Double Six Posted May 20, 2016 Share Posted May 20, 2016 Hey guys,do you have to replace your whole steering shaft assembly or can you just put in new u-joints , if so who has them? mine has slack in the one under the brake booster. Thanks. Link to comment Share on other sites More sharing options...
COMJNUT Posted May 20, 2016 Share Posted May 20, 2016 I just went for the whole assembly. From 4 Wheel Parts Link to comment Share on other sites More sharing options...
daking Posted May 20, 2016 Share Posted May 20, 2016 Borgeson for $150. http://www.pscmotorsports.com/shop-by-brand/borgeson/steering-shaft-telescopic-steel-jeep-2034.html I installed it, but honestly, it is not much better then factory on the MJ/XJ applications. It is a little more beef, but over all same design. Borgeson shafts for other applications, like 73 to 93 RAM Trucks are much better then factory. Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 20, 2016 Share Posted May 20, 2016 Borgeson for $150. http://www.pscmotorsports.com/shop-by-brand/borgeson/steering-shaft-telescopic-steel-jeep-2034.html I installed it, but honestly, it is not much better then factory on the MJ/XJ applications. It is a little more beef, but over all same design. Borgeson shafts for other applications, like 73 to 93 RAM Trucks are much better then factory. Thanks - I was considering the Borgeson option. The V8 ZJ's had a beefier shaft too; I'll look into adapting that. :cheers: Link to comment Share on other sites More sharing options...
xjrev10 Posted May 20, 2016 Share Posted May 20, 2016 I just went for the whole assembly. From 4 Wheel Parts Yep. Exactly what I did. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted May 20, 2016 Share Posted May 20, 2016 If you have slop in the steering shaft, it could also be that the rubber bushing has devulcanized, which is fairly common for a 25+ year old part. I saw not too long ago where someone removed the shaft, welded it solid, and once again has tight steering. <Original thread> That intermediate shaft (between the gear box and steering column) has a vulcanized rubber bushing. After age, it will de-vulcanize and cause that slop. You can weld the "stops" in place on it which will prevent you from having to replace it at all. Link to comment Share on other sites More sharing options...
big66440 Posted May 20, 2016 Share Posted May 20, 2016 Borgeson for $150. http://www.pscmotorsports.com/shop-by-brand/borgeson/steering-shaft-telescopic-steel-jeep-2034.html I installed it, but honestly, it is not much better then factory on the MJ/XJ applications. It is a little more beef, but over all same design. Borgeson shafts for other applications, like 73 to 93 RAM Trucks are much better then factory. I have the same Borgeson piece waiting to be installed according to the instructions it's not 100% bolt on. Was it difficult to install? any tips? thank you Link to comment Share on other sites More sharing options...
daking Posted May 20, 2016 Share Posted May 20, 2016 Humm, for the Jeep? It was a simple bolt in. no modding or cutting needed. I replaced the steering box at the sometime. For the Dodge trucks, modification is needed. Link to comment Share on other sites More sharing options...
Double Six Posted May 21, 2016 Author Share Posted May 21, 2016 What is the best way to remove the shaft? can you get to it from underneath the truck or do you have to remove the brake booster to get to it ? Thanks again for your help in this matter. Link to comment Share on other sites More sharing options...
mrmel2you Posted May 21, 2016 Share Posted May 21, 2016 You can remove the shaft from under the hood. No need to remove the brake booster. Remove the bolt at the joint towards the firewall, remove the bolt from the joint towards the gearbox. Use a small pry bar at the joint at the gearbox, pry the shaft towards the firewall. Should come right out. You may have to spread the clamps apart a bit (where the bolts are at the joints) use a small pry bar/chisel/screwdriver----whichever one you want to use, I used an old flathead screwdriver I had :) Link to comment Share on other sites More sharing options...
Double Six Posted May 21, 2016 Author Share Posted May 21, 2016 ok thanks,that helped a lot mrmel2you !!! :thumbsup: Link to comment Share on other sites More sharing options...
mrmel2you Posted May 22, 2016 Share Posted May 22, 2016 I'm a newbie here "Double Six", but glad I could help :) This club is AWESOME, filled with AWESOME members and there a ton of helpful files in here. Really helped me out, this is my first MJ (first ever Jeep product) but I'm getting to like it more and more every day :) Happy Trails, Papa Mel :) Link to comment Share on other sites More sharing options...
daking Posted May 22, 2016 Share Posted May 22, 2016 You can remove the shaft from under the hood. No need to remove the brake booster. Remove the bolt at the joint towards the firewall, remove the bolt from the joint towards the gearbox. Use a small pry bar at the joint at the gearbox, pry the shaft towards the firewall. Should come right out. You may have to spread the clamps apart a bit (where the bolts are at the joints) use a small pry bar/chisel/screwdriver----whichever one you want to use, I used an old flathead screwdriver I had :) Yep, exactly how I did it too :) I was expecting it to be more difficult Link to comment Share on other sites More sharing options...
Big Dan Posted May 23, 2016 Share Posted May 23, 2016 Anyone have any links for steering shafts for manual steering boxes (ie - not power steering) ? Link to comment Share on other sites More sharing options...
benjy_26 Posted May 23, 2016 Share Posted May 23, 2016 Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 23, 2016 Share Posted May 23, 2016 Power and non-power steering columns use different shaft part numbers, 52001947 vs. 52001948. What the difference is I have no idea. If you're lucky the non-power shaft is just beefier but will play. The ZJ box will be no problem though as the MJ and ZJ housings and input shafts are the same. Link to comment Share on other sites More sharing options...
benjy_26 Posted May 23, 2016 Share Posted May 23, 2016 Power and non-power steering columns use different shaft part numbers, 52001947 vs. 52001948. What the difference is I have no idea. If you're lucky the non-power shaft is just beefier but will play. The ZJ box will be no problem though as the MJ and ZJ housings and input shafts are the same. Cool deal. I'll be doing my conversion as soon as my steering box brace and spacer get here. I'll let y'all know how everything fits together. Link to comment Share on other sites More sharing options...
