MJ stuff - CA
Gjeep
Shortbed roll bar, no brackets. Paint needs to be stripped and repainted. $200 + shipping
NOS AX-15 2wd, brand new. Set up for internal slave currently, No bellhousing. $750 + shipping
NOS Renix AC and cruise control items. Basically a box/ lot of parts $400 obo + shipping
Renix Borla header...run on engine for approx 30K....$150 + shipping
Darn it!
Just 27 minutes too slow on the A/C stuff.
Guys let me know what documentation and A/C parts are included.  Going to need the information for when I put the A/C in the diesel Comanche. Mostly will need the evaporator and installation instructions.  Plan is to use the VW a/c compressor and likely a Comanche/Cherokee condenser in front of the stock Jeep diesel radiator.  Will also use the VW cruse control.
Borla hasn't made it for the renix model for about 10 years I believe. Mine has about 30k on it. No issued. I moved to a HO engine set up. Not sure where you are located, but I just shipped a 75 lbs box no so different size to Ohio for $100. I'm guessing the borla would be 1/2 the cost at least. PM me your address and I can figure it out. Thanks.
Here's what's still available...
NOS AX-15 2wd, brand new. Set up for internal slave currently, No bellhousing. $600+ shipping
  • 3 weeks later...
Archived
