big66440 Posted March 31, 2017 Share Posted March 31, 2017 I was wondering if anyone knew the MOPAR part number or ACDELCO ( If I'm not mistaken GM used the same MAP sensor for some of their vehicles) part number for the MAP sensor compatible with the Renix 4.0 ?. Since it's a very important sensor in our fuel injection system I'd rather use a high quality factory part than aftermarket, thanks. Link to comment Share on other sites More sharing options...
DirtyComanche Posted March 31, 2017 Share Posted March 31, 2017 Early HO and Renix ones are the same. Along with GM TBI applications. The later HO ones are different in how they mount (directly to the throttle body) but still have the same logic/output. I'm not Mopar-or-Nocar, so I'd get an ACDelco one... Pretty certain the brand new spare I have on the shelf is ACDelco. Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 31, 2017 Share Posted March 31, 2017 Early HO and Renix ones are the same. Along with GM TBI applications. The later HO ones are different in how they mount (directly to the throttle body) but still have the same logic/output. All 91-95 HO map sensors are firewall mounted and can be used on a Renix. The 96 only MAP is TB mounted but has the same outputs and the earlier MAPs. The 97's and up MAPs are all TB mounted and have different outputs than the earlier MAPS. Link to comment Share on other sites More sharing options...
DirtyComanche Posted March 31, 2017 Share Posted March 31, 2017 Early HO and Renix ones are the same. Along with GM TBI applications. The later HO ones are different in how they mount (directly to the throttle body) but still have the same logic/output. All 91-95 HO map sensors are firewall mounted and can be used on a Renix. The 96 only MAP is TB mounted but has the same outputs and the earlier MAPs. The 97's and up MAPs are all TB mounted and have different outputs than the earlier MAPS. Okay, thanks for the correction, I thought all the TB mounted ones were the same. Silly for them to change them. Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 31, 2017 Share Posted March 31, 2017 Early HO and Renix ones are the same. Along with GM TBI applications. The later HO ones are different in how they mount (directly to the throttle body) but still have the same logic/output. All 91-95 HO map sensors are firewall mounted and can be used on a Renix. The 96 only MAP is TB mounted but has the same outputs and the earlier MAPs. The 97 and up MAPs are all TB mounted and have different outputs than the earlier MAPS. Okay, thanks for the correction, I thought all the TB mounted ones were the same. Silly for them to change them. The 96 was the first OBD2 year but still retained some of the OBD1 sensors. The 97 models were full blown OBD2 and none of the sensors AFAIK will play on our OBD1 or Renix stuff. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted March 31, 2017 Share Posted March 31, 2017 This guy has quite a few delco map sensors at a good price....http://m.ebay.com/itm/NOS-GM-1980S-BAR-MAP-SENSOR-RED-835-CODE-/391741766665?hash=item5b35a0fc09%3Ag%3AYoAAAOSwLEtYhpiA&_trkparms=pageci%253A18b5e6f8-166d-11e7-b991-74dbd180b1a5%257Cparentrq%253A26c8d62c15b0a6228615d255ffff6d1e%257Ciid%253A1 Link to comment Share on other sites More sharing options...
Jeep Driver Posted April 1, 2017 Share Posted April 1, 2017 This guy has quite a few delco map sensors at a good price....http://m.ebay.com/itm/NOS-GM-1980S-BAR-MAP-SENSOR-RED-835-CODE-/391741766665?hash=item5b35a0fc09%3Ag%3AYoAAAOSwLEtYhpiA&_trkparms=pageci%253A18b5e6f8-166d-11e7-b991-74dbd180b1a5%257Cparentrq%253A26c8d62c15b0a6228615d255ffff6d1e%257Ciid%253A1 That's a good deal. However, he is uncertain as to which bar..........do you know? I know the 2 bar is for forced induction.......do you know if it matters? I looked this up in the past and really got no answer. I replaced mine with a GM MAP, it works, from now on I'll only buy ones that are embossed with GM. Link to comment Share on other sites More sharing options...
big66440 Posted April 1, 2017 Author Share Posted April 1, 2017 This guy has quite a few delco map sensors at a good price....http://m.ebay.com/itm/NOS-GM-1980S-BAR-MAP-SENSOR-RED-835-CODE-/391741766665?hash=item5b35a0fc09%3Ag%3AYoAAAOSwLEtYhpiA&_trkparms=pageci%253A18b5e6f8-166d-11e7-b991-74dbd180b1a5%257Cparentrq%253A26c8d62c15b0a6228615d255ffff6d1e%257Ciid%253A1 Seems kinda fishy, I know the guy has 100% feedback but looking them closely they look a bit used, he doesn't have boxes for them either. Nothing to prove he didnt pull them from junkyard cars, bench test them and now he's trying to flip them??? Guess I'm a bit cynical sometimes. Link to comment Share on other sites More sharing options...
Minuit Posted April 1, 2017 Share Posted April 1, 2017 Many years of MAP sensors are actually GM parts anyway - Delco will be fine. Just Everyone Else's Parts etc. I wouldn't believe for a second that those sensors are NOS, but they really aren't too failure prone so I'd feel fine running a used one. Link to comment Share on other sites More sharing options...
Jeep Driver Posted April 1, 2017 Share Posted April 1, 2017 http://www.ebay.com/itm/161795944527?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT Different seller, exact same claims. A lot of genuine NOS is popping up now for some reason.......dealership closings......estate sale collections...........whatever the reason. Link to comment Share on other sites More sharing options...
desbennett004 Posted April 1, 2017 Share Posted April 1, 2017 This guy has quite a few delco map sensors at a good price....http://m.ebay.com/itm/NOS-GM-1980S-BAR-MAP-SENSOR-RED-835-CODE-/391741766665?hash=item5b35a0fc09%3Ag%3AYoAAAOSwLEtYhpiA&_trkparms=pageci%253A18b5e6f8-166d-11e7-b991-74dbd180b1a5%257Cparentrq%253A26c8d62c15b0a6228615d255ffff6d1e%257Ciid%253A1 That's a good deal. However, he is uncertain as to which bar..........do you know? I know the 2 bar is for forced induction.......do you know if it matters? I looked this up in the past and really got no answer. I replaced mine with a GM MAP, it works, from now on I'll only buy ones that are embossed with GM. I would be interested to know this also. Would if effect running if it wasn't forced induction? I plan to turbo my MJ in the distant future when I have a couple grand burning a hole in my pocket... Sent from my SM-N900W8 using Tapatalk Link to comment Share on other sites More sharing options...
fiatslug87 Posted April 1, 2017 Share Posted April 1, 2017 The factory PN is 33000153. Link to comment Share on other sites More sharing options...
