ahmincha Posted October 16, 2015 Share Posted October 16, 2015 Well I bought another one its a 92 2wd 4.0 auto with air Link to comment Share on other sites More sharing options...
ahmincha Posted October 16, 2015 Author Share Posted October 16, 2015 Link to comment Share on other sites More sharing options...
cbreiter Posted October 16, 2015 Share Posted October 16, 2015 It's a nice truck! Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted October 16, 2015 Share Posted October 16, 2015 That's the one on CL not too far from me . How is it ? Link to comment Share on other sites More sharing options...
ahmincha Posted October 16, 2015 Author Share Posted October 16, 2015 Thanks cb Well stroke the unibody is in good shape all solid so far. motor runs well trans shifts good body will need some work but what did I expect LOL. And if I am not mistaken it has a dana 44 with limited slip Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted October 16, 2015 Share Posted October 16, 2015 Thanks cb Well stroke the unibody is in good shape all solid so far. motor runs well trans shifts good body will need some work but what did I expect LOL. And if I am not mistaken it has a dana 44 with limited slip Nice !! Link to comment Share on other sites More sharing options...
Minuit Posted October 16, 2015 Share Posted October 16, 2015 That's a D44 alright. Other than the rust it looks pretty solid. Looks like a few people before you have tried to fix the rust and probably just made it worse. Link to comment Share on other sites More sharing options...
1992EliminatorSWB4x4 Posted October 16, 2015 Share Posted October 16, 2015 A great project it is. The 1992 dash and interior is in nice solid shape. It's a keeper. Link to comment Share on other sites More sharing options...
ahmincha Posted October 17, 2015 Author Share Posted October 17, 2015 Thanks Min. So does that mean it is a metric ton Link to comment Share on other sites More sharing options...
Minuit Posted October 18, 2015 Share Posted October 18, 2015 Hard to tell for sure, but those look like the standard 3+1 springs to me, which would make it a non-metric ton. If you can take a picture of the leaf springs we could tell for sure. Link to comment Share on other sites More sharing options...
ahmincha Posted October 18, 2015 Author Share Posted October 18, 2015 I'll take some tomorrow. Well my plan is to fix the body paint it convert it to 4wd I'm going to change out all the fluids tomorrow gas tank is leaking so I ordered a new one and straps. It should be here next week It seems to be leaking trans fluid from the lines I will have to replace them ac lines are rusted and previous owner put a new used radiator in that doesn't look all that great so that has to go Also it needs new rear brakes and today the hood release cable broke. But its a jeep and this is all expected Link to comment Share on other sites More sharing options...
ahmincha Posted October 20, 2015 Author Share Posted October 20, 2015 contacted jeep on sunday and they emailed me a build sheet already. No mention of metric ton. but they did say it had 18" tires Link to comment Share on other sites More sharing options...
ahmincha Posted October 21, 2015 Author Share Posted October 21, 2015 Ok I am going to start looking for parts to do my 4x4 swap just want to verify that the trans and transfer case from 1991 thru 96 cherokee trans and transfer case is bolt in and same for front sheet metal Thanks Link to comment Share on other sites More sharing options...
ahmincha Posted October 25, 2015 Author Share Posted October 25, 2015 new fuel tankNew ujoints Brakes and rear brake lines Link to comment Share on other sites More sharing options...
ahmincha Posted October 28, 2015 Author Share Posted October 28, 2015 new exhaust system Link to comment Share on other sites More sharing options...
ahmincha Posted November 21, 2015 Author Share Posted November 21, 2015 Well was driving down the freeway hit a bump and went into death wobble. So I replaced the tie rods and dampener had it aligned hopefully that does it Link to comment Share on other sites More sharing options...
ahmincha Posted December 12, 2015 Author Share Posted December 12, 2015 Ok found a donor cherokee for 4wd conversion its a 01 will the trans and transfer case work Link to comment Share on other sites More sharing options...
valis Posted December 12, 2015 Share Posted December 12, 2015 Nice looking truck. I still have the white '92 that we swapped several years ago. Other than blowing through clutch slave cylinders it's running strong! Link to comment Share on other sites More sharing options...
ahmincha Posted December 13, 2015 Author Share Posted December 13, 2015 Nice to hear from you. Thanks no where close to as clean as that one but it will do I just sold the wrangler a few months back and had to get something. Link to comment Share on other sites More sharing options...
ahmincha Posted December 14, 2015 Author Share Posted December 14, 2015 Well i got a couple donor cherokee 1st one 1990 I like these rims And a 01 Link to comment Share on other sites More sharing options...
ahmincha Posted December 15, 2015 Author Share Posted December 15, 2015 This is the diff from the 01 the one I am going to use I guess I will have a little work to do to it But at least the area that holds the track bar and stabilizer are solid Link to comment Share on other sites More sharing options...
shelbyluvv Posted December 15, 2015 Share Posted December 15, 2015 That diff is a weaker low pinion version. I would not put a single dollar into fixing it. HP 30s are a dime a dozen. Pick up a good usable axle and throw that LP away. Link to comment Share on other sites More sharing options...
ahmincha Posted December 15, 2015 Author Share Posted December 15, 2015 Thanks shelby I did make that decision last night. Already found a hp 30 should pick up tonite Link to comment Share on other sites More sharing options...
ahmincha Posted December 23, 2015 Author Share Posted December 23, 2015 my 3" lift showed up Axle gone replacing rear main seal while I'm here Trans gone Link to comment Share on other sites More sharing options...
