comancheman Posted August 1, 2007 Posted August 1, 2007 ok ive got some issues that i need to fix asap but i don't know what to fix. i have a noise coming from my tcase. it sounded like my drive chain stretched and was rubbing against the case so i replaced the chain, it still made the noise after the new chain was in so i did some experimenting. with the tcase in neutral and tranny in drive i can hear it if i go underneath the truck. it still sounds just like the chain rubbing but the chain isnt even spinning when the tcase is in neutral. what is spinning in the tcase while in the neutral position? any ideas?
JeepcoMJ Posted August 1, 2007 Posted August 1, 2007 are you telling us you didn't check EVERYTHING while you had it apart? :nuts: you KNOW that leads to :wall: :headpop: :mad: :hateputers: :oops: :redX: :redX: and much :cheers: before you go :nuts: and pull the t-case out of the and :wrench: it then are all like :jump: :banana: after we :thwak: you pretty good. and most of you are like :huh???: after this post. all I have to say is :dunno: I'm gonna go :driving: my now. by the way, I expect your post to generate alot of :papers: :eek: :nanner:
Kenosha Warrior Posted August 1, 2007 Posted August 1, 2007 ignore the weiner's sarcasm. shoulda checked for slop in other things, but you've atleast started to sortof narrow down the problems.
JeepcoMJ Posted August 1, 2007 Posted August 1, 2007 ignore the weiner's sarcasm. shoulda checked for slop in other things, but you've atleast started to sortof narrow down the problems. that wasn't sarcasm. btw my wiener is alot bigger than yours colton. steph said so :P j/k on that one. but it wasn't sarcasm
Oizarod115 Posted August 1, 2007 Posted August 1, 2007 another 231 is probably cheaper/less headache than dealing with that one :dunno:
rockhardzj Posted August 1, 2007 Posted August 1, 2007 I have nearly all the internals for a 231, extra, just laying around.
Kenosha Warrior Posted August 1, 2007 Posted August 1, 2007 ignore the weiner's sarcasm. shoulda checked for slop in other things, but you've atleast started to sortof narrow down the problems. that wasn't sarcasm. btw my wiener is alot bigger than yours colton. steph said so :P j/k on that one. but it wasn't sarcasm quit sniffin glue we all know your 3.8 Manche is powered by a hampster running the wheel.
rockhardzj Posted August 1, 2007 Posted August 1, 2007 we all know your 3.8 Manche is powered by a hampster running the wheel.3 hampster power!!!
Eagle Posted August 1, 2007 Posted August 1, 2007 What's a hampster? I always thought that was somebody from one of the Hampton-named towns on Long Island (NY). Oh! You meant hamster, one of those little furry critters like my sister used to have when she was a kid.
Drahcir495 Posted August 1, 2007 Posted August 1, 2007 we all know your 3.8 Manche is powered by a hampster running the wheel.3 hampster power!!! Don't forget the .8 hamster
comancheman Posted August 1, 2007 Author Posted August 1, 2007 its amazing the intelligence one will receive from one simple question :cheers:
partsmj Posted August 2, 2007 Posted August 2, 2007 I had a noise from my 231 tc after wheeling. It was banging pretty good. My first thought was the old J8134488 transfer case output shaft snap ring. It was broken, I replaced it and thought it was ok. Still banging and it was pretty bad. I pulled the tc in my driveway, knocked it apart and it was toast. I have never seen an oil pump that was stripped, and shafts had bent teeth, it was done. I pulled a 231 from my 90 XJ, and rather than just put it in there, I had to see what it looked like inside since the Jeep had about 210K on the clock. It was good to go. All the shift fork pads were good and it was super clean inside. I put it back together and I hope to have the Jeep back on the road this weekend. Good luck with yours.
rockhardzj Posted August 2, 2007 Posted August 2, 2007 we all know your 3.8 Manche is powered by a hampster running the wheel.3 hampster power!!! Don't forget the .8 hamsterWell, the 4th hampster is missing some toes or mayb e a whole leg or something.... Gimpy little aminal...
DirtyComanche Posted August 2, 2007 Posted August 2, 2007 FWIW, hamsters have a great power to weight ratio.
JeepcoMJ Posted August 2, 2007 Posted August 2, 2007 FWIW, hamsters have a great power to weight ratio. so does a cat but we're not comparing them here are we?
