crumbscomanche Posted April 11, 2018 Share Posted April 11, 2018 So my hood has a decent bit of damage from an accident the PO had. Does anyone know if a 98+ is the same as previous years? I have an extra and it looks pretty damn close.. thanks! Link to comment Share on other sites More sharing options...
ComancheKid45 Posted April 11, 2018 Share Posted April 11, 2018 I believe all hoods interchange from 87-01. Link to comment Share on other sites More sharing options...
schardein Posted April 12, 2018 Share Posted April 12, 2018 No real life experience, but my research shows they all interchange. I did notice that the holes to attach the underhood light changed sometime between 91-93. So you might find other small differences. Link to comment Share on other sites More sharing options...
Dzimm Posted April 12, 2018 Share Posted April 12, 2018 Yes they do. Like Schardein said above, there are some small differences but they are the same size. Link to comment Share on other sites More sharing options...
shelbyluvv Posted April 12, 2018 Share Posted April 12, 2018 84-86 are different Link to comment Share on other sites More sharing options...
Eagle Posted April 13, 2018 Share Posted April 13, 2018 2 hours ago, shelbyluvv said: 84-86 are different Yes, but the difference has to do with the two latches at the outer corners. The 84-86 hoods didn't have those. I believe that's mostly a matter of drilling a couple of holes for attachment. Not certain, but I believe the basic hood is the same and could be adapted to work. Link to comment Share on other sites More sharing options...
shelbyluvv Posted April 13, 2018 Share Posted April 13, 2018 It can't be modified. Totally different Edit: it can be but why would you? It is a $#!& ton of work and you better be a master bodyman. Link to comment Share on other sites More sharing options...
crumbscomanche Posted April 13, 2018 Author Share Posted April 13, 2018 thanks - is the style the same? not sure if that makes but they literally look identical from the top Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 13, 2018 Share Posted April 13, 2018 When I got my Reflexxion cowl hood years ago, it was advertised as fitting all XJ/MJ models 1984 through 2001, but some drilling was required on certain models for the hood hinges. It was an easy bolt-on for me, but there must have been some difference in the hood hinge mounting holes. And I don't know what these differences were.. Link to comment Share on other sites More sharing options...
Dzimm Posted April 13, 2018 Share Posted April 13, 2018 11 hours ago, crumbscomanche said: thanks - is the style the same? not sure if that makes but they literally look identical from the top Not sure what you are asking here but yes they do look the same from the outside and the body lines match up properly. Link to comment Share on other sites More sharing options...
shelbyluvv Posted April 13, 2018 Share Posted April 13, 2018 You can put a 87+ hood on a 84-86 easily. You can NOT use a 84-86 hood easily on a 87+. All hoods from 1987 and newer will bolt on a 1987 and newer truck. This is fact because I have done it, owned both trucks and tried it. Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 13, 2018 Share Posted April 13, 2018 12 minutes ago, shelbyluvv said: You can NOT use a 84-86 hood easily on a 87+. What makes it not easy? Guessing some hinge difference? Link to comment Share on other sites More sharing options...
Kyleinreallife Posted April 13, 2018 Share Posted April 13, 2018 Bruh, I’m a fabricator, find a hood, we’ll make it work!87 XJ Wagoneer Ltd I-6 NP242 AW4 HPD30/D44 Link to comment Share on other sites More sharing options...
shelbyluvv Posted April 13, 2018 Share Posted April 13, 2018 2 minutes ago, HOrnbrod said: What makes it not easy? Guessing some hinge difference? The latches are different. 87+ is on the corners, cut into the front of the hood. 86- latch is in the center. It is not worth the work to modify the hoods. Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 13, 2018 Share Posted April 13, 2018 2 minutes ago, shelbyluvv said: The latches are different. 87+ is on the corners, cut into the front of the hood. 86- latch is in the center. It is not worth the work to modify the hoods. Link to comment Share on other sites More sharing options...
shelbyluvv Posted April 13, 2018 Share Posted April 13, 2018 This is how you put an 87+ hood on a 86 Link to comment Share on other sites More sharing options...
johnj92131 Posted April 13, 2018 Share Posted April 13, 2018 Hood prop is also in a different location. The 91 has hood prop on passenger side of engine compartment The 86 diesel has hood prop on front of radiator Link to comment Share on other sites More sharing options...
crumbscomanche Posted April 13, 2018 Author Share Posted April 13, 2018 thanks all. This is what I was looking for. Will let you know how it goes! Link to comment Share on other sites More sharing options...
krustyballer16 Posted April 14, 2018 Share Posted April 14, 2018 For how plentiful hoods are, why try to modify? Unless you can't find an 84- 86 hood to fit your 86...Sent from my SM-G892A using Tapatalk Link to comment Share on other sites More sharing options...
