Renoenvy08 Posted March 8, 2016 Share Posted March 8, 2016 I just bought a 90 MJ Eliminator, The guy I bought it from has put Cherokee rearend and springs under it so now the back of my truck sits about 4" higher, how can I fix this problem when I don't have the stock springs? Link to comment Share on other sites More sharing options...
Pete M Posted March 8, 2016 Share Posted March 8, 2016 can you share a picture of the springs you have? Link to comment Share on other sites More sharing options...
Zebvance Posted March 8, 2016 Share Posted March 8, 2016 Pictures would be helpful. I don't think that cherokee spring would have physically been able to bolt up. I believe they are shorter Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 8, 2016 Share Posted March 8, 2016 Pictures would be helpful. I don't think that cherokee spring would have physically been able to bolt up. I believe they are shorter Yes, by almost 6". Link to comment Share on other sites More sharing options...
Megadan Posted March 8, 2016 Share Posted March 8, 2016 I wonder if he added leaves from a Cherokee pack into the Comanche ones? That would make sense to me, and would also explain some lift. Link to comment Share on other sites More sharing options...
yxmj Posted March 8, 2016 Share Posted March 8, 2016 Or he went spring over when he put in the XJ diff? Link to comment Share on other sites More sharing options...
Pete M Posted March 8, 2016 Share Posted March 8, 2016 I saw a picture on facebook not that long ago and it was definitely XJ leaves on an MJ. the shackle pointed forwards and was parallel with the leaves. very bad. ther are a couple manufacturers out there that make stock MJ leaves. also car-part.com might be of help finding them in junkyards. be wary of the used ones and inspect them thoroughly. the leaves have a bad habit of cracking at the bolt. Link to comment Share on other sites More sharing options...
Megadan Posted March 8, 2016 Share Posted March 8, 2016 I am very happy with my General Springs stock repalcement leaves. Highly recommended. New will obviously be more expensive, about $280 plus shipping (which was about $88 for me). Link to comment Share on other sites More sharing options...
Renoenvy08 Posted March 9, 2016 Author Share Posted March 9, 2016 I talked to the guy I got my MJ from he said he only changed axel and went from under to over plus different gear ratio. So now I need to figure out what to do about that thanx everyone, tried to upload pic but was told file too big Link to comment Share on other sites More sharing options...
yxmj Posted March 9, 2016 Share Posted March 9, 2016 Either go back to spring under or lift the front....coil spacers are an easy quick fix Link to comment Share on other sites More sharing options...
Pete M Posted March 9, 2016 Share Posted March 9, 2016 putting the springs on top gives about 5-6 inches of lift. how much lift is up front? did he move the perches on the XJ axle? XJs and MJs have their perches in different widths apart. Link to comment Share on other sites More sharing options...
gogmorgo Posted March 10, 2016 Share Posted March 10, 2016 No such thing as an image too large. If your image host rejects it, find a better one. When you're posting a pic, you aren't uploading it to this site. You're linking it in from somewhere else on the internet. Link to comment Share on other sites More sharing options...
Incommando Posted March 10, 2016 Share Posted March 10, 2016 I'll bet his "soa" is the Chero perches in the stock location. Link to comment Share on other sites More sharing options...
dunnc1991 Posted March 10, 2016 Share Posted March 10, 2016 I'll bet his "soa" is the Chero perches in the stock location. This ^ Link to comment Share on other sites More sharing options...
