Flywheel milling
So a few years ago I got a fywheel from a 95' ax-15 milled by a shop. It turns out, I never needed this flywheel until now. I have read some very conflicting reviews about milling ax-15 flywheels as they are convex, and do not need to be milled like traditional ones. I have run a unmilled flywheel for about 3 years in my jeep with no issues. I now need to use the milled one, and I am wondering if I will run into any problems.
IN SHORT: I have milled AX-15 flywheel I want to use, Ive read thats not ok
Following.  I just pulled my flywheel and replaced with an Advance Auto one.  Wanted to get mine resurfaced and keep....
I didnt know advance sold them, I suppose thats an option if I messed mine up. I don't see it being an issue, but at the same time I don't want to find out the hardway and have to drop a trans. haha
A proper machine shop should be able to mill the convex shape, and should also know to look up the proper specs they're milling to. But there's no guarantee that a machinist will bother to do it properly. Some will, some won't. It's probably best to confirm with the machine shop in question.
I work in a machine shop. Where would one find said specs for shape?
Sent from my SM-G930T using Tapatalk
Thats what I assumed. However, I did not know about the convex when I had it milled. And have no idea what the shop did as it was probably 5 years ago
:dunno: presumably the manufacturer?
I'm not a machinist, but if I was I'd be making sure I was doing things properly.
Don't get me wrong, I have a huge amount of respect for machinists. I've tried my hand at it, and huge amounts of precision don't come to me very easily. I wish I was better at it... Seems like an awesome trade.
But there could be any other motivation for that. It could be that they're afraid taking off too much material could cause the clutch to not keep adequate pressure on it, or it could even simply be they want to sell more new flywheels.
Chrysler-Jeep's motivation doesn't matter. If they don't even tell their dealers what the specs are, where would you look for them?
In past years, there were people who posted periodically on NAXJA about having had their flywheels resurfaced, and the results were always horror stories. Of course, I'm sure that was because the shops milled them flat, but there was a reason why Jeep said not to machine them.
I have done hundreds or clutch jobs and always had the flywheel machined and NO machine shop has ever heard of convexing
the surface(non that I have ever dealt with) and all have been machined as a normal flywheel would be and NOT 1 failure nor can I conceive any reason why
the machine surface would do any damage so that leave's it to installation error and since people never own there own mistakes
they blame anything and anyone instead...
Now having said all that if you can get a NEW flywheel for $50 then you jump on that because I can not get a new one for anywhere near that price so $50 to machine one is about the going rate here...
I would have thought getting your flywheel milled would be the same as getting your brake rotors done, hardly worth it. I know here, the labor cost just means it's more cost effective to buy new.
Sent from my SM-N900W8 using Tapatalk
I've heard that quite a bit from members of other forums when I asked if any DIY guys had a brake lathe to turn their rotors/ drums. Shops usually charge about 10 bucks a piece in my area, I'm not questioning your credibility in any way but would you mind sharing the average cost to get them turned? just curious, thanks.
I just had mine resurfaced... and now I'm a little worried, i havent installed it yet but what kind of "horror stories" have been told about using resurfaced flywheels...
I may be in the market for a new flywheel...
Sent from my SM-G930P using Tapatalk
I surfaced mine before putting it in. When the truck would get warmed up it would tend to not fully release when the clutch was pushed in. It was a very minor amount, but at stop lights and the such you'd notice by not rolling back any, or even creeping a little.
So I drove the Truck home last night.  I experienced the same as Mattwheels has..   :rant:   !st and 2nd  are stiff, 3rd and 4th no issues.. and 5th seems tight.
