I'm doing the 4wd swap and having new floors, inner and outer rockers, and cab corners put on I don't want them messed up.
So I would like to see pictures of rock rails and how you mounted them. Thanks
I'm thinking of doing the same thing, so I'll follow this thread .
mnkyboy, thats some crazy flex! I hope my Comanche can do that. Does the front spring re-seat on its own when it lowers back?
That was right after I built the suspension, I had just pulled it out to check some clearances.
Once its all set up and the shocks are in it shouldn't go quite that far.
I cut through my frame and ran the supports through it.  doesn't touch the rockers, strong as hell, and is a frame strengthener too.
Love that idea
Bolts onto the uni body rail and about every 6" on the pinch seam. I haven't shock tested by dropping onto a rock, but I've picked up the whole side of the jeep quiet a few times with no flex
