I've spent most of the day reading reviews on various tires since
the (used) Wrangler Radials I put on didnt exactly wow me during
this last snowfall. I pretty much decided on the Wrangler DuraTracs
but when I enter vehicle information all the sites agree that "these
tires do not fit your vehicle..." blah, blah...
LT235/75/15's - only differences are higher PSI max (30vs50) and
LOWER weight capacity (1958vs2028) but other than that they seem
on paper to be near exactly the same tires.
I don't exactly have my heart set on the DuraTracs, and Ive had
great experience with the more expensive Michelin AT2s on
other vehicles, I'm just confused to whether I missed something?
The sites report that they don't fit because that size was never used by the factory. The largest from the factory was 225/75R15.
That said, even as I type my wife's Cherokee is rolling on Wrangler Radials in 235/75R15 and they fit fine. My old '88 Cherokee is on 31x10.50-15s, with no lift -- and the Cherokee rear wheel wells are smaller than the Comanche's.
As long as you are running a rim with stock backspacing you will have no problem..... . :MJ 1: .
Well I have always run P235/75R15 on my Michelins and Bridgestones,
and TireRack, TireDirect, and Amazon all list this size as fitting my Mj in
Goodyear Wrangler Radials (which I am currently running) among others.
But P235/75R15 in Wrangler RS fit, but LT235/75R15 DuraTracs supposedly
do not. Is anyone here running the 29" DTs on their stock wheels? My
concern is that the stiffer sidewall somehow prevent the tire from being
mounted on the wheel... or something along those lines....
You will not have any issues mounting an LT tire on a factory or any other type of rim that would normally fit that size tire. I think that you are over thinking this. The website that says that tire won't fit your truck is not the be all and end all of tire mounting information. It may just be saying it because the MJ was never rated for an LT tire. A lot of the Michelin LTX's and BFG A/T's that are commonly used are LT rated and are used with no issues. If you like those tires, get them. You'll be fine!
A big issue is not just the size but the design. A mild street tread or A/T will fit without rubbing the LCA where an M/T with aggressive side lugs will rub. I put 31s on an unlifted 2wd and they never rubbed but they were a street tread.
For liability reasons those dealer sites will rarely suggest a non-stock size.
I ran a full set of 235/75 x 15 Kumho SR21 tires for a while with no problems on stock aluminum wheels.
Only reason they are not on the truck now is the truck was stolen in Tijuana and the thieves took the tires and wheels.
