Hi, I've got a problem I'm hoping someone here can point me to a solution for. I've got a '91 Comanche that tries to die when I press the clutch to decelerate. Sometimes it doesn't, sometimes it does. If I press the gas petal to give it just a little juice when I do press the clutch to decelerate, it won't die and will idle just fine. So, that's my main way of working around this. However, I'd love a real solution. Thanks a million.
Sorry, I didn't get notified of responses. I'll check back better.
Pete, it idles just fine when started/sitting.
cruiser, I have no idea, but I could mention that to my husband and son. They work on everything. I just inquire as needed when stumped, like this. lol
2 hours ago, aprildaisy said:
... IAC is one off of something else in the yard and that could be worn...
If it's the IAC, I'm pretty sure the IAC can't be "one off".  More likely dirty.  Take it out, clean it with carb cleaner...be gentle with it when handling the pintle...(tip)... so's not to damage it.
Well, just replaced the IAC and, from the looks of the one taken out, it was definitely a factor! I haven't driven it yet, but both my Son and Husband say it runs and sounds better just idling. Thank you so much for helping direct me there!!! :D
On 4/23/2018 at 11:45 PM, cruiser54 said:
Ever clean your throttle body and IAC?
http://cruiser54.com/?p=60
That's great. After reading this I removed my IAC on Saturday, when I was tinkering, mostly out of curiosity.  It had some stuff on it that I cleaned off and scuffed it with some fine sandpaper.  It immediately idled more smoothly and went from an chronically wonky 500-700 RPM.  Now it's rock solid at 750.   :L:
Well...while changing that part helped it along, it didn't fix the problem. Sigh. lol  Paradise, glad this helped you!! :D
  • 3 months later...
ONLY when you press the clutch? is there a sharp rpm drop while shifting?
with engine hot and idling and transmission in neutral, press the clutch... see if RPMs drop, if so the throwout bearing or internal cylinder is bad, normally when you press the clutch the THB/IC turn with the pressure plate, if the bearing is damaged or stuck it will bring the rpms down enough to stall it...
So, do you always press in the clutch just to decelerate?  Have you tried just letting up on the gas, braking, downshifting and pushing in the clutch when you stop?  I may be wrong but that's how I've always driven a stick.  Just sayin'
clean the throttle body.....................
Originally by TJWalker of CherokeeForum & JeepForum
dirty IAC
The Idle Air Control (IAC) is mounted on the back of the throttle body (front for ’87-’90).
The valve controls the idle speed of the engine by controlling the amount of air flowing through the air control passage. It consists of a stepper motor that moves a pintle shaped plunger in and out of the air control passage. When the valve plunger is retracted, the air control passage flows more air which raises the idle speed. When the valve plunger is extended, the air control passage flows less air which lowers the idle speed.
Over time and miles, the IAC can get carboned up which can have an adverse affect on idle quality. Cleaning the IAC may restore proper function and is an easy procedure to perform and good preventive maintenance so it is never a bad idea. This should be part of a normal tune-up procedure and whenever idle/stalling issues are present.
CLEANING THE JEEP 4.0 IDLE AIR CONTROL
dirty renix throttle body
  1. Remove the air filter cover, associated hoses and the rubber boot that goes from the air filter cover to the throttle body. Remove the IAC with a Torx driver (2 bolts; one can be kind of hard to get to). On ’91 and later, it may be easier to just remove the whole throttle body. Be sure to use a new throttle body to manifold gasket when reinstalling.
  2. “Gently” wiggle out the IAC from the throttle body. Gasket/O-ring on the IAC can be re-used if it is not damaged
  3. Clean the IAC with a spray can of throttle body cleaner; inexpensive and available at any place that sells auto parts. Throttle body cleaner is recommended rather than carburetor cleaner as it is less harsh, safe for throttle body coatings and oxygen sensors. Use cleaner, a rag and a toothbrush and or Q-Tips. Be gentle; don’t twist or pull on the pintle that protrudes from the IAC as it is fragile and you could damage it.
  4. Thoroughly spray clean and flush where the IAC seats in the throttle body with the same spray cleaner.
  5. It is also a good idea to clean the entire throttle body bore itself, the butterfly valve inside of the throttle body and it’s edges, and all associated linkage as long as you have things disassembled.
dirty chrysler throttle body
wait, what does the IAC has to do with it? if it was dirty cleaning it will help smoothing idling rpms, whe  you press the clutch you are releasing the engine from the transmission, is supposed to run free, why woudl the rpms drop? a dirty IAC will give overall low rpms at idle...
Assuming normal manual transmission operation, when you push in the clutch pedal, you also have released the throttle. The engine returns to idle, so you need the IAC to keep the engine running properly. If it's sticking shut, or otherwise not opening far enough, the engine will die.
That’s where my mind went. Or I just pop it in neutral
On 4/25/2018 at 7:59 PM, Ωhm said:
Flame-out on decel, my guess is spark plugs, unless, of course, they had just been changed recently.
On 4/26/2018 at 9:06 AM, aprildaisy said:
A tune up was done recently, so that's not it.
What were the spark plugs gap set to? Not sure exactly what the specs calls for. Anyone?
