment Share on other sites More sharing options...
foxboy633 Posted May 3, 2018 Share Posted May 3, 2018 I'll snag a set of rollbar brakets! could you PM me where to send payment to? and can you ship to Canada? Link to comment Share on other sites More sharing options...
kryptronic Posted May 3, 2018 Share Posted May 3, 2018 PAID and PM sent for one set of rollbar brackets. Thank you for doing this, these look fantastic. I'm really excited to be able to correctly mount my factory rollbar. These brackets look like the factory ones, but much heavier duty in design.  I'd be interested in bench seat brackets if on a later run you did a variant that had 1" to 1.5" more height. Just throwing that out there for consideration. Link to comment Share on other sites More sharing options...
Pete M Posted May 3, 2018 Share Posted May 3, 2018 25 minutes ago, kryptronic said: I'd be interested in bench seat brackets if on a later run you did a variant that had 1" to 1.5" more height. Just throwing that out there for consideration.  a 1" riser made from 1x1 tubing should be easy enough to do.   Link to comment Share on other sites More sharing options...
krustyballer16 Posted May 3, 2018 Author Share Posted May 3, 2018 38 minutes ago, Pete M said: Â a 1" riser made from 1x1 tubing should be easy enough to do. Â Â Yes, easier and cheaper than modifying the seat brackets. Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 3, 2018 Share Posted May 3, 2018 25 minutes ago, krustyballer16 said: Yes, easier and cheaper than modifying the seat brackets. Â Go ahead and make a bolt-on set using the existing floor studs. I'll buy it and be your test pig. Â Â Â Link to comment Share on other sites More sharing options...
krustyballer16 Posted May 3, 2018 Author Share Posted May 3, 2018 1 hour ago, HOrnbrod said: Â Go ahead and make a bolt-on set using the existing floor studs. I'll buy it and be your test pig. Â Â Â Do what? Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 3, 2018 Share Posted May 3, 2018 11 minutes ago, krustyballer16 said: Do what? Â Bolt-on ~1" seat spacers / raisers. Link to comment Share on other sites More sharing options...
Pete M Posted May 3, 2018 Share Posted May 3, 2018 just get 4 pieces of 1x1 tubing about 7" (?) long and straddle then side-to-side between and on top of the 2 brackets. punch holes in the appropriate places and get longer bolts to join the seat bits to the floor brackets. done.   Link to comment Share on other sites More sharing options...
krustyballer16 Posted May 3, 2018 Author Share Posted May 3, 2018 Yep!^^^^ Â Could be done for extra dolla dolla bills, yall Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 3, 2018 Share Posted May 3, 2018 Krusty makes strong stuff. How much? Pic? Don't want no weak-azz thinwall tubing. Let's see a design when you get some spare time, that is if you have any spare time. Link to comment Share on other sites More sharing options...
krustyballer16 Posted May 3, 2018 Author Share Posted May 3, 2018 What's the reason for 1" higher? Link to comment Share on other sites More sharing options...
Pete M Posted May 3, 2018 Share Posted May 3, 2018 it comes stronger    Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 3, 2018 Share Posted May 3, 2018 8 minutes ago, krustyballer16 said: What's the reason for 1" higher? Â A compromise for my shorter half. I've already raised her JKU drivers seat with a spacer kit. Link to comment Share on other sites More sharing options...
kryptronic Posted May 3, 2018 Share Posted May 3, 2018 44 minutes ago, krustyballer16 said: What's the reason for 1" higher? I'm 6'2". A little higher gives the legs some room to stretch. Could do spacers, but I'd rather have taller brackets.  Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 3, 2018 Share Posted May 3, 2018 5 minutes ago, kryptronic said: Could do spacers, but I'd rather have taller brackets.   Me too. Good luck finding any. I can't.. Link to comment Share on other sites More sharing options...
krustyballer16 Posted May 3, 2018 Author Share Posted May 3, 2018 I can make a 2nd size. Will be $10 more cuz I'm sure I'll have to pay for the 35 seconds itll take to modify for a 2nd size lol  1" or 1.5"? I won't be able to guarantee how they fit height wise.... Link to comment Share on other sites More sharing options...
kryptronic Posted May 3, 2018 Share Posted May 3, 2018 (edited) 2 hours ago, krustyballer16 said: I can make a 2nd size. Will be $10 more cuz I'm sure I'll have to pay for the 35 seconds itll take to modify for a 2nd size lol  1" or 1.5"? I won't be able to guarantee how they fit height wise....  1" would be perfect in my opinion.  Edited May 4, 2018 by kryptronic Removed the rest of my reply. Made no sense when I looked at the brackets in my truck. Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 4, 2018 Share Posted May 4, 2018 I must have missed something - I don't see a design. Link to comment Share on other sites More sharing options...
Limeyjeeper Posted May 4, 2018 Share Posted May 4, 2018 Paid Link to comment Share on other sites More sharing options...
kryptronic Posted May 4, 2018 Share Posted May 4, 2018 1 hour ago, HOrnbrod said: I must have missed something - I don't see a design.  Krusty is contemplating making a small run of taller seat brackets at a slightly higer price. I think you're under the impression he might be making risers. Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 4, 2018 Share Posted May 4, 2018 1 minute ago, kryptronic said:  Krusty is contemplating making a small run of taller seat brackets at a slightly higer price. I think you're under the impression he might be making risers.  Roger. Count me in then for a set Krusty - same conditions as kryptonic stated are fine with me me. Link to comment Share on other sites More sharing options...
krustyballer16 Posted May 4, 2018 Author Share Posted May 4, 2018 Order lists are update of who wants what and who has paid. Thanks  If the list fills up over the weekend I'll order Tuesday! Facebook orders are about the same as on here, almost to 20 each! Link to comment Share on other sites More sharing options...
Jeep Driver Posted May 4, 2018 Share Posted May 4, 2018 Your seat brackets look nice. Link to comment Share on other sites More sharing options...
dkenitz Posted May 6, 2018 Share Posted May 6, 2018 Just saw this new post. I need to think about the taller seat brackets. That may be a good compromise for me and the misses. Will send payment as soon as I make a decision. Thanks! Link to comment Share on other sites More sharing options...
