What are these ?
This is interesting, i have never ever seen these two parts mounted in those places. Right hand drive?
And yes, leave them alone, especially the MAP sensor in the first picture. You don't have to have the diagnostic plug, Renix scan tools are few and far between, but it would be a mess trying to track down and eliminate each of the wires.
since i did a engine swap i really don't think my map sensor is controlling anything on the motor
in the second pic the black thing with the two red wires is a fuze
i was wondering what are those two white-ish squares next to it doing
oh so the white squares are where you plug in the computer and it tells you whats going on
since i don't have the original motor and almost non of the sensors hooked up I'm not ever gonna really use those things
and i have ran the truck parked on idle and discounted the hose to the map sensor
i did not notice any difference in the motor with it connected or not
at this point is it safe to say that i don't need either of them ?
Disconnect the hose and the electrical connector and go for a drive...report back  :-)
lol flat on the face as he takes off........
So what motor did you put in?
Not the original motor (type) means going from a 2.2 to a 4.0 or sbc etc.
Is this a 4cyl? Stock engine controls (computer)?
If this is a direct replacement, I'd suggest reading up on engine controls, what they do, and why you need them.
yes its a 2.8 originally but i put in a 3.4
i didn't really do an engine swap the vehicle was bought with no 2.8 in it
so i had to drop in the 3.4 kinda like free-styling it
i will take it for a test drive with the tube disconnected and see if i notice any difference
