JEEPTRK Posted December 28, 2017 Share Posted December 28, 2017 My 89 Jeep comanche was stolen this morning. Baltic Metallic (blue) with a white Jeraco Cap. 5 speed and bench seat. If anyone hears anything please contact me at 610-864-1582 Location West Chester, PA Link to comment Share on other sites More sharing options...
Pete M Posted December 28, 2017 Share Posted December 28, 2017 that sucks. I hate thieves Link to comment Share on other sites More sharing options...
sinkrun Posted December 28, 2017 Share Posted December 28, 2017 In PA also will keep a eye out. Care to share more of how it happened? Link to comment Share on other sites More sharing options...
Dzimm Posted December 29, 2017 Share Posted December 29, 2017 Posting some pictures would be good so if we see it elsewhere on the web we can report! Hopefully it's back home soon! Link to comment Share on other sites More sharing options...
johnj92131 Posted December 29, 2017 Share Posted December 29, 2017 I have had a couple of cars stolen over the years. It just really sucks. Most of the time it is just some STUPID Chump who needs a ride a few miles and the car will be recovered in a week or so. One time I found some Fellow in the middle of trying to steal my car and managed to scare the you know what out of him. He took of running up hill and left my car with some cut ignition wires. Link to comment Share on other sites More sharing options...
Skorpyo Posted December 29, 2017 Share Posted December 29, 2017 Photos from FB posted by same individual Link to comment Share on other sites More sharing options...
Jeep Driver Posted December 29, 2017 Share Posted December 29, 2017 That was stolen for the goodies.........stripped by now. Round here, they'd find the carcass burned out in a couple of weeks. Link to comment Share on other sites More sharing options...
johnj92131 Posted December 29, 2017 Share Posted December 29, 2017 On 12/29/2017 at 2:40 PM, Jeep Driver said: That was stolen for the goodies.........stripped by now. Round here, they'd find the carcass burned out in a couple of weeks. Expand About 5 years ago, my Comanche was stolen from a friends house in Tijuana. My friend's brother in law was a Tijuana cop. Within 12 hours, the truck was recovered. Cops found 4 guys stripping the truck and managed to catch one of them. The fellow got 7 years in prison! Link to comment Share on other sites More sharing options...
DirtyComanche Posted December 29, 2017 Share Posted December 29, 2017 Hope it works out better than the last one I recall being stolen off here, which was torched. Link to comment Share on other sites More sharing options...
Pete M Posted December 30, 2017 Share Posted December 30, 2017 everyone should have a killswitch somewhere. at least then the truck might remain behind as they steal stuff from it. thieves suck. Link to comment Share on other sites More sharing options...
kook911 Posted December 31, 2017 Share Posted December 31, 2017 On 12/30/2017 at 4:27 PM, Pete M said: everyone should have a killswitch somewhere. at least then the truck might remain behind as they steal stuff from it. thieves suck. Expand Care to share how to do this. I read a couple of threads but not to sure on the method. Link to comment Share on other sites More sharing options...
Pete M Posted December 31, 2017 Share Posted December 31, 2017 you need to tap into a line that is important for the truck to run. I suggest the fuel pump line where it connects to the inline resistor in the engine bay on the dr side inner fender. (whitish ceramic thing about 3" long with 2 wires coming out of it) Disconnecting here will allow the truck to start, but cause it to die after a couple seconds (the resistor is there for reduced noise from the pump and the computer by passes it at startup). unlike a traditional killswitch that makes the truck not start at all and then the thief think to look for a switch, this will make your truck look like just a pile of crap and maybe he'll go away without any more damage than your doorlock and ignition. Link to comment Share on other sites More sharing options...
Pete M Posted December 31, 2017 Share Posted December 31, 2017 oh, and if you do a simple inline switch, you'll need to remember to turn it off each time or else it won't work as a deterrent. the switch will need to be located in a spot that is both easy to reach for you, but hard to find for anyone else. but since you're not using it as the cranking switch, it can be somewhere that is easy to reach as you get into the truck or before your buckle up. Link to comment Share on other sites More sharing options...
youngfred Posted December 31, 2017 Share Posted December 31, 2017 ... On my 69 el Camino, I wired a switch, in-line with the HEI Distributor's - +12v. wire that ran to the Ignition Switch. Inside the cab, I installed a 1/4" jack, like those used on the old headphones from that 'other world'(analog-a). Thieves look for a switch or something that moves. The 1/4" Female Jack is flat, so trying to feel around for a switch, the flat Female Jack will be bypassed. My keychain would separate in half with the push of a button, so My Key was the 1/4" Male Plug that had the two leads Soldered together, internally, in order to complete the circuit, when the ignition switch was used. Without the 1/4" male plug installed into the jack, the motor would turn but no power got to the distributor. I always worried about - current draw, through the 1/4" Plug/Jack circuit which was set up for audio circuits but it was never a problem. I never lost the elky. youngfred Link to comment Share on other sites More sharing options...
Dzimm Posted January 1, 2018 Share Posted January 1, 2018 On 12/31/2017 at 11:06 PM, youngfred said: ... On my 69 el Camino, I wired a switch, in-line with the HEI Distributor's - +12v. wire that ran to the Ignition Switch. Inside the cab, I installed a 1/4" jack, like those used on the old headphones from that 'other world'(analog-a). Thieves look for a switch or something that moves. The 1/4" Female Jack is flat, so trying to feel around for a switch, the flat Female Jack will be bypassed. My keychain would separate in half with the push of a button, so My Key was the 1/4" Male Plug that had the two leads Soldered together, internally, in order to complete the circuit, when the ignition switch was used. Without the 1/4" male plug installed into the jack, the motor would turn but no power got to the distributor. I always worried about - current draw, through the 1/4" Plug/Jack circuit which was set up for audio circuits but it was never a problem. I never lost the elky. youngfred Expand This is genius! Link to comment Share on other sites More sharing options...
Pete M Posted January 1, 2018 Share Posted January 1, 2018 combine that with the fuel line and you're golden! I may have to steal that idea (pun intended ) Link to comment Share on other sites More sharing options...
Eagle Posted January 1, 2018 Share Posted January 1, 2018 On 12/31/2017 at 10:43 PM, Pete M said: oh, and if you do a simple inline switch, you'll need to remember to turn it off each time or else it won't work as a deterrent. the switch will need to be located in a spot that is both easy to reach for you, but hard to find for anyone else. but since you're not using it as the cranking switch, it can be somewhere that is easy to reach as you get into the truck or before your buckle up. Expand Get a switch panel from an XJ and use the slot for the rear defogger or driving lights as the kill switch. If you have an auto tranny, hard wire the tranny power-comfort switch to "Power" and use that switch. Link to comment Share on other sites More sharing options...
