Egm89 Posted May 20, 2018 Share Posted May 20, 2018 Following this post lol, very interested on the renix 60 mm Link to comment Share on other sites More sharing options...
MeanLemons Posted May 26, 2018 Author Share Posted May 26, 2018 15% off the throttle bodies this weekend! Link to comment Share on other sites More sharing options...
TheDude Posted May 26, 2018 Share Posted May 26, 2018 Does that count towards the Renix ones?Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
MeanLemons Posted May 26, 2018 Author Share Posted May 26, 2018 I don’t have any renix ones done. I still need to re-work the holding jig to center it. So yes thats a good question. I ll clarify my statement above 15% off for 91+ throttle bodies. Link to comment Share on other sites More sharing options...
Wounded_Fighter Posted June 16, 2018 Share Posted June 16, 2018 +1 for renix, +1 follow Link to comment Share on other sites More sharing options...
MeanLemons Posted June 17, 2018 Author Share Posted June 17, 2018 I have two more renix TBs on the way. Probably few weeks or so. As of that one I messed up... I welded the hole shut and I’m gonna bore through it again. Link to comment Share on other sites More sharing options...
MeanLemons Posted June 26, 2018 Author Share Posted June 26, 2018 Finally had time to take the good renix TB outta my MJ and successfully bored it out to 60mm without blowing through the wall. so I guess you could say I’m ready for renix version now on. Link to comment Share on other sites More sharing options...
Wounded_Fighter Posted June 26, 2018 Share Posted June 26, 2018 10 hours ago, MeanLemons said: Finally had time to take the good renix TB outta my MJ and successfully bored it out to 60mm without blowing through the wall. so I guess you could say I’m ready for renix version now on. Take any pics of the new shiny renix ver? Link to comment Share on other sites More sharing options...
MeanLemons Posted June 26, 2018 Author Share Posted June 26, 2018 Not yet. I brought it into work for some glass beading I should have pics up tonight when I bring it back home for re-assembly. Link to comment Share on other sites More sharing options...
MeanLemons Posted June 26, 2018 Author Share Posted June 26, 2018 Here are the pictures of the renix TB Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 26, 2018 Share Posted June 26, 2018 53 minutes ago, MeanLemons said: Here are the pictures of the renix TB What's the Renix intake TB hole size? Link to comment Share on other sites More sharing options...
MeanLemons Posted June 26, 2018 Author Share Posted June 26, 2018 Before or after? Link to comment Share on other sites More sharing options...
MeanLemons Posted July 2, 2018 Author Share Posted July 2, 2018 I got two more renix cores to play with. I ll post when they are ready Link to comment Share on other sites More sharing options...
WahooSteeler Posted July 2, 2018 Share Posted July 2, 2018 7 hours ago, MeanLemons said: I got two more renix cores to play with. I ll post when they are ready Have you put a price on these yet? Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 2, 2018 Share Posted July 2, 2018 On 6/26/2018 at 5:05 PM, MeanLemons said: Before or after? The stock size. The HOs are 62mm, just curious if the Renix is close.. Link to comment Share on other sites More sharing options...
MeanLemons Posted July 2, 2018 Author Share Posted July 2, 2018 35 minutes ago, WahooSteeler said: Have you put a price on these yet? I thought I did.. anyway. It’s $130 shipped. It’s $5 more than HO throttle bodies because it’s significantly more work. Link to comment Share on other sites More sharing options...
MeanLemons Posted July 2, 2018 Author Share Posted July 2, 2018 4 minutes ago, HOrnbrod said: The stock size. The HOs are 62mm, just curious if the Renix is close.. Stock size for the HO is 60mm at the top but tapers down to 56mm at the bottom (bottleneck). As for renix, the stock size is 52mm. I bore it out to 60mm Link to comment Share on other sites More sharing options...
WahooSteeler Posted July 2, 2018 Share Posted July 2, 2018 3 minutes ago, MeanLemons said: I thought I did.. anyway. It’s $130 shipped. It’s $5 more than HO throttle bodies because it’s significantly more work. Thanks! My bad if I missed it posted before........... Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 2, 2018 Share Posted July 2, 2018 2 minutes ago, MeanLemons said: Stock size for the HO is 60mm at the top but tapers down to 56mm at the bottom (bottleneck). I mean the Renix intake manifold hole. I have a 99+ intake on my HO and the intake hole is 62mm. Using a bored throttle body that's been punched out to 62mm all the way through. So it's a nice straight shot.. Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 2, 2018 Share Posted July 2, 2018 9 minutes ago, MeanLemons said: As for renix, the stock size is 52mm. I bore it out to 60mm Thanks, didn't realize it was so small. Link to comment Share on other sites More sharing options...
MeanLemons Posted July 3, 2018 Author Share Posted July 3, 2018 I just went out and measured the renix intake on my MJ. The intake hole is 2.438”. (62mm). Link to comment Share on other sites More sharing options...
MeanLemons Posted July 3, 2018 Author Share Posted July 3, 2018 I have bunch of intakes sitting here from different years. They all measure the same; 2.440 diameter Link to comment Share on other sites More sharing options...
MeanLemons Posted July 3, 2018 Author Share Posted July 3, 2018 Here’s a pic of stock renix butterfly on top of stock HO butterfly plate and a pic of renix on top top of my 62mm plate Link to comment Share on other sites More sharing options...
MeanLemons Posted July 3, 2018 Author Share Posted July 3, 2018 Link to comment Share on other sites More sharing options...
MeanLemons Posted July 3, 2018 Author Share Posted July 3, 2018 A customer is now happy. With 10 smiles Link to comment Share on other sites More sharing options...
