rylee144 Posted November 7, 2017 Share Posted November 7, 2017 Hi all- I found a gauge cluster that claims to be for a 1988. I have attached the photos of my current cluster and a link to the one for sale. The part number is off but rightfully so because they look different. Did they make two styles in 1988? Can I swap this one in? Thanks https://www.ebay.com/itm/JEEP-CHEROKEE-XJ-INSTRUMENT-GAUGE-CLUSTER-PART-ES895600284-OEM-1988/152775553112?hash=item239221f058:g:CFsAAOSwrFtZ~5ed&vxp=mtr Link to comment Share on other sites More sharing options...
coolwind57 Posted November 7, 2017 Share Posted November 7, 2017 Can one assume the difference is that one is for Auto transmission (no tachometer) and one is for manual (tachometer)? Sorry I am not answering your question, but I'm in the market for upgraded gauges myself. I want to go from idiot gauges (automatic transmission) to full gauge setup. Link to comment Share on other sites More sharing options...
rylee144 Posted November 7, 2017 Author Share Posted November 7, 2017 Mine is a manual with no Tac Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 7, 2017 Share Posted November 7, 2017 Auto or manual trannsmission has nothing to do with the type of cluster. Both transmissions can use either idiot light or full gauge clusters. General cluster rule of thumb is blue case = Renix, white case = HO. The Renix clusters have a manual speedometers and use cables. There are some differences in the cables between the years. HO speedos are all electronic. Link to comment Share on other sites More sharing options...
coolwind57 Posted November 7, 2017 Share Posted November 7, 2017 3 minutes ago, HOrnbrod said: Auto or manual trannsmission has nothing to do with the type of cluster. Both transmissions can use either idiot light or full gauge clusters. General cluster rule of thumb is blue case = Renix, white case = HO. The Renix clusters have a manual speedometers and use cables. There are some differences in the cables between the years. HO speedos are all electronic. Did they make clusters for automatic transmission trucks with tachs? Link to comment Share on other sites More sharing options...
Green Mesa XJ Posted November 7, 2017 Share Posted November 7, 2017 I’ve noticed both styles of clusters. I’ve always thought the early blue were discontinued by the HO years but I seen some HO with simple clusters that look like the early non gauge idiot light clusters. I’m using a full gauge cluster like that 88, mine I think is off a 89 or 90. as long as it a mechanical speedometer it should work. Only difference in the eighties is the speedometer cable changes about 1987, the early 84-86 use a slightly different way of securing to the back of the speedometer. I believe I was able to still plug my 85 speedometer cable into the 89 cluster. Eventually I did order the correct cable. Sent from my iPhone using Tapatalk Pro Link to comment Share on other sites More sharing options...
Minuit Posted November 7, 2017 Share Posted November 7, 2017 44 minutes ago, coolwind57 said: Did they make clusters for automatic transmission trucks with tachs? Floor shift, yes. Column shift, no. Guess they didn't feel like making a tach cluster with the gear indicator. Link to comment Share on other sites More sharing options...
johnj92131 Posted November 7, 2017 Share Posted November 7, 2017 The cluster in the picture is 1986/87 style speedometer face. Notice the sweep for 7:00 to 4:00? The eBay cluster is a late 87+ to 1990 style. Notice the 9:00 to 4:00 sweep? 1986 had a different speedometer cable connection to the speedometer. I can not tell you if the pictured cluster is 86 or 87. That sweep was offered with both speedometer cables Link to comment Share on other sites More sharing options...
johnj92131 Posted November 7, 2017 Share Posted November 7, 2017 6 minutes ago, Minuit said: Floor shift, yes. Column shift, no. Guess they didn't feel like making a tach cluster with the gear indicator. I have never seen a picture of a Factory tach for the column shift. Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 8, 2017 Share Posted November 8, 2017 2 hours ago, Minuit said: Floor shift, yes. Column shift, no. Guess they didn't feel like making a tach cluster with the gear indicator. Good point. :headslap: Link to comment Share on other sites More sharing options...
mass.casualty Posted November 25, 2017 Share Posted November 25, 2017 Following as i would like to swap the stock base model blue, full idiot light cluster for the black/white/red cluster. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
kryptronic Posted November 26, 2017 Share Posted November 26, 2017 I'm interested in swapping an earlier blue Renix cluster into my HO. Am I crazy? I don't mind pulling the clusters apart and mixing and matching parts. The sweep on the faceplates for the tach and speedo look off. Has anybody done this? Just for looks as I'm doing a throwback AMC interior. Link to comment Share on other sites More sharing options...
schardein Posted November 26, 2017 Share Posted November 26, 2017 The "blue" style gauges were available on the HO models. I have seen them on rare occasions. Here is a pic of an HO cluster I pulled from a 1991 Cherokee. It was a police model with a column shift (so the trans indicator is present), 120mph speedo (7 to 4 sweep) with trip odometer. Also an extended idle switch where the fog light switch would normally be. I swapped this into my MJ, plug and play after switching the senders and adjusting the odometer to match my miles (yes it can be done on HO electronic speedos). My original cluster was idiot lights, but it did have the blue gauges. Also, no trip odometer. I'm not sure, but I think these were the only options for blue gauges in the HO years, either the idiot light cluster or these hard to find police clusters. I've also seen the police cluster like this without the auto trans indicator. Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 26, 2017 Share Posted November 26, 2017 I like the UK cluster. Link to comment Share on other sites More sharing options...
yxmj Posted November 26, 2017 Share Posted November 26, 2017 That's just Canadian Eh... Link to comment Share on other sites More sharing options...
kryptronic Posted November 26, 2017 Share Posted November 26, 2017 1 hour ago, schardein said: I've also seen the police cluster like this without the auto trans indicator. I need to be on the lookout for this one with a tachometer. Sounds like exactly what I need as I've got an AX15. Wondering if any HO XJ police models would have been manuals. Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 26, 2017 Share Posted November 26, 2017 1 hour ago, yxmj said: That's just Canadian Eh... Not in MPH, eh. Maybe the UK XJs can go 120 MPH, ya think? Link to comment Share on other sites More sharing options...
schardein Posted November 26, 2017 Share Posted November 26, 2017 32 minutes ago, kryptronic said: I need to be on the lookout for this one with a tachometer. Sounds like exactly what I need as I've got an AX15. Wondering if any HO XJ police models would have been manuals. I've never seen or heard of a police cluster with the tach. Link to comment Share on other sites More sharing options...
