Renoenvy08
Everything posted by Renoenvy08
I know this is in here somewhere but I can't find it, can someone tell me the size of the mounting bolts for a ax15 bellhousing to a 4.0l block?
Eliminator tranny question
Renoenvy08 replied to Renoenvy08's topic in MJ Tech: Modification and Repairs
I was quoted $3300 to rebuild my tranny and xfer case ( broke 1 gear on cluster and a separate one) this tranny I'm looking at is from a 90 2 door Cherokee, was just curious because a have a eliminator. -
Could anyone tell me how much the total length of the eliminator ax-15 with a NP-231? I. Think I found a replacement for my eliminator but want to be shure
Does anyone know where I can find a 1990 eliminator ax-15 cluster gear? I ordered what was supposed to work but it's completely different. Any ideas?
Stupid question (maybe)
My MJ is a 90 the xj is 94, I'm trying to get another ax-15 for the MJ -
My no231 is toast but, I'm parting my xj will the np231 from the xj fit my MJ?
I got my seals, run channel and door weatherstripping today. I tried to put the channel in and I couldn't get if to work till I pulled the front piece of glass then it was easy. On another note just got a call from the tranny shop to rebuild my AX-15 and transfer case they want $3300. I'm thinking I'm going to get a tranny off eBay. thoughts?
That's what I was looking for I'll order them tomorrow and let you know how they are. Tyvm
I remember seeing a write up about replacement door window seals and I can't find it anywhere, if someone could please let me know where that write up is or where they got replacement seals it would be appreciated. Thx
Gauging Interest: Manual Window Regulators
Renoenvy08 replied to JolietJEEP'84's topic in MJ Tech: Modification and Repairs
I'd be interested in one of ea. But no clue how much. A friend of mine found a RH side online for like $75, it was the only one -
You'd think people in washington could drive in the rain, they can untill the weather changes then they forget how when it rains again. What's sad is this goes for all weather
Well I finally got tired of putting Band-Aids on my mj. From what I've seen it's been hit at least 3 times (ea quarter panel, R rear). So I started taking it apart, I'm thinking I might need a donor Cherokee if I have any uni- body dmg, but haven't got that far yet. I'm trying to hold myself to doing one thing a day to it, I'll keep updating
I just put a clutch disk/ pressure plate/ throw out bearing in. It was making noise in all gears but 4th was the quietest I got home then replaced the clutch put it back together and still making noise
my tranny started making a heavy clicking sound (AX15) you only hear it when your in gear and not pushing the clutch if you push in the clutch it goes away has anyone elce had this happen? and what was the cause thx in advance
Rear main, if you don't do it (if you have my luck) it will start leaking after you drop the motor in
Thanks, a new one is otw
Does anyone know where I can find a new inner boot for the shifter? Some mice got into my truck (made a nest next to core flap) on the way they chewed up the boot that bolts to the body, thought about using a piece of inner tube but not Shure that will work. Any ideas?
While I was trying to figure out why my headlights won't work this fell out of the turn signal part of the column, I'm pretty Shure it has to do with the high beams as now I don't hear the click (and no resistance) when I move the turn signal arm like I was trying to put the lights on high. Thanks for the help
Would anyone know where to get a new combination valve? There's no mj's in the my around here the closest I've found is K.C. kansas. That's a long haul from Washington
Well I shouldn't have said anything, my booster started sucking air so now I'm putting in a new booster after white knuckling it for two days over the Tacoma narrows bridge and back just waiting for payday
Well I have the upgraded axle in, getting ready to take it out on a test drive. Thank to everyone who gave me advice. As a bonus this just arrived a day early. Think my next upgrade is going to be the booster
Hi, my name's Ted. I live in port orchard. I have a 1990 eliminator, ax15. I'm currently swapping out my front axle to a non vacuum one, should be done today
K, I tried using a punch but I couldn't get it to move. I'll stop and get a different one.thanks
