I am finishing up my AX-15 installation and I am missing the transfer case linkage.  I looked into the Novak linkage but it is a little pricey.  Has anyone used another linkage that worked. Has anyone used the 231 HD Shift Linkage (Manual Trans) - Boostwerks Engineering.  The price is awesome compared to the Novak.  What's the difference between the two?  Thanks
Novak is cable, and aftermarket shifter stick.
Boostwerks uses a heim/allthread straight linkage direct from stock shifter to modified  lever at the t-case.
I'm going to go boostwerks on my MJ, when I do 4WD swap, and will at some point on my XJ.
Minus the new t-case side lever, you could source allthread and heim joints local. But, for the price of the kit I think it's worth it.
Junkyard not an option?
Sent from my SM-G930T using Tapatalk
Not really.  The junkyards around here are not great.
BTW where are you in VA? I just moved from Richmond and there are 3 pick-n-pulls and quite a few traditional yards that I've had good luck with.
I'm in Northern Virginia...
I'm another advocate for boostwerks. Works great and I've used both novac and boostwerks. Still takes some adjusting. But once set never had an issue
Sent from my SAMSUNG-SM-G891A using Tapatalk
Some people have taken the older linkage and flipped over.  You can search for that on here (and other Jeep forums) to check how it worked out.
